Loose ball joint castle nuts - JeepForum.com
post #1 of 4 Old 10-21-2021, 11:57 PM Thread Starter
CarJunkie
We are hearing the tell-tale clicking. How many of you have had this issue corrected? I plan to do it myself.
CarJunkie is offline
post #2 of 4 Old 10-22-2021, 12:13 AM
Vinman
I had the drivers side click a bit but after tightening up both joints on that side and havenít heard a sound since
Vinman is offline
post #3 of 4 Old 10-22-2021, 02:26 PM Thread Starter
CarJunkie
I just bought 4 cotter pins (1/8”x2”) from Lowe’s and will check all 4 later today or tomorrow. I’d rather make sure they are all properly torqued.
I’ll set the tops to 55ft-lb, bottoms to 33ft-lb, then tighten each to the next face that lines up for the cotter pin.
I have a lift, and probably won’t need to remove the wheels since they are 0 offset and give pretty easy access. This should take less time than driving to the dealer and back…..but still pretty annoying on a brand new rig. This issue dates back to 2018, there is a TSB for the problem, and yet they continue to leave the factory this way. Crazy!
post #4 of 4 Old 10-22-2021, 05:30 PM
ravenworks
ravenworks's Avatar
Loctite as well should be used
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
