2020 Jeep JL Hitch Install Bracket issue - JeepForum.com
post #1 of 8 Old 06-06-2020, 04:16 PM Thread Starter
jameskjeep
2015 JK Wrangler
Cool 2020 Jeep JL Hitch Install Bracket issue
So I bought a new 2020 Jeep JL Rubicon with the steel bumper package, But mine did not come with a hitch. I bought the Mopar hitch and ever video on you tube made it look easy as ****. Just 4 bolts and I'm good to go. Well I look under my bumper and I see two bolts installed holding up what looks like a steel plate between the frame and bumper. I removed the two bolts and can not get that plate to come out. Do I have to remove my whole bumper to get that plate out? I take it that I do not reuse that plate once I have the hitch installed. Anyone know how to remove that plate?
2005 Black Jeep Wrangler X 6 speed
Python Security System With remote locks
7 Speaker sound system + 2 12" MTX Thunder 6000 Subs
1.25 JKS BL
2.5 OME HD Sup Lift 1 inch JKS MML 32" BFG MUDDS
MT Classic 2 15x8
jameskjeep is offline
post #2 of 8 Old 06-07-2020, 02:03 PM
Pokey02
Should just be the 4 bolts for the hitch. I have the steel bumper and tow hitch. I just removed the rear bumper to install a GenRight. Here's pics of the tow hitch after the bumper is removed (ignore the loose bolts...the GenRight bumper is a tight fit)
19 JLR - Mopar 2" lift, 37" Copper STT Pros
13 10a JKUR - Metalcloak 2.5" lift
Pokey02 is offline
post #3 of 8 Old 06-12-2020, 12:50 PM
Jonesie
1981 CJ5
This may be a dumb question, but have you checked the install instructions?
https://www.imagesmartdealer.com/mop...t/K6862551.PDF
Jonesie
1981 Jeep CJ5
Working on a 360 V8, T-176, D300 Swap
Jonesie is offline
post #4 of 8 Old 06-13-2020, 01:16 PM Thread Starter
jameskjeep
2015 JK Wrangler
Yes I did and just like the instructions you posted they came in another language. As you can see at the top of page two that's the plate I'm talking about. I guess that means I do need to take my whole bumper off and just throw away that plate?
1.25 JKS BL
MT Classic 2 15x8
post #5 of 8 Old 06-13-2020, 02:53 PM
Jonesie
1981 CJ5
I just took delivery of my 2020 JLUR on Wednesday. I'll head out and see what it looks like under the rear bumper.
Jonesie
1981 Jeep CJ5
Jonesie is offline
post #6 of 8 Old 07-02-2020, 03:58 PM
morph860
My Ď19 Sahara had that plate as well. Took me a while to figure it out. Almost gave up. I ended up using a crowbar to move it out of place far enough to squeeze the hitch in between.
Edit - the directions for mine didnít say to take that plate out. Just to move it a bit to get the hitch in between it. Maybe itís different with the steel bumper.
morph860 is online now
post #7 of 8 Old Yesterday, 11:13 PM Thread Starter
jameskjeep
2015 JK Wrangler
Yeah I think you are right I just reuse it. Did you have to remove your whole bumper to get it in between the frame and the plate?
1.25 JKS BL
MT Classic 2 15x8
post #8 of 8 Old Today, 04:54 AM
morph860
No. I took the 2 bolts out that went through that plate. The ones you reuse to install the hitch. And I had to remove 2 other small screws. After that, used a pry bar to move that plate away from the frame far enough to get the hitch in. Took me a few tries. But after I got the plate at the right angle, the hitch went right in.
