Wiper Blades - JeepForum.com
 1Likes
  • 1 Post By Techlight
post #1 of 15 Old 06-21-2021, 02:06 PM Thread Starter
Stormrider51
Newbie
Stormrider51's Avatar
Wiper Blades
Folks, I've got a bit of a mystery. I purchased a 1979 CJ7 and it needs new wiper blades. The problem is that the ones the parts books say are correct don't fit. The Jeep was restored some years ago and I suspect an older type of arms and blades were used. I'm attaching a photo of the ones on the Jeep. Can anyone I.D. them so I don't spend more money on something that doesn't work? The arm slides directly into the blade and removal requires pulling outward on a tab on the distal end.
John
ADDED PHOTO OF WIPER ARM.
Life is an adventure. Don't miss it.
Stormrider51 is offline
post #2 of 15 Old 06-21-2021, 02:28 PM
Techlight
Looks like a Trico classic would fit it...but can't say on what size. Should be able to walk into any parts store and have them take a look and measure. When removed is the arm a straight style or a U style?
,[_____],
_-o||||||||o-_
()_)ŻŻŻŻ )_) 1984 CJ7 Renegade, 4.2L-TBI, D30, AMC20, 4.5" OME lift
Techlight is offline
post #3 of 15 Old 06-21-2021, 03:39 PM
ravenworks
ravenworks's Avatar
Probably 13"
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #4 of 15 Old 06-22-2021, 04:38 AM
keith460
keith460's Avatar
Jeeps are the hook type blade and 11" in length. Same type used on Volkswagen Beetles.
Edit: They are not hook, my bad. Definitely the bayonet type.
1984 CJ-7 Renegade
keith460 is offline
post #5 of 15 Old 06-22-2021, 06:23 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Keith, or anyone.
Who makes the best replacement blades for a CJ? The ones I purchased are junk.
Thanks and sorry for the hijack.
Matt
Matt1981CJ7 is offline
post #6 of 15 Old 06-22-2021, 09:50 AM
Techlight
Originally Posted by Matt1981CJ7 View Post
Keith, or anyone.
Matt
Keith probably has a better answer ....but no surprise there. Guy is a walking Jeep encyclopedia.
Out of all the brands I've tried I've always liked Trico ...they seem to fit the best, hold up well, and the classics look stock. However, I'm in the desert so I get one winter out of them and then they bake all summer. Rain-x is your friend on this one too.
Matt1981CJ7 likes this.
,[_____],
_-o||||||||o-_
post #7 of 15 Old 06-22-2021, 12:13 PM
Fourtrail
1974 CJ6
The last time I replaced the wiper blades on the one CJ that has working wipers.... I just bough the basic style wipers and removed the blade from the new ones, cut to the correct length, opened up the crimp on the CJ's wipers, slid in the good quality replacement blade and then crimped it back down. Seems to be working for the last few years.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #8 of 15 Old 06-22-2021, 12:35 PM
258
258's Avatar
I buy 22" replacements and cut them to size; 11". I have bought ANCO U-22R, ACDelco 18-22RFW and they both worked out fine. Cheaper to cut them to size, PLUS you end up with 4 blades for down the road replacement.
258 is offline
post #9 of 15 Old 06-22-2021, 04:08 PM Thread Starter
Stormrider51
Newbie
Added photo of wiper arm.
post #10 of 15 Old 06-22-2021, 05:24 PM
hp_lovecraft
1981 CJ5
Every CJ I've ever owned used bayonet-style wipers, not hook.
THe picture above is the correct wiper blade and arm.
The bayonet end of the wiper arm pivots into that center hole on the wiper blade. and its just held in by the spring tension of the wiper arm.
and those are the nice wipers. Its hard to find those types around here. Usually I just see the junky anco "universal" style that has a cheap plastic adapter for the bayonet mount. junk
hp_lovecraft is offline
post #11 of 15 Old 06-22-2021, 05:28 PM
keith460
keith460's Avatar
I have to agree on the Trico brand and usually get them from NAPA or Amazon. But have to admit, my CJ is never out in the rain so I probably still have the same Trico wiper blades I bought in 2009.
1984 CJ-7 Renegade
keith460 is offline
post #12 of 15 Old 06-22-2021, 05:30 PM
keith460
keith460's Avatar
That's right, my bad. I meant bayonet and have no idea why I mentioned hook type.
1984 CJ-7 Renegade
keith460 is offline
post #13 of 15 Old 06-22-2021, 06:13 PM
hp_lovecraft
1981 CJ5
That said, there is the holy grail of a modern rear window wiper arm that will bolt-on replace the CJ wiper arms, so you have a better variety of wipers blades.
That said, I keep my windshield rain-x'd, so the wipers are not really an issue.
Years ago, I added washers to the linkage, and a larger blower for the defrosters.... and I can safely drive in a snowstorm.
post #14 of 15 Old 06-23-2021, 07:40 AM
bob4703
1974 CJ5
I've tried several brands and found none of them work well. I keep new ones on it to keep Barney Fife happy. Barney refuses to believe that I don't drive in the rain and that RAINEX works better. We did compromise. He insists on wipers and I don't have to have muffler.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #15 of 15 Old 06-24-2021, 09:10 AM Thread Starter
Stormrider51
Newbie
Problem solved. I opened the tabs on the old wipers, removed the worn out blades, and then installed the new ones. Many thanks for the help.
John
