06 TJ 02 Sensors ALL show Codes P0032 P0038 P0052 P0058 - JeepForum.com
post #1 of 7 Old 07-16-2015, 01:36 PM Thread Starter
stmerc
2006 TJ - Started with a check engine light and a code for only 1 Oxygen sensor, which got replaced, code was reset and the check engine light went out.
3 weeks later the check engine light is back on and Now ALL 0'2 Sensors show Codes: P0032 P0038 P0052 P0058.
An initial look found one of the battery cables cracked, now replaced. Check engine light went out. Started the JEEP a few times and light remained out. On about the 6th time, check engine light came back on - still showing all the codes for the O'2 sensors (Heater Checks High - All 4).
Has anyone got any ideas short of replacing the PCM?
stmerc is offline
post #2 of 7 Old 07-22-2015, 10:38 AM Thread Starter
stmerc
PCM (ECM) It is then....
stmerc is offline
post #3 of 7 Old 07-22-2015, 10:39 AM Thread Starter
stmerc
stmerc is offline
post #4 of 7 Old 07-22-2015, 05:19 PM
bonza
ground G105 is common to the heating circuit for all four O2 sensors
its located near the left engine mount according the the FSM, yet a diagram for the grounds in the same manual show it somewhere near the oil filter on the right hand side
2005 TJ Light Khaki
bonza is offline
post #5 of 7 Old 07-22-2015, 08:35 PM
3X4X4
Before you get too advanced, have you performed SL 25-001-07?
Does your CEL, key on, no start, flash after 15 seconds for 10 seconds before going back solid?
J
3X4X4 is offline
post #6 of 7 Old 07-23-2015, 01:12 AM
bonza
J
is that what this thread about? https://www.jeepforum.com/forum/f9/02...d-try-1447579/
2005 TJ Light Khaki
bonza is offline
post #7 of 7 Old 07-23-2015, 09:29 PM
3X4X4
Yes.
I would perform the bulletin first because it changes the ground path I do believe. In any case it completely cured all manner of O2 sensor issues I was having, COMPLETELY!
It might not be your issue but do the easy things first and the bulletin needs to be done either way.
J
3X4X4 is offline
2006 , ecm , oxygen , pcm , tj
