Wiper arm and blade upgrade for CJ - JeepForum.com
 2Likes
  • 1 Post By CrustySprings
  • 1 Post By momo2
post #1 of 10 Old 04-15-2021, 05:32 AM Thread Starter
pamola
Hey all, I am in the never ending process of upgrading my 83 CJ7. I would like to replace my stock wiper arms and wipers with something more stout. No interested in the wiper boy modification at this point, was just wondering if anyone has removed the old wiper arms and replaced them with a sturdier wiper arm from another vehicle. My stock wiper arms are so cheezy. Would Yj arms possibly fit? Was thinking of taking an arm to the auto parts store to see if they could match it up with something else.
pamola is offline
post #2 of 10 Old 04-15-2021, 07:55 AM
bob4703
1974 CJ5
There was a thread here a few years back about modifying the rear glass wiper arm from a Ford Escape. I remember that because we have an Escape that I've never used the rear wiper so I'll only have to hunt one. Google is your friend.
Then I rediscovered Rainex!
Paved roads are prime examples of government over spending!
bob4703 is offline
post #3 of 10 Old 04-15-2021, 08:23 AM
Renegade82
Renegade82's Avatar
1982 CJ7
Here was my solution to using newer aftermarket arms and blades. https://www.jeepforum.com/forum/f8/3...0/index54.html See post #804
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #4 of 10 Old 04-15-2021, 04:21 PM
schardein
schardein's Avatar
1983 CJ7
CJ and YJ wiper arms don't interchange. The drive head of the YJ is larger. YJ on the left, CJ on the right. The windshield frame in this picture is a YJ. I run a YJ tub, with YJ w/s frame, so YJ wipers.
1983 CJ7, 5.3, NV3550, D300 4:1, Fr D44 Ox air, Rr D44 OX cable, 4.56, 35" Falken A/T3W on beadlocks
schardein is offline
post #5 of 10 Old 04-15-2021, 09:51 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
In the past I have walked through Auto salvage yards and snatched various arms off of various vehicles----old and newer.
I found the CJ arms to work fine------if you replace the spring with one a little shorter, even bend a new hook on one that will fit in the arms width (springs come in different widths)
schardein's pic above will show what I'm saying.
Recently I bought some black arms from Kaiser Willys for my '77 CJ-5---I like them!----I will be getting springs to make them hold down a little tighter too!
https://www.kaiserwillys.com/black-w...-fits-76-86-cj
----JEEPFELLER
JEEPFELLER is online now
post #6 of 10 Old 04-15-2021, 10:39 PM
KevinCJ7Jeep
KevinCJ7Jeep's Avatar
1981 CJ7
One of my wiper arms over rotated and got hung up, bent and cracked the windshield frame. I converted to YJ wiper arms/blades. You have to enlarge the wiper arm post holes and use YJ wiper arm/blades and the YJ wiper arm linkage. The CJ motor is still used. The YJ arms and linkage are larger and should hold up better.
KevinCJ7Jeep is offline
post #7 of 10 Old 04-16-2021, 08:17 AM
CrustySprings
See if this helps...
https://www.jeepforum.com/forum/f8/m...-arms-3957642/
I did this mod and really like the wipers now. The only thing I changed is that I did not use pop rivets. I used a blind fastener I found at Home Depot.
bob4703 likes this.
258 cu. inch six, Team Rush ignition upgrade, T5, Dana 300, Superwinch lockouts, Black Diamond 3" suspension lift, greasable shackles, poly bushings, JKS quick discos, 32x11.50x15 Cooper STT's, American Racing 23 15x8 alloys, Uniden Pro 520XL CB radio, 2' adjustable tip Firestick antenna, Viair 460 onboard air system
CrustySprings is offline
post #8 of 10 Old 04-16-2021, 01:33 PM
momo2
1980 CJ7
No need for such a big hack. The anco arms are much stouter and you can even fit the upper part of stock arms in there
https://www.rockauto.com/en/catalog/...wiper+arm,8848
Gesendet von meinem SM-G950U mit Tapatalk
John Strenk likes this.
momo2 is offline
post #9 of 10 Old 04-18-2021, 06:50 PM Thread Starter
pamola
Thanks for all the great options to upgrade my wipers. I will start with the trico 37-111's first and go from there.
pamola is offline
post #10 of 10 Old 04-18-2021, 09:36 PM
Rondawg80
1980 CJ5
I bought arms and blades for the rear of a 2006 ford escape. I saw a thread somewhere on this, and it worked out really well. You just replace the ford splined socket with the one for the jeep.
I made the right thickness washers to center the arm on the socket. (you could just stack a couple of washers on each side) works Perfect! and I can get replacement blades just about anywhere.
Rondawg80 is online now
