12 hole injectors - JeepForum.com
 10Likes
post #1 of 23 Old 06-07-2019, 11:20 PM Thread Starter
GAragecouple
GAragecouple's Avatar
12 hole injectors
Any thoughts on swapping out original injectors for the 12 hole ones?
GAragecouple is offline
post #2 of 23 Old 06-08-2019, 05:38 AM
biffgnar
biffgnar's Avatar
There are some extensive threads on injector swaps that you should be able to find and read. IMO at best you may get a little smoother running engine (and that may be placebo effect), but will be no change to power, mileage, etc.
biffgnar is offline
post #3 of 23 Old 06-08-2019, 06:40 AM
jtec
2014 JK Wrangler
If it ain't broke .......
Agree with above statement- anecdotal at best.
Jerry Bransford likes this.
jtec is offline
post #4 of 23 Old 06-08-2019, 08:48 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
There's no real significant benefit to doing that swap, I wouldn't waste my $$$ to do that.
shortydog33 likes this.
Jerry Bransford is offline
post #5 of 23 Old 06-08-2019, 09:54 AM
JEK3
JEK3's Avatar
If you already need to swap your injectors (broken, clogged, whatever), then it can't hurt to try them if there isn't much cost difference. Just keep in mind that any performance improvement is probably due to the fact that you needed to swap your injectors.
JEK3 is offline
post #6 of 23 Old 06-08-2019, 08:44 PM
Kaptainkid1
I just did mine today and bought 6x refurbished ones on ebay Bosch. 2002 Jeep wrangler sport 4.0l 166k was a dog and slow as ****. I have 31in tires, 3in lift, basket and gas tanks. So i also pulled the oem airbox snorkel off and is breathing much better. She has more power and its a big notices from stock. With extra weight in the back im also running air lift 1000. She is all leveled now too.
20190608_172107_1560048084692.jpg   20190608_154714_1560048103895.jpg   20190527_131100_1560048139254.jpg
Kaptainkid1 is offline
post #7 of 23 Old 06-09-2019, 06:34 AM
biffgnar
biffgnar's Avatar
Have you ever heard of confirmation bias?
Newtons3 and jtec like this.
biffgnar is offline
post #8 of 23 Old 06-09-2019, 11:23 AM
Kaptainkid1
Wouldn't the larger opening in the airbox help with power.
post #9 of 23 Old 06-09-2019, 11:54 AM
SkylinesSuck
Not if it wasn't a bottleneck to begin with. Also the shape of that airhorn promotes airflow.
Newtons3 likes this.
'98 Sahara w/AX15 & 4.6L stroker, 2.5" OME lift, 32" BFG M/T's, 8.8 w/Detroit Trutracs & 4.10's F&R
SkylinesSuck is offline
post #10 of 23 Old 06-09-2019, 12:25 PM
biffgnar
biffgnar's Avatar
Isn't it Venturri effect or something like that? And the internal flow restrictions within the 4.0 are the limiting factor.
biffgnar is offline
post #11 of 23 Old 06-09-2019, 02:52 PM
Jerry Bransford
Administrator
No. That 'trumpet' plugged into the air box is there to speed the airflow into the engine which reduces engine noise and help with combustion. Even with the trumpet in place the engine still easily gets more air flow through the air intake system than it can possibly consume at WOT and redline rpms. Leave the trumpet in place, it does not reduce performance in the least.
post #12 of 23 Old 06-11-2019, 04:54 PM
WeezyBlue
You know, I just sent in and had the injectors from my turbo'd 91 Celica with 180k miles cleaned and tested by WitchHunter, vs buying replacements.
Test results show they were still flowing perfectly before cleaning. Did come back shiny though.
KD8UCX
05 TJ Rubicon DD
82 Wagoneer Limited WIP
06 TJ SE Sold
WeezyBlue is offline
post #13 of 23 Old 06-11-2019, 07:16 PM
Jerry Bransford
Administrator
You can thank modern gasoline formulations chock full of cleaners for that. Clogged/dirty fuel injectors have been rare since then.
post #14 of 23 Old 06-11-2019, 08:17 PM
Kalten
Correct me if I am wrong, and I probably am, I don't think running a multiple hole fuel injector without any additional filtration is a great idea since it would be easier to clog. Not sure if there is any other fuel filter besides the one on the fuel pump pickup and I don't know what its micron rating is.
06 LJ Auto, 4" SL, Synergy Adj CA & Trackbar, 33x10.5 AT KO,
231 w/(WC,2lo,6pinion & JB-C SSYE)
Kalten is offline
post #15 of 23 Old 06-11-2019, 10:45 PM Thread Starter
GAragecouple
That's a good question. I'm guessing what would clog the 12 hole would also clog the 1 hole. Hmm
