Beadlock questions - JeepForum.com
post #1 of 5 Old 07-30-2021, 08:58 PM Thread Starter
Blu3rav3n
Beadlock questions
Hello Jeepers!
It has been far too long but I am finally back and with a a fancy new JLU Rubi. SO down to my questions.
I am either going with the ICON 2.5 stage 2 or 3 lift, or the Dynatrac EnduroSport 2.5 lift. Undecided at the moment but pretty sure I have narrowed it down to one of those. Now with those lifts in mind, I am looking at these 2 options for beadlocks....assuming they fit and the Blackrhinos are actual BL's from the link provided.
https://www.tiresandwheels.com/produ...6&c-vid=306828
https://store.mopar.com/oem-parts/mo...bC12Ni1nYXM%3D
Will either of those work? What is your experience with either of them if any? If I am running 37's Discoverer STT Pros, what is the tire size I would need ( pretty sure it would be 37X13.50R17LT 121Q but I could be worng) Will there be enough backspacing or will I need spacers? Anything I'm missing?
Thanks,
Its a 99 TJ Build is all!
Blu3rav3n is offline
post #2 of 5 Old 07-31-2021, 04:34 AM
jklastinger
I have the Mopar wheels, which can be made to be a true Beadlock. I am running 37x12.5x17 Toyota’s with 3.5 inches of lift and no issues.
Sent from my iPhone using Tapatalk Pro
jklastinger is offline
post #3 of 5 Old 08-07-2021, 06:34 PM Thread Starter
Blu3rav3n
What do you mean can be made a true beadlock? Is there 2 different models of that rim? One a simulated and one a beadlock?
What lift are you running? Nice rig too btw.
Thanks
post #4 of 5 Old 08-08-2021, 07:51 PM
jklastinger
Beadlock questions
The ring can be used as a Beadlock or as a beauty ring like I am using it as, just a matter of how it is installed.
Running 3.5 inch Metalcloak. Thanks.
post #5 of 5 Old 08-10-2021, 07:38 PM
Tango.
That is not completely correct.
You can use the same Mopar Wheel and mount it as a beadlock if you order the BEADLOCK Ring part # P5160154 which is different than the beauty ring it comes with.
I have the Mopar beadlock wheels also..
Life is hard-John Wayne
Tango. is offline
