Wolff Steering Bearing - JeepForum.com
 3Likes
  • 1 Post By RARECJ8
  • 1 Post By RARECJ8
  • 1 Post By RARECJ8
post #1 of 9 Old 01-14-2020, 02:43 AM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
Done it? Any issues?
Since engine is out and am going with PSC parts, now is time to fix the slop. OEM bearing long ago shot. Presently use a borgeson shaft. It came off the box end but cannot get it off the intermediate shaft coming from firewall. Tried a can of pb blaster, no go. Disconnected shaft at the upper coupler and still no go. More blaster. It won’t budge.
I will eventually get it. For the Wolff part, any comments or snags u run into? Steering is the last frontier for this rig. Everything else has been touched numerous times. Except the steering gear box. Lasted since 1981, not bad. No leaks but a needed upgrade. Considered the H1 swap, but bit the bullet for all new PSC stuff. Off road design HD tierod and drag link with one ton ends all in place. Now just this pesky upper collar to remove. Holding up show. Also picked up more hd box mount.
Took delivery of this today. Looks well built and is far beefier than Oem stuff.
https://www.wolffeng.com/store/p2/M1...e_Bearing.html
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #2 of 9 Old 01-14-2020, 06:53 AM
skizriz
skizriz's Avatar
1978 CJ7
Been thinking on that bearing for mine. Think ive replaced it three times over the years, its due again.
skizriz is offline
post #3 of 9 Old 01-14-2020, 09:30 AM
Renegade82
Renegade82's Avatar
1982 CJ7
I installed one back in October of 2017. No issues so far, it was a great upgrade. I have some pics of the install on the top of page 51 of my build thread but it's pretty straight forward. https://www.jeepforum.com/forum/f8/3...0/index51.html
I had noticed a thumping / bumping kind of sound that I could feel in my steering wheel when I was on rocky un-maintained mountain roads. Almost like the column was knocking in and out. So I wiggled my new Borgeson shaft and got a little play. It was a new lower bearing kit from Crown that I had put in about 3,800 miles ago during the resto. Once I switched over to the new one it totally disappeared.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #4 of 9 Old 01-14-2020, 02:52 PM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
Nice. I am stuck getting the shaft off the splined end. This step:
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #5 of 9 Old 01-15-2020, 01:20 AM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
Got it in. Used a pickle fork to remove the old part. A chunk was broken off.
Renegade82 likes this.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #6 of 9 Old 01-15-2020, 01:22 AM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
New versus old steering gear.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #7 of 9 Old 01-15-2020, 01:23 AM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
Securing the spacers to new box mount.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #8 of 9 Old 01-15-2020, 01:00 PM
cpadget
cpadget's Avatar
1983 CJ7
Just a thought...have you looked at adding this MORE brace into your install? I added it when I did my H1, Borgeson swap.
cpadget is offline
post #9 of 9 Old 01-15-2020, 02:29 PM Thread Starter
RARECJ8
RARECJ8's Avatar
1981 CJ8
Yes I have one similar but stronger IMO. Issue is passenger side frame is busted where the brace attaches. Lots of stress transferred to other side. In process beefing up the numerous cracks. Sone were nearly 360 degrees around, at the mount also the sway bar and bump stop mount areas. Red engineering those mounts to be stronger and better txfr stresses.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
