When to Replace Shackles? - JeepForum.com
 1Likes
  • 1 Post By Fourtrail
post #1 of 9 Old 04-07-2020, 01:46 PM Thread Starter
0hcanada
0hcanada's Avatar
so, what's the test for needing to replace shackles? or, ... is there one? other than maybe a broken one, what dictates if or when to replace them?
Sent from my SM-G925W8 using Tapatalk
0hcanada is offline
post #2 of 9 Old 04-07-2020, 02:00 PM
only in a jeep cj
If they are stock shackles, you’ll see the bolt no longer centered in the bushing.
Sometimes the outer exposed bushing edges will be missing large pieces.
Or the shackle will be loose or leaning from a rusted out or damaged inner sleeve.
Also remember that the design and specs are different between the OEM shackle design and the aftermarket HD versions.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 2003 Inca Gold TJ Rubicon
2012 JKUR RHD
only in a jeep cj is offline
post #3 of 9 Old 04-07-2020, 03:32 PM Thread Starter
0hcanada
0hcanada's Avatar
Originally Posted by only in a jeep cj View Post
If they are stock shackles, youíll see the bolt no longer centered in the bushing.
they are stock. ... some outer exposed bushing edges are missing; but still appear centred ... can't say they are leaning either ...
you say that design and specs are different between OEM and aftermarket HD versions. does that mean = better?, or?
0hcanada is offline
post #4 of 9 Old 04-07-2020, 03:56 PM
Fourtrail
1974 CJ6
Broken or to upgrade is the only reason to replace a shackle, they are not really a wear item if they are setup and maintained correctly. Now it is a maintenance item to replace the bushings when they get hard, cracked and worn. Most go to an aftermarket shackle to gain some cheap lift over stock. Small lift is ok, but too much and you screw up your steering angles. HD can mean better as you can get a set with greaseable bushings that will ride smoother and last longer.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #5 of 9 Old 04-08-2020, 05:21 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Bent shackle
damaged shackle
Center (bushing) bolt loose/rotating in the shackle or bent. These should be fixed on one side and shouldered tight up against the other.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #6 of 9 Old 04-08-2020, 07:46 AM
Renegade82
Renegade82's Avatar
1982 CJ7
Like was said, the shackle isn't really a wear item the bushings are. Especially if they are the factory rubber ones. The more notorious weak item is the shackle mounts. They can twist, unwind, or crack at the rivet hole. And if you do go with a longer, beefier aftermarket shackle the need for new mounts becomes even greater.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #7 of 9 Old 04-08-2020, 11:24 AM Thread Starter
0hcanada
0hcanada's Avatar
so, by looks of responses its basically the bushings that appear in need of replacing. as i replied earlier shackles are straight, centred, ... only thing is some outer exposed (stock) bushing edges are missing.
can you get just bushings, or do you have to buy the entire shackle to get bushings?
if you can get just bushings, any heads up on what's best to keep it stock/OEM?
0hcanada is offline
post #8 of 9 Old 04-08-2020, 11:50 AM
Fourtrail
1974 CJ6
you can order stock rubber bushings through 4wd. if you want to stay stock, might as well just replace shackle and all as they normally to not come apart easily.
https://www.4wd.com/p/crown-automoti...ckle-kits/4181
Cutlass327 likes this.
post #9 of 9 Old 04-08-2020, 05:16 PM
only in a jeep cj
Originally Posted by 0hcanada View Post
you say that design and specs are different between OEM and aftermarket HD versions. does that mean =better?, or?
A lot of people do not understand the design of the stock shackle as it is composed of inner sleeves that are a distance slightly shorter than the width of the bushings so when everything is tightened it compresses the bushings with a certain amount of preload. Yes, the stock bushings are supposed to have their bolts tightened. There should be no metal on metal movement in the OEM set up. Only the rubber bushing is what gives.
The aftermarket heavy duty shackle kits usually consist of a center bar that is welded between the left and right shackle plates. This fixed distance will not allow you to properly preload the bushings and these aftermarket shackles run a larger bolt with no inner sleeve so there is either direct rotation in the bushing or the bolt pivots in the shackle plate holes. They are great for off-road applications were you need a strong but very loose shackle. But for a jeep driven on the highway I will take a stock shackle with either the rubber or the aftermarket polyurethane bushings any day. If you do go with aftermarket polyurethane bushings, be aware that there are two types. The ones with the flat face Are used with the aftermarket shackles, while the ones with a convex face are used with the OEM shackles as those plates have convexed areas.
Ed
1975 CJ-6 1983 CJ-8
2012 JKUR RHD
