What to use to cowl seal to windshield frame ? - JeepForum.com
post #1 of 18 Old 09-17-2019, 02:47 PM Thread Starter
agear
I need to find something to stick my cowl seal to my windshield fr as me because it's starting to rust my new paint from water getting in there. Regular doubleside poster tape was a fail. I'm scared if I use the red double sided 3m tape that like they use for emblems , that it will peel my paint if i have to remove it. Any ideas ? My seal doesnt lay flat up on the windshield frame it curls. I need something that can be safely removed if necessary. Thank you
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 18 Old 09-17-2019, 03:31 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I used 3M trim adhesive (black). 3M makes a specific adhesive remover designed for safely removing it. Or WD40 will remove it, too.
Matt
Matt1981CJ7 is online now
post #3 of 18 Old 09-17-2019, 03:47 PM Thread Starter
agear
Matt
Nice haven't tried that one yet . Thanks !
agear is offline
post #4 of 18 Old 09-19-2019, 02:42 PM Thread Starter
agear
Matt
How does do sealing out water ?
agear is offline
post #5 of 18 Old 09-19-2019, 03:10 PM
Matt1981CJ7
1981 CJ7
It sealed well.
Matt
post #6 of 18 Old 09-19-2019, 04:33 PM
keith460
Jeep. There's Only One
keith460's Avatar
It failed on me as well after a year or two. I might as well try the 3M stuff but then again, I never take my CJ out in the rain either.
There are many types of double sided tape to choose from, but the problem is, I am no expert on what is best that can adhere to paint and rubber but not take the paint off if it needs to be removed.
1984 CJ-7 Renegade
keith460 is offline
post #7 of 18 Old 09-19-2019, 08:10 PM
Axhammer
Axhammer's Avatar
Are you talking about the foam rubber seal between the tub and the windshield frame? The one that has to flex allowing the windshield to fold forward? Those things leaked when they were new, and Iím trying to come up with a way to seal mine after I take it apart to repaint everything. Iím assuming the seal is available aftermarket, but am sure it will still leak. The one on my 1985 CJ-7 is the original seal, and looks crooked and deformed from age, and it leaks bad. Iím planning on putting a piece of black flex seal tape on it for now, since itís still being driven daily. Iím not so sure I would want to put tape over it after I repaint everything.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is offline
post #8 of 18 Old 09-19-2019, 09:33 PM
mikeyboat
1979 CJ7
Originally Posted by keith460 View Post
... I never take my CJ out in the rain either...
Aw, come on Keith! Please tell me you've taken a sock off to wipe down the inside of the windshield before!
j/k - I wouldn't drive your beautiful specimen in the rain either
mikeyboat is offline
post #9 of 18 Old 09-19-2019, 10:06 PM
sevensandeights
Sorry for the hijack but I remember reading a post about flattening out this seal so the windshield can angle back more. My driver's side angles back almost 2 inches more than the passenger side. It's nearly impossible to put my soft top on because of this. Anyone have a link?
I'm fairly certain the windshield is OEM but the seal looks new, likely a Crown/Omix product.
sevensandeights is offline
post #10 of 18 Old 09-20-2019, 04:24 AM
keith460
keith460's Avatar
I don't wear socks driving the Jeep, only size 14 flip-flops. It makes quite the challenge clutching and braking and not knowing if they stay on your feet or not while doing so.
1984 CJ-7 Renegade
keith460 is offline
post #11 of 18 Old 09-20-2019, 07:34 AM
Hoover7
Hoover7's Avatar
With feet that big, I'd think the bigger challenge would be mashing a single pedal rather than two at the same time!
Hoov
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is offline
post #12 of 18 Old 09-20-2019, 01:21 PM
keith460
keith460's Avatar
Ha, been down that road a few times in small Korean rental cars when I wear safety boots as large as Frankenstein's. You wind up stepping on the gas pedal and brake at the same time!
1984 CJ-7 Renegade
keith460 is offline
post #13 of 18 Old 09-20-2019, 02:12 PM Thread Starter
agear
It sealed well.
Matt
Nice
agear is offline
post #14 of 18 Old 09-20-2019, 02:13 PM Thread Starter
agear
Originally Posted by Axhammer View Post
Are you talking about the foam rubber seal between the tub and the windshield frame? The one that has to flex allowing the windshield to fold forward? Those things leaked when they were new, and I’m trying to come up with a way to seal mine after I take it apart to repaint everything. I’m assuming the seal is available aftermarket, but am sure it will still leak. The one on my 1985 CJ-7 is the original seal, and looks crooked and deformed from age, and it leaks bad. I’m planning on putting a piece of black flex seal tape on it for now, since it’s still being driven daily. I’m not so sure I would want to put tape over it after I repaint everything.
I think some people are able to get it to seal
agear is offline
post #15 of 18 Old 09-21-2019, 08:42 PM
Renegade82
Renegade82's Avatar
1982 CJ7
I put a continuous bead of rtv on both the ws and the cowl. Let it dry till hardened. This creates a bump that further compresses the rubber of the seal. I did this back in 95 and 15 years later I had only some surface rust (top pic). So when I restored the Jeep this time I did the same thing. No leaks so far... from washing it. It's only seen rain maybe 2-3 times since.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
