What would you expect to pay for this work? - JeepForum.com
post #1 of 7 Old 01-26-2008, 12:14 PM Thread Starter
burtonsnowman
Vehicle: '84 CJ-7
I have no shop or much in the way of tools (or motivation in the winter), so I'm having a local shop perform some work on my Jeep for me.
I'll be collecting all the parts (except steel, welding rods, etc.) so labor is mostly what I'm concerned with.
Here's what I need done:
- Rebuild my 4.0 to 4.6 stroker
- Remove 2.5/T-4, drop in 4.6/new tranny/adaptor
- Install new springs, outboard springs, SOA
- Remove old steering stuff, install new high-steer componentry with J-10 box, build reinforcements
- Install full-width axles (lockers, tires, wheels are already on the axles)
- Slap on aome frame reinforcements
- Install new driveshafts (what will those cost me?)
That's about it...so what kind of labor do you think that is worth? How many hours? Do most shops work by the hour, or by the job?
Also, this Jeep is virtually rust-free and only has 90k original miles on it, so there shouldn't be many hang-ups or surprises.
- Red '84 CJ-7 - I'll build it someday! I have the parts, but no shop and no time! :(
- Black '78 J-10 - rollin' on 37s and SOA with front/rear Detroits, high-steer, etc.
- Green '93 ZJ - Crusty old PARTS-GIVER TO THE CJ!
"Six in a row makes it go"
...and a driveway full of Subarus...
burtonsnowman is offline
post #2 of 7 Old 01-26-2008, 12:59 PM
White92
Guest
That's what you think. I would guess it would be around 10k or something like that, I may be off. That's why we all do it ourselves.
White92 is offline
post #3 of 7 Old 01-26-2008, 01:10 PM
greaseboysjeeps
Guest
well put. lol
greaseboysjeeps is offline
post #4 of 7 Old 01-28-2008, 07:37 PM Thread Starter
burtonsnowman
Any other auggestions/input/ideas? Am I missing anything?
post #5 of 7 Old 01-28-2008, 07:57 PM
Bard
I would say you are missing a lot of stuff, just sounds like a vague approach to me, IMO. No offense.
You forgot cooling, wiring, springs, hangers, guages, manual or auto tranny?
t-case and adapter depending on what tranny, driveshafts custom built are about $250 each. As for welding and fabrication, you are looking at a ton of work to set it correctly. Don't forget shocks and spring perches, brake lines, fuel pump, etc, Alot goes into a complete change over.
Estimated charge would be close to $15k to do it, if not more.
Save the CJ for a better day and buy a YJ all built up and trash it. Seriously, why ruin a CJ in that condition is what you stated?
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #6 of 7 Old 01-28-2008, 07:58 PM
Mudslide
Mudslide's Avatar
1980 CJ7
I hope the shop you're using is use to doing that kind of work. If so, they should be able to give you a quote. It won't be cheap. If it were me, and I was going to spend that much money at one time, I'd look around for one already built. I bet you would come out way ahead in money, time, stress, ect. You could keep the rig you have or sell it to recover some of the cost. JMO
80 CJ7 Laredo-351W, NP435, D300, D30/AMC20, TJ flares, 36" TSL's, 3"BL, spray in liner, tube bumpers, and KC's.
69 F150-Hot 302. Project street truck.
94 Land Cruiser-33" MTX's (my wife's)
03 GMC-DD work truck.
Time is fun when you're havin' flies.
Mudslide is offline
post #7 of 7 Old 01-28-2008, 08:42 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
funny thing about custom work like outboarding your springs and a soa..There is no set time amount for it..So they can take there time and pass it on to you..
I agree that you could buy one done up like you want for way less..The jeep your building is standard for west coast rigs it seems..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
What to expect after transmission, transfer case swap bluesman423 Jeep CJ Forum 3 08-10-2009 08:36 AM
What can you really expect to get$ for a D44 Totallymetal Jeep CJ Forum 7 04-19-2009 02:30 PM
What kind of gas milage to expect from a 304 CJ7 Luckyduck Jeep CJ Forum 2 09-07-2008 11:05 PM
How much HP, if any, can I expect to gain UGA6 Jeep CJ Forum 8 02-21-2007 08:03 PM
Getting 79 CJ7-what to expect? NJCJ7 Jeep CJ Forum 4 06-16-2003 05:20 PM
