Wire the bumper spot lights into dome light switch? - JeepForum.com
 4Likes
  • 2 Post By Renegade82
  • 1 Post By Jim1611
  • 1 Post By pedal2themetai
post #1 of 7 Old 10-17-2019, 10:20 PM Thread Starter
young jeeper
I don’t have a dome light and don’t usually have the top on anyway. I was wanting install some lights to the bumper and then wire them so when I click the light switch to where it would turn on the dome light, it would instead turn on the bumper lights.
Is this possible? I have seen the wiring diagram of what post the dome light ties into, I would essentially need to tie the relay into the power and ground of the dome light connection, right?
Chevy 350 carb
Muncie SM465
Skyjacker Softride 4" lift
young jeeper is offline
post #2 of 7 Old 10-17-2019, 11:06 PM
Renegade82
Renegade82's Avatar
1982 CJ7
Depends on what light you want to use. If you use some small LED lights the circuit could probably handle it. But if your going to use some type of incandescent lights then no. Now you could if you run another pair of heavy gauge wires back and use a relay, then trigger the relay with the existing dome light circuit switch.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #3 of 7 Old 10-18-2019, 06:19 PM Thread Starter
young jeeper
Yeah that was my thought with using a relay. The dome switch should be able to send that signal, right?
Is there any downside to doing it this way? I don’t want to mount switches in the dash and this seems like the cleanest way of doing so.
Chevy 350 carb
Muncie SM465
post #4 of 7 Old 10-18-2019, 06:50 PM
Jim1611
Jim1611's Avatar
Is there any downside to doing it this way? I donít want to mount switches in the dash and this seems like the cleanest way of doing so.
Triggering the relays with the switch takes very little amperage so it won't hurt the switch. I think the dome light switch takes care of the ground and not a hot wire. You also could mount a switch under the dash panel too, that way you avoid drilling re dash. I'd still run the lights on a relay though.
pedal2themetai likes this.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #5 of 7 Old 10-19-2019, 07:55 AM
pedal2themetai
1956 CJ5
HI AAHH I think when you turn the switch to turn on the dome lights doesn't it dim the dash lights Out. Might not be good for night driving..
I'd add a toggle switch to hang under the dash so no new hole visible
good luck
tim
trailhead2004 likes this.
pedal2themetai is offline
post #6 of 7 Old 10-20-2019, 09:42 AM Thread Starter
young jeeper
good luck
tim
The dome light comes on at the highest dash light setting. It does on mine anyway.
Chevy 350 carb
Muncie SM465
post #7 of 7 Old 10-20-2019, 10:00 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
good luck
tim
X2
A stand alone switch would be easy to rig up and you wouldn't run the risk of accidentally bumping the headlights off messing with the switch.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
