Where are the rear tie downs located on a CJ5 - JeepForum.com
 6Likes
post #1 of 41 Old 08-03-2020, 05:47 PM Thread Starter
John Strenk
John Strenk's Avatar
1976 CJ5
I have a bikini hop that needs tie downs in the rear.
I was wondering where on the tear corner the tie downs are usually located
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #2 of 41 Old 08-03-2020, 06:57 PM
Fourtrail
1974 CJ6
I would put them slightly out from straight back when the top is on. That or in the center of the bend around the back corners.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #3 of 41 Old 08-04-2020, 05:33 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
On top of the rear "rail" of the tub. The angle can be straight back or slightly outward to take up any sagging.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #4 of 41 Old 08-04-2020, 06:15 AM
OrangeCJ-5
OrangeCJ-5's Avatar
1978 CJ5
On the top rail of the tub at the taillights. This is a 1980 tub if that matters.
OrangeCJ-5 is offline
post #5 of 41 Old 08-04-2020, 06:18 AM
bob4703
1974 CJ5
Mine are centered over the curve. You want a little side tug against the opposite strap. I wore a uniform for almost 30 years and one thing I learned was when you erect a tent you want more side tension and less linear tension on your lines. I've heard more than once that a CJ is a tractor with a tent pitched on it.
Consider putting a strap buckle in each strap. It makes removal and installation easier. This is important when the afternoon thunderstorm occurs and you are trying to figure out how in the heck to thread the strap while you are getting wet.
Tractor Supply sells chromed footman loops for $1.50.
c82cj likes this.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #6 of 41 Old 08-04-2020, 09:26 AM
BradWilson101
1975 CJ5
Centered over the rear curve
c82cj likes this.
75 CJ-5 with 76 glass tub. 350 sbc with Edelbrock 600cfm, SM465, D20, D44 w/ 3:73, D30 w/ 3:73, Novak Hydro Clutch Convo. Turned into a frame off resto so it's still in progress.
BradWilson101 is offline
post #7 of 41 Old 08-04-2020, 11:05 AM Thread Starter
John Strenk
1976 CJ5
Now how to figure out the proper way of putting a threaded insert into fiberglass.
First time was a disaster...
post #8 of 41 Old 08-04-2020, 11:48 AM
Fourtrail
1974 CJ6
Drill hole, fill with 2 part epoxy and then insert the insert?
Cutlass327 likes this.
post #9 of 41 Old 08-04-2020, 12:21 PM
BradWilson101
1975 CJ5
Do you have the “rivet gun” version or the “long handle, bolt cutter” version? The former has a tendency for sideways torque which hasn’t been helpful in past projects.
post #10 of 41 Old 08-04-2020, 08:09 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Along with the 2 part epoxy,
You might coat a correct size bolt with anti-seize and run it "even" with the bottom of the insert. After it cures, screw the bolt out.
This is much EZer than drilling the center of the insert, then finding a tap to clean up the internal threads.
----JEEPFELLER
JEEPFELLER is offline
post #11 of 41 Old 08-04-2020, 08:28 PM
cjoffroad
cjoffroad's Avatar
1980 CJ7
I like to put a washer on the backside of the insert to give it something to grab to.
cjoffroad is offline
post #12 of 41 Old 08-04-2020, 09:23 PM Thread Starter
John Strenk
1976 CJ5
That will be another discussion. I need to shore up the visor mounts as the fiberglass is thin and starting to pull out.
I want to put in some of those threaded pop rivets in there.
I have both types of riveters, one that looks like a bolt cutter and one that looks like a pop riveter but it is hydraulic operated.
What I am unsure is the thickness of the fiberglas and getting the right insert length is important.
The area where the footman loop is attached is solid fiberglass. So I think a threaded or splined insert should be used there.
post #13 of 41 Old 08-04-2020, 09:25 PM Thread Starter
John Strenk
1976 CJ5
I'm not sure I follow you here.
post #14 of 41 Old 08-05-2020, 03:42 AM
BradWilson101
1975 CJ5
Sorry John, I meant the type of “nut insert” tool. Is there any way to add some more resin to build up or shore up the thinning fiberglass? If not I would suggest the epoxy as well. Just to give it some more material.
post #15 of 41 Old 08-05-2020, 04:26 AM Thread Starter
John Strenk
1976 CJ5
I've been reading some boat forums about mounting hardware in fiberglass hulls.
Seems like, "Need a #8 screw mount in a hull?"
"Drill a 1/2" hole and fill it with epoxy, Then put your #8 insert in the epoxy. But make sure you countersink the hole so you don't chip the gel coat."
Not sure how to do that on a vertical surface.
The rails on the CJ are already solid epoxy. Might need to do that with the windshield.
