'01 TJ Death Wobble - JeepForum.com
post #1 of 8 Old 12-18-2014, 10:33 AM Thread Starter
JeeperLink
'01 TJ Death Wobble
I have an '01 2.5L TJ with 32" tires and 2" lift. I bought it like this and it seems that it has all stock suspension. All they did was to put spring spacers to get the lift. I was lied to by the dealer and I should looked closer..
Anyway, at 40mph up to 45, I have wobble in the front. It's not terribly bad after looking at some videos of others. But it's still annoying. I have put the Jeep on jack stands and turned the steering lock-to-lock and find no play in any of the joints. I have also taking out the track bar, and steering stabilizer and have not found any wear on the bushings or rubber. The stabilizer shock is stiff and no leakage. I have noticed that it feels like it's coming from the left front. So I checked to see if there was any play in the wheel bearings on both front tires, and there was none.
I am at a total loss as to where the wobble is coming from. Please note that I am a mechanic. I have built and raced cars for the 13 years. I will admit that I don't have much experience with 4wds. The only thing that I have NOT done was to rotate the tires. I will be doing that this evening..
Any advise would be greatly appreciated.
Jeep Registry: https://www.jeepforum.com/forum/showt...2#post27209562
Specs (if you don't want to click the link):
2.5L - stock
ax-5 Tranny
231 transfer case
Dana 30 on the front
Dana 35 in the rear
JeeperLink is offline
post #2 of 8 Old 12-18-2014, 11:53 AM
Shark_13
When you do the dry steer test, the tires need to be on the ground, not on jack stands.
Just go back & forth a 1/2 turn, no need for lock-lock. Feel the tie rod ends for play, and watch both ends of the track bar for any type of movement.
What is your tire pressure set to? last time balanced & rotated? toe in?
Shark_13 is online now
post #3 of 8 Old 12-18-2014, 12:11 PM
biffgnar
biffgnar's Avatar
If just a slight wobble, not full DW, check tire balance.
biffgnar is offline
post #4 of 8 Old 12-18-2014, 05:38 PM Thread Starter
JeeperLink
Thanks for the replies guys. Yea, I was thinking tire balance as well. But, before spending money on this issue, wanted to cross out a few off my list.
I did steer it left to right before I put it on stands. The right front has very little play in it (I would say, less than a millimeter). The left front, none.
Pressure is set to 22lbs, any higher then it feels like I don't have any suspension.
post #5 of 8 Old 12-19-2014, 06:10 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
Most speed dependent wobble when moving in a straight line, is tire balance issues if it happens nearly 100% of the time that you are driving in that particular speed range.
Necromancer_tat is offline
post #6 of 8 Old 12-19-2014, 10:30 PM Thread Starter
JeeperLink
Yea, tire balance is where I am leaning towards as well. Just made a 5 hour round trip with it (longest trip so far) and my back is killing me. But, I will have the tires balanced, probably after Christmas.
I am planning on upgrading the tire rods and arms with a ZJ set, but that's a different thread.
I will also update this thread whenever I do find the culprit of the wobble, so hopefully it will help someone else!
Thanks!
post #7 of 8 Old 12-20-2014, 05:31 PM Thread Starter
JeeperLink
Rotated the tires in an X pattern and everything went away. No more wobble or vibration. Had it up to 60 today and feels like I'm riding on a cloud, in comparison to what is was before.
post #8 of 8 Old 12-20-2014, 09:39 PM
Shark_13
Gotta love the easy cheap fixes
death wobble , shaking , shimmy , tj
