Windshield Lightbar Wiring Routes for CJ7 - JeepForum.com
post #1 of 3 Old 05-24-2020, 08:06 AM Thread Starter
treythompson
Anyone have good suggestions on where to tuck a 50ā€ light bar wiring coming down the windshield and ultimately needing end up in the engine compartment?
Iā€™m mounting a 6 switch bank under the hood and then a single wire will run to a 6 position rocker witch inside the cab.
Thanks for any feedback
treythompson is offline
post #2 of 3 Old 05-25-2020, 04:03 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
You can drill a hole in the windshield frame and feed it down through the cavity to behind the dash pad. If you lower the windshield you can then feed the wires down where the wiper harness is, down to the firewall and through. You can buy grommets at electrical shops and i would touch up bare metal. You need some local slack near the top of the cowl so you can lower the windshield.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 3 Old 05-25-2020, 06:28 AM Thread Starter
treythompson
Thank you for the ideas.
