2.5 Pulley / Serpentine Advice - JeepForum.com
 2Likes
  • 1 Post By mukluk
  • 1 Post By Jonny Jeep
post #1 of 10 Old 03-21-2020, 05:43 AM Thread Starter
ozzyjeep69
Hi all. I have a 98 2.5 RHD, been sat in a field for years. New to TJ's.
The serpentine belt has had it, and all the pulleys are rusty as hell. Im going to replace them all.
Ive hunted the forums, and looked / googled for ages at all the pics of the serp routing, pulleys etc. and a lot are similar, but none are exactly like mine.
I dont have A/C, but I do seem to have a pulley on a bracket what looks like where the AC compressor should be.
Can anyone advise what part # for this pulley? Its sort of a big idler I think..?
I guess also I need a belt sized for an engine "with AC"?
Also do you think I should replace the entire alternator or can I just change the rusted out pulley on the front?
Thanks!
ozzyjeep69 is offline
post #2 of 10 Old 03-21-2020, 05:57 AM
Arty McGeep
Arty McGeep's Avatar
Hello. Changing just the pulley on the alternator looks like it might be rather difficult. I probably wouldn’t try it. You might just try taking the belt off and cleaning up the grooves on the pulley with a wire brush. Check to see that the alternator turns free by hand. If it does, I’d just run it. I’d be more worried about the frame underneath the Jeep. How does that look?
Arty McGeep is online now
post #3 of 10 Old 03-21-2020, 06:35 AM Thread Starter
ozzyjeep69
The frame is ok, just some surface rust. Pretty common here in the UK given its always pissing with rain!
post #4 of 10 Old 03-21-2020, 08:54 AM
TJ4Jim
I have a 99 TJ with the 2.5 and looking at your setup it looks to me like it may have had AC originally because the large pulley in the upper left is like nothing I have ever seen. Someone may have eliminated the compressor and installed a pulley in it's place rather then using the AC delete belt. See the diagram for a 98' below. I would just order a non-AC belt and eliminate pulley.
If you come to a fork in the road take it.
TJ4Jim is offline
post #5 of 10 Old 03-21-2020, 02:34 PM
Jonny Jeep
Jonny Jeep's Avatar
It seems the 2.5L RHD has same routing as the 4.0L RHD. The routing is correct. Parts list shows the same belt routing diagram for both 2.5 and 4.0 RHD.
Here's a pic of the decal that would have been on the original radiator.
Jonny Jeep is offline
post #6 of 10 Old 03-21-2020, 04:41 PM
TJ4Jim
I agree but why is there a pulley where the compressor should be on the 2.5
TJ4Jim is offline
post #7 of 10 Old 03-21-2020, 05:27 PM
mukluk
mukluk's Avatar
The alternator on the RHD version is tucked lower/closer to the block to provide clearance for the steering shaft, thus placing its pulley too low to use the standard non-AC belt routing found on LHD models. That's why you have the additional idler pulley where the compressor would normally sit.
From what I can see of the idler in question it appears to have only some minor surface rust. I'd be inclined to just clean it up and replace the bearing if it were mine.
TJ4Jim likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #8 of 10 Old 03-21-2020, 06:19 PM
mukluk
mukluk's Avatar
Looks like the idler should be part number 4792112AE, or 38042 for aftermarket (90mm diameter). If interested in replacing just the bearing, it should be a 6203-2RS.
2000 TJ SE
2005 LJ Rubicon
post #9 of 10 Old 03-22-2020, 03:37 AM
Jonny Jeep
Jonny Jeep's Avatar
Mukluk, explained it well except the alternator is slightly higher rather than lower. These pictures show my 4.0L, with the belt removed, compared to a LHD 2.5 pic I found. As you can see the non AC RHD has the same idler pulley where the AC compressor would be. The idler pulley to the side of the alternator is lower down and closer to the alternator. With end on views, it's easier to see that the LHD non A/C routing can't be used on the RHD models.
TJ4Jim likes this.
post #10 of 10 Old 03-22-2020, 04:50 AM Thread Starter
ozzyjeep69
Great, sorted thanks.
serpentine
