Will YJ Hard doors fit 80 CJ7 - JeepForum.com
 4Likes
  • 3 Post By ECJ-7
  • 1 Post By Mister4x4
post #1 of 7 Old 10-20-2021, 12:01 PM Thread Starter
CoachBC
CoachBC's Avatar
Was wondering if the doors off a YJ or any other jeep model fit a 1980 CJ 7
CoachBC is offline
post #2 of 7 Old 10-20-2021, 12:09 PM
Fourtrail
1974 CJ6
IIRC the changover date for the CJ-7 was in 80 went they from the striker plate to the nader bolt, if you have the nader bolt, they will go right on, if you don't, then you would need to update the door striker to the nader bolt for the yj doors to work on your cj-7. nothing newer than a YJ will work on a CJ-7
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
post #3 of 7 Old 10-20-2021, 11:50 PM
Renegade82
Renegade82's Avatar
1982 CJ7
The hard door shells are about the only Jeep part used on the new Wrangler model. The problem is, as was said above, they were the same as the last Jeeps were and those 81 1/2-86 used a mounted striker post for the paddle handle doors. What may be different is the B pillar that these mount on. I'm not sure what year they added this pillar in place of the horizontal angled brace.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #4 of 7 Old 10-21-2021, 12:22 AM
RedNeckCorvette
1979 CJ7
The half doors would not fit my CJ-7 due to the thickness of the plastic, on the interior of the doors. They hit the roll bar so hard the doors were 4'' - 5'' open to the outside of the latch. I lost interest for some time now.
RedNeckCorvette is offline
post #5 of 7 Old 10-21-2021, 01:44 AM
Mongo228
Mongo228's Avatar
1980 CJ7
I can't say much on the full doors, but the half doors can be made to work. I know the YJ hard top will fit on a 1980 CJ7 (look up Mister 4x4's CJ7 ... I helped him mount the hard top). So, logically, it would follow the doors, with some modifications, will fit.
We tried to get these striker adapters to work; they sorta did, but not really.
What I wound up doing was cutting out the angled supports from the wheel house to the back of the door frame, and installing YJ B-pillars. You can see what I did here.
Dunno if you have your heart set on the change, but there are a couple of options for you to try. May be others.
Luck to you!
Dave
Mesa, AZ
"Grinders and Paint Make You The Welder You Ain't!" -- from a t-shirt
Mongo228 is online now
post #6 of 7 Old 10-21-2021, 04:01 AM
ECJ-7
1976 CJ7
CJ's Aren't suppose to have doors, it cuts down on the breeze.
devildog80, atrusler and Mongo228 like this.
ECJ-7 is offline
post #7 of 7 Old 10-28-2021, 08:01 PM
Mister4x4
Mister4x4's Avatar
1980 CJ7
Luck to you!
As Dave mentioned, late-model 'paddle handle' door will fit, but you'll need to change strikers. The '80 model were 'wedge type' strikers, and the later models 'pin' strikers (like most modern car doors). I'll be doing the same thing he did to convert to modern style strikers, but instead of welding, I'll be 'gluing' them in with 3M Panel Adhesive.
I tried the striker adapters Dave linked to in his post, but there's a bit of a gap on the trailing edge, because the pin doesn't have enough adjustability to pull the doors in properly. But as you can see, they fit just fine in every other way.
Here's the difference between the '80s doors, and the later model Paddle Handle doors. 'Before' with a CJ hard top and factory doors:
And 'Now' with the later model Paddle Handle doors and an early YJ hard top (I wanted the bigger windows for better outward visibility). I'll be repainting them to look like it did before:
Mongo228 likes this.
Eric
Mister4x4 is offline
