Wiring Diagram - JeepForum.com
post #1 of 8 Old 01-29-2007, 12:02 PM Thread Starter
Dimension4
Guest
Wiring Diagram
I forgot my manual at home does anybody have a wiring diagram for an 1984 vintage CJ?
Dimension4 is offline
post #2 of 8 Old 01-29-2007, 01:50 PM
John Strenk
John Strenk's Avatar
1976 CJ5
That was split up into many segments. Which section do you think you need. ?
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #3 of 8 Old 01-29-2007, 02:08 PM Thread Starter
Dimension4
Guest
The section for the heat - blower motor. Thank you.
post #4 of 8 Old 01-29-2007, 06:32 PM
John Strenk
1976 CJ5
I have this but if you need the rest, I'll see what I have at work.
post #5 of 8 Old 01-29-2007, 07:19 PM Thread Starter
Dimension4
Guest
THANKS!!! I'll see if I can get it going. I was going to just run a switch from +12v to the fan, but this will be factory. I did the blazer blower motor upgrade. The original fan wasn't even wired up, and I tested it and it didn't work either
David
post #6 of 8 Old 01-30-2007, 08:32 AM Thread Starter
Dimension4
Guest
Well, I got it working bypassing the factory wiring harness, but using the factory switch. Does anyone have the diagram that shows the wires that go through the firewall (wiring harness)? If I can locate the factory wire I should be able to use the factory fuse and junction through the firewall.
post #7 of 8 Old 01-30-2007, 10:49 AM
John Strenk
1976 CJ5
Look for position "CY". A light brown wire.
post #8 of 8 Old 01-30-2007, 02:01 PM Thread Starter
Dimension4
Guest
Awesome, thanks a lot. It's working now!!
80 Wiring Diagram WayneMeuir Jeep CJ Forum 4 11-01-2009 12:44 PM
Wiring Diagram Chasebo Jeep CJ Forum 2 08-02-2009 01:54 PM
360 wiring diagram coyote7791 Jeep CJ Forum 3 08-05-2007 02:26 PM
ARB Wiring Diagram Aphelion79 Jeep CJ Forum 3 01-29-2006 10:35 PM
CJ-7 Wiring Diagram Esquilax Jeep CJ Forum 2 08-23-2004 11:12 AM
