Will this hurt the value of my Jeep - Page 2 - JeepForum.com
 5Likes
post #16 of 24 Old 05-30-2021, 11:00 AM
Axhammer
Axhammer's Avatar
Rivnuts are fine until one starts to spin. Once a rivnut starts to spin you have a new problem.They are pretty common in aviation, and the ones I am used to seeing have one small notch that must be cut in the edge of the hole. It’s not really a robust design, but there may be a different design that I am not familiar with.
If you do install rivnuts make sure you paint the bare metal that is created when you drill & notch the hole. I would recommend painting it first, and then after the paint has cured, wet install the rivnut with a corrosion inhibiting sealant.
If you don’t paint the bare metal it won’t take long for rust to develop.
Why do I own a CJ? I like to “Balance the wrench and the steering wheel”
1985 CJ-7 Sebring Red, White hardtop, 284 CID inline six (4.7) TF 999 auto
2020 JLU Black, Black hardtop, EcoDiesel, 35’s on 2” Mopar lift
View my Pontiac in my profile
Axhammer is offline
post #17 of 24 Old 05-30-2021, 04:00 PM
80cj
80cj's Avatar
1980 CJ5
Originally Posted by keith460 View Post
Riv Nuts are even better than just drilling and tapping. That's a step up for sure. They probably stick out above the sheet metal by a 1/16" or less so the foam weatherstrip would fill in the space when mounted.
I tend to agree. The windshield sheet metal gauge is thin and you won't get many threads engaging if you drill and tap. Just my thoughts.
80cj is offline
post #18 of 24 Old 05-31-2021, 05:37 AM
keith460
keith460's Avatar
With the 18 gauge steel of the windshield frame and using a drill bit for 100% thread cutting, I was able to get about 3 threads using 32 thread count screws. Beats using a sheet metal screw with one thread tearing it up but I only take off the rail once a year. Screws are lubricated with anti-seize compound as well. If they ever strip out in my lifetime, which I doubt, I'll use the rivet nuts for sure. But drilling for a 1/4" hole for the rivet nuts, there's no turning back.
These would work as 18 gauge steel is 0.050" thick and these are good to 0.030" minimum.
1984 CJ-7 Renegade
keith460 is offline
post #19 of 24 Old 06-02-2021, 08:04 AM
yjcharlie
yjcharlie's Avatar
1987 YJ Wrangler
Originally Posted by Nathar View Post
I just added it to the registry w images. Unfortunately my noobism won’t allow me to link it, so Look for Madeline in the registry or copy and paste.
jeepforum.com/forum/showthread.php?p=41281743#post41281743
Beautiful jeep for sure. Honestly, I would not drill holes in it for the top.
yjcharlie is offline
post #20 of 24 Old 06-02-2021, 02:29 PM
Colt44
Colt44's Avatar
1983 CJ7
Originally Posted by BrutusBlue View Post
The channel would interfere with the hardtop front edge. If you don’t mind removing the channel every time you put the hard top on then it’s not a big deal.
Been doing that for years. As was the case with very, very many CJs from the start, mine had been drilled for the sheet metal screws and I had no problems. That said, it's nice to know about the inserts in case they do ever strip out.
There is a lot to be said for a bikini top in the summer months, and the hard top will cover the holes. I seriously doubt the addition of those holes will affect value one way or the other.
"Let all the laws be clear, uniform and precise:
To interpret laws is almost always to corrupt them."
~ Voltaire
Colt44 is offline
post #21 of 24 Old 06-05-2021, 10:30 AM
Keekers McGrew
Absolutely STUNNING, Mate!! And this is an '84 with less than 25k miles?!? Myself, personally,...I would be hesitant to do anything else to it. But then again, I'm no where near the expert that the others on this forum are. Enjoy it as long as you can, and Happy Jeeping.
Keekers McGrew is offline
post #22 of 24 Old 06-09-2021, 12:54 PM
Steelman
IX-X-XIII-XIV-XL-XLIII
Steelman's Avatar
That's a beaut!
-Bob
'98 Black TJ Sport 4.0L/Auto Trans
-(O|||||||O)-
my rig:
_____________________________________________
Originally Posted by _Trucker View Post
I would rather shoot you in the face than play a guessing game....
Originally Posted by mrblaine
Are you bipolar, passive agressive, or just unable to recognize the dichotomy of your thought processes?
Steelman is offline
post #23 of 24 Old 06-09-2021, 03:23 PM
keith460
keith460's Avatar
Originally Posted by Steelman View Post
That's a beaut!
I'll say....
1984 CJ-7 Renegade
keith460 is offline
post #24 of 24 Old 06-16-2021, 02:24 PM Thread Starter
Nathar
Thanks for linking the pics, and also for the nice comments! I just noticed that the interior pic doesn't show the carpet. Rest assured the carpet is in absolutely perfect shape. We typically keep it stored in a climate regulated environment. I've found it keeps the integrity of the carpet in tact and makes sure that the carpet doesn't retain moisture against the floor panels which could cause rust.
Nathar is offline
