2020 JL 3.5 lift kit recommendations!! - JeepForum.com
 1Likes
post #1 of 20 Old 08-13-2020, 02:22 PM Thread Starter
kkuamoo
Looking for a 3.4-4 lift kit for my 2020 jl. Wont be doing any extreme off roading but like the moderate trails.
Which do you recommend? rough country? teraflex? jks?
kkuamoo is offline
post #2 of 20 Old 08-18-2020, 10:48 AM
cranbiz
cranbiz's Avatar
Teraflex, JKS, Metalcloak. I wouldn't touch a Rough Country setup with a 50' pole.
02 WJ Laredo, heavily optioned but stock
12 JK, 3.5" Teraflex/Franken lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #3 of 20 Old 09-16-2020, 07:50 PM
WestTX
Cactus Hobbit
WestTX's Avatar
I have my eye on the TeraFlex if I upgrade to the JL.
2021 JLU Rubicon Bright White EcoDiesel
If you eat, drink, or wear cloths then your involved in agriculture.
WestTX is offline
post #4 of 20 Old 10-09-2020, 08:52 AM
Rancho_Lifts
Vendor
Rancho_Lifts's Avatar
3.5" left
2" right
Both a Rubicon, both on 37" tires.
I like sharing this picture so folks can have a good idea.
I prefer the 3.5" personally.
Good luck!!
Critical9 likes this.
Rancho_Lifts is offline
post #5 of 20 Old 10-17-2020, 06:59 PM
wilderside42
wilderside42's Avatar
Rock Krawler is a good one to check out too. I went with the 2.5” adventure series kit and I’m pretty happy with it. I installed it a few days before I got my wheels and could not tell a difference in the way it rode vs factory. Once I got my wheels and tires it became stiffer I’m guessing because the tires have much stiffer sidewalls.
Sent from my iPad using Tapatalk
wilderside42 is offline
post #6 of 20 Old 10-18-2020, 07:05 AM
Axhammer
Axhammer's Avatar
What size tire, and load rating did you go with?
Why do I own a CJ? I like to “Balance the wrench and the steering wheel”
1985 CJ-7 Sebring Red, White hardtop, 284 CID inline six (4.7) TF 999 auto
2020 JLU Black, Black hardtop, EcoDiesel, 35’s on 2” Mopar lift
View my Pontiac in my profile
Axhammer is offline
post #7 of 20 Old 10-18-2020, 07:19 AM
wilderside42
I put on Nitto Ridge Grappler 35x12.50R18LT 128q 12p.r.
I know that’s a 12 ply tire. It changed the ride significantly but I’m not sure you can get that tire in a softer load can you? Honestly I never payed attention to that when I ordered them.
post #8 of 20 Old 10-18-2020, 07:42 AM
Axhammer
Axhammer's Avatar
Yeah, that’s basically a load range E tire. I’m planning on a load range C tire for my JLU. The ones I wanted are on back order, so I’m stuck running the stock tires for now. I like tire size.com for tire shopping, it has a lot of good info if you spend a little time looking at different sizes & brands.
https://tiresize.com/chart/
Axhammer is offline
post #9 of 20 Old 10-18-2020, 08:07 AM
wilderside42
That site does have a ton of info. It says my tires are F load rating on there and appears to be the only option in that size/model. I picked that tire based on the tread pattern and never considered the load rating. Just curious, what tire did you pick that was a C rating?
post #10 of 20 Old 10-18-2020, 09:29 AM
Axhammer
Axhammer's Avatar
I like Toyo tires, so I figured a set of Toyo all terrain tires would work for the first couple years of daily driving my new JLU. I am not planning on a lift for a couple years so I don’t void the warranty. I want the largest tires that will work OK without a lift. 285/75-17’s will fit the OEM wheels, and spare tire carrier. At 33.9” tall they will provide the appearance I am looking for, over the stock 32” street tread Michelin’s. The local shop where I buy my tires from couldn’t get them last month, but I’m going to call them this week and have them check again. I know I could get them online, but I try to spend money locally as much as I can for some stuff.
Axhammer is offline
post #11 of 20 Old 10-18-2020, 09:31 AM
Axhammer
Axhammer's Avatar
One good thing about running 12 ply tires is, I doubt you will get many flat tires.
Axhammer is offline
post #12 of 20 Old 10-18-2020, 12:02 PM
wilderside42
Yeah I like Toyo tires as well. I’m pretty sure Nitto and Toyo are technically the same company. I run Toyo Proxes II on my Chevy Avalanche and love them. I probably would have got Open Country ATs this time if the Ridge Grapplers hadn’t caught my eye. My old JK had Nitto Terra Grappler AT2 on it and they were bad to pick up rocks and sling them out at 60mph and I figured Open Country’s ATs would be the same.
post #13 of 20 Old 11-05-2020, 09:00 PM
jklastinger
Here is my 2020 Rubicon with Metalcloak 3.5 inch lift and sitting on 37’s.
Sent from my iPhone using Tapatalk Pro
jklastinger is offline
post #14 of 20 Old 11-06-2020, 04:22 AM
Axhammer
Axhammer's Avatar
Beautiful rig! What engine do you have? Did you regear for the 37’s? I’m not sure if 411 would be enough gear for 37’s. Maybe it would work better with the new 8 speed automatic. I love the lines of the JLU with a hardtop.
Axhammer is offline
post #15 of 20 Old 11-06-2020, 05:04 AM
jklastinger
Thanks. 3.6 auto with 4.88 gears. 35’s with the 4.11’s was okay. Would not do 37’s without regearing. Love the combo.
