Wizard of Brakes
LinkBack | Thread Tools |
Originally Posted by DaleII
View Post
No. Now I'm actually more afraid of the Jeep doing a front flip or a stopy.
I am Savvy
blackmagicbrakes.com
Sponsored Links | |||
His name was Dave. He drove it a few weeks ago?
2005 Silver LJ
Wizard of Brakes
Dave was late. He was supposed to be there at 10 and I hung out a bit longer than was needed to wait for him.
What did Dave think?
I am Savvy
Originally Posted by mrblaine
View Post
2005 Silver LJ
Since I am a card carrying Southern Smartass member # 2145 and no one else has said it, it is left to me.
blaine and anyone else from Savvy, needs to be very careful when testing that bracket, you stop too quickly and luckrider's head will be up your ***.
Originally Posted by Neudiin
View Post
Well, another day gone by and my Brackets-O-Death have killed no one.
Practical application is still kicking theory's butt.
View Post
Lowered, Dubbed, and Spinning
Why wear a flip flop on your left foot, and a steel toe on the right?
Wizard of Brakes
Originally Posted by lostsheep
View Post
Your like the kid in math class who HONESTLY doesn't understand why the answer is less important than the solution.
That bracket is not going to fail and there's nothing you can do to make it fail and I'm going to post back up for every day that goes by and it doesn't fail or kill someone.
Besides all of that, in reference to your math kid analogy, I knew the process to arrive at the solution long before I built the brackets. I'm well familiar with aluminum alloys and what they can and can't do. I've been working with it in stressful applications for at least 20 years.
I am Savvy
And you're like the teacher who doesn't understand that some folks know what will work and go do it even if it isn't arrived at by conventional means.
You are most likely 100% correct. All I'm trying to point out, is that in a safety sensitive system, there is ZERO room for oversight. You gotta test.
Your statement regarding the teacher vindicates mine about the student. Answer inclined kids become mechanics and solution inclined kids become engineers, for better or worse.
Over and way the *&^% out.
Wizard of Brakes
View Post
I have not once said it was going to fail. I believe I said:
It scares the piss out of me that someone who sells so many brakes ASSUMES anything at all.
Look around, do you see the kit for sale yet? No you don't and you won't until I'm 100% comfortable that it will take everything anyone can throw at it and survive just fine. For the record again, I DO NOT SELL ANY BRAKES. I am the designer, developer, and supervise the testing and evaluation.
You're late to the party with your assumptions, but no one has spent as much time as I have figuring out the process for making these things work. The fact that I'm 100 percent successful with ZERO failures of ANY KIND should give you a clue as to the amount of time I spend on this stuff.
Just because I have no letters behind my name to satisfy the needs of some doesn't mean I take this stuff lightly, nor does it mean I haven't sent a bracket to an engineer buddy to have it drawn up and a FEA done on it.
I am Savvy
View Post
...I am the designer, developer, and supervise the testing and evaluation...
-Intermission-
...nor does it mean I haven't sent a bracket to an engineer buddy to have it drawn up and a FEA done on it.
-Intermission-
-JeepFund
ΞlllllllΞ
It's ok, let him go. He just built a bracket.
View Post
i didn't drop off a drawing, i dropped off a knuckle, caliper/bracket, unit bearing and rotor with an air pressure line adapter. We clamped the caliper in place, oriented it for the high point on the bleed screw and then he started generating the program and drawing in cad to make the part. If you can do all that in a couple of hours, we really need to talk.
2005 Silver LJ
View Post
blaine and anyone else from Savvy, needs to be very careful when testing that bracket, you stop too quickly and Dale's head will be up your ***.
Support Our Troops!
JFI Member #7: Support Our Troops!
BESRK Rear Bumper, Hella 500s
Tags |
aluminum , brake caliper bracket , centeric premium calipers , savvy , vanco super 17 |
Previous Thread
Next Thread
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Similar Threads | ||||
Thread | Thread Starter | Jeep Forums | Replies | Last Post |
Rhino Lining inside of jeep? Worth 6-800 bucks? | dfaircloth88 | TJ Wrangler Technical Forum | 42 | 02-01-2012 05:23 AM |
Is the Atlas 4-speed worth an extra thousand bucks to you? | MattTheMudder | TJ Wrangler Technical Forum | 9 | 05-08-2010 10:28 PM |
127-130....104-105 is it worth 50 bucks? | slowassjeep | TJ Wrangler Technical Forum | 12 | 09-19-2005 05:47 AM |
Brand New but with 4000 bucks worth of damage. | Ol'Blue Jeep | TJ Wrangler Technical Forum | 35 | 08-27-2005 10:26 AM |
s3t worth the 500-600 extra bucks over the 3t? | UNCCPikeTJ | TJ Wrangler Technical Forum | 1 | 07-19-2003 11:39 PM |
Posting Rules | |
