WTFrick!? - PO dash wiring nightmare. Fire/instrument hazards? - JeepForum.com
 16Likes
post #1 of 72 Old 02-02-2020, 11:54 PM Thread Starter
uw91
uw91's Avatar
Went in for the LED upgrade and windshield weld nut update and saw something that looked very unoriginal, and a bit worrisome. I saw some bird's nests here and there and ultimately duct tape just peeking out from electrical tape that was wrapped around the wiring as though it were to be a factory harness. Seeing this I said, 'Whelp.... when in Rome... remove the electrical tape and send your anxiety and frustration through the Colloseum'. Why in the name of Odin would someone duct tape wires?
I removed all the electrical tape and zipped the wires together as to not lose track of them. Once done I tackled the duct tape, and holy mother; the PO duct taped 2 12-gauge (I believe they are that size) wires together in crap connectors that split out to 3 wires. How is this not a fire hazard? I do not believe these go to a specific fuse but directly to the fuse box, which now has me worried that you are adding power to a 3rd line that could over-power that specific instrument. This is done on a few occasions as you can see in the photos.
Is this the proper route? (Minus the duct tape) Take 2 wires, merge them together and have 3 wires lead out from them?
Any idea what some of these connectors are from the plug type?
I believe one connector is from an old trailer hook up, as it ties into the light switch.
I have AC, tach, clock... though it does look like they installed an aftermarket tach. (Blue gauge, left side of 5th pic)
Anyways, thanks for the eyes and I'm really glad my curiousity got me on this one bc I have a feeling that things could have turned out ugly. I also never knew that wrapping duct tape around your connections and then electrical tape around all the wires was the route to go. Always thought it was the other way around.
IMG_20200202_144036.jpg   IMG_20200202_144450.jpg   IMG_20200202_144604.jpg   IMG_20200202_223207.jpg   IMG_20200202_142933.jpg
PNW Represent
uw91 is offline
post #2 of 72 Old 02-03-2020, 01:30 AM
whollsee
1982 CJ7
Believe it or not, duct tape was actually factory!!! The chunk you show may not be though...
uw91 likes this.
When ever I hear the word 'Jeep' I reach for my wallet.
whollsee is offline
post #3 of 72 Old 02-03-2020, 03:42 AM
John Strenk
John Strenk's Avatar
1976 CJ5
The Tach looks factory. Although the speaker does not.
This looks like the plug for the factory fog lights
This looks like the connection for the 4 cyl tach. Is that yellow wire cut?
If those were at 90* apart, I would say this is for the turn signal flasher.
Yes "Duck tape" was used in the original harnesses. Something about temperature rating of black electrical tape wasn't high enough to cover splices like that.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #4 of 72 Old 02-03-2020, 05:49 AM
shadoow
As a side note be aware that the factory tach is part of the ignition circuit. If the tach goes bad or is just removed your engine will not run. If you want/need to remove the tach you disconnect the 2 wiring harness connectors going to the tach then connect those 2 wiring harness connectors together so you end up bypassing the tach unit and still have the ignition system functional, like a jeep that came without a tach from the factory.
uw91 likes this.
shadoow is offline
post #5 of 72 Old 02-03-2020, 09:12 AM Thread Starter
uw91
uw91's Avatar
---- The speaker was my install
----That would make sense. They had aftermarket KC fog lights installed.
----The wire is cut, yup. (I have a 6 cyl)
----Isn't the turn signal flasher on the fuse box? I see the other square flasher (I think that is it) that is from the wire harness.
----That's crazy and funny at the same time. I guess my biggest worry was the joining of wires in the manner they did.
Thank you for the notes. I guess I need to track down every splice to see where in the heck it goes because I have at least 6 free connections. If they left open connections based on packages, engine type, etc. that'd make sense, but this looks a little strange to me.
PNW Represent
uw91 is offline
post #6 of 72 Old 02-03-2020, 10:34 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Welcome to scary world of factory CJ wiring. I was shocked the first time I looked at the rat's nest of wires behind my dash. Fortunately, everything still works on mine, so I've left well enough alone.
The duct tape throws a lot of guys off, but that is in fact how they did it at the factory. You'll find a few of those spliced duct taped connections in your engine harness, as well.
Good luck,
Matt
Matt1981CJ7 is online now
post #7 of 72 Old 02-03-2020, 10:34 AM
jimdavis577
Jeeper for life
jimdavis577's Avatar
1979 CJ5
Yes AMC was known to use Duct Tape as stated above, I have seen it multiple times throughout many jeeps. Also I would suggest If you dont have one.... Get the OEM wiring schematic as it will help you trace down the wires and where there should and shouldn't be splices/ connectors. Alot of times connectors are in place for options you may or may not have on your jeep. Actually your dash harness doenst look horribly molested as of yet ... I have seen and repaired ALOT worse than this .... When doing your repairs.... always try to inspect the connecting wires .... IF they are not clean and Copper in color ... then strip it until you do get to clean wire.... then make your connection there using solder and shrink wrap ..... after I make a connection I always coat the joint and exposed wire with Dielectric grease before shrink wrapping ... just to keep the wires from wicking any moisture into the insulation ..... but its not a necessity ....... good wiring habits and techniques will go along way with a proper running and functioning jeep !
John Strenk, 258 and Sparkybob like this.
79 CJ5, SBC, sm465/np205, Dana 60 axles, stretched and tubed
88 yj, SOA, AMC 304, dana 44 front and rear, on 35s
88 XJ, 4.0 all stock
2012 JKU, 4" inch lift on 35's , bumpers and winch, daily driver
jimdavis577 is offline
post #8 of 72 Old 02-03-2020, 10:59 AM Thread Starter
uw91
uw91's Avatar
Here are some more fun pics.
Are these splices factory? I guess; are the way they joined the wires factory connections? I don't know the name of those connectors, but some look correct. Thank you for any interpretations you have and I'll need to track down a wiring diagram for this. Here are more fun pics and please enjoy and throw out any IDs you may know. Hopefully this can help me and many others down the line.
PS: I guess one of my big worries is that when something is spliced together and then leads to an oil/battery gauge, can that cause faulty readings? I guess maybe if it isn't a ground wire?
PNW Represent
uw91 is offline
post #9 of 72 Old 02-03-2020, 11:09 AM
jimdavis577
Jeeper for life
1979 CJ5
When I get home from work, I will look at a couple harnesses I have in the shop and see if I can match/identify what you got going on there .... I have a few of these laying around I use for parts ..... Here is a dash I did awhile back
uw91 likes this.
post #10 of 72 Old 02-03-2020, 11:27 AM Thread Starter
uw91
uw91's Avatar
Thank you! I don't want you to slave around too much b/c I don't think I have many electrical issues I can't clean up and the gauges appear to be OK. But I'll take any help I can get in cleaning that up, wrapping it right, then never worrying about it again.
PNW Represent
uw91 is offline
post #11 of 72 Old 02-03-2020, 12:17 PM
John Strenk
1976 CJ5
I think these are grounds:
Are you sure? I think those go to the Dash Panel lights, the speedo only needs 3. ...
Accessory circuit splice.
But I wouldn't expect it there. There is a splice that comes from the Ignition switch and is spliced with one going to fuse box and one going to voltmeter.
1. Horn Relay
2&3 Can't see it well enough.
Not sure but there is no trailer tow plug. Thinking it might be for the hard top light harness. Never had one on any of my CJ's
Can't see the wire color on the smaller square but there was a plug for the Cigar lighter under there.
On an 84 CJ the turn signal flasher is behind the parking brake.
Only the emergency flasher is in the fuse box.
Here is one you haven't found yet.
Might be this one.
post #12 of 72 Old 02-03-2020, 12:31 PM
jimdavis577
Jeeper for life
1979 CJ5
Attachment 3886683
1. Horn Relay
Attachment 3886681
I believe this is the Fuel guage sending unit ..... is it not .... seems like I remember that and the tail lights in the same loom .....
post #13 of 72 Old 02-03-2020, 12:34 PM
John Strenk
1976 CJ5
Ah, I was thinking of the plugs with the Orange and black wires. Thinking it might be for the hard top light harness. Never had one on any of my CJ's
Yes, the other plug is for the tail lights and fuel gauge from the sending unit.
post #14 of 72 Old 02-03-2020, 12:38 PM
jimdavis577
Jeeper for life
1979 CJ5
well Shouldnt it be 5 wires for tail lights ...... R turn ... L turn .... Park .... Brake .... Reverse...... so that by default ... would meant the orange and black should be fuel guage ..... I hate not having access to my schematics .... LMAO .... I have all data ... so I have all of them and can compare yr by yr .... ITs soooooo nice having that !!! lol
post #15 of 72 Old 02-03-2020, 01:46 PM
Matt1981CJ7
1981 CJ7
John is correct, this is for the dome light on a hard top.
uw91, privately send me your email address, and I will send you a copy of the '84 Technical Service Manual wiring schematics.
Matt
