What tires to put on my cj7 build. - JeepForum.com
 4Likes
post #1 of 27 Old 08-07-2019, 05:04 PM Thread Starter
Splinter
1980 CJ5
It has 30 x 9.50 x 15 on it now. I think original Jeep rims. I want. 33 x 12.5 x15. I want something that looks aggressive but in reality this will be a mall crawler. Any suggestions??
Splinter is offline
post #2 of 27 Old 08-07-2019, 05:06 PM Thread Starter
Splinter
1980 CJ5
Adding photo
Splinter is offline
post #3 of 27 Old 08-07-2019, 05:45 PM
Dngrs1
1979 CJ7
BF Goodrich AT KO2's come to mind.....
uw91 likes this.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #4 of 27 Old 08-07-2019, 06:34 PM Thread Starter
Splinter
1980 CJ5
Wow 😮 I’ll check them out
Splinter is offline
post #5 of 27 Old 08-07-2019, 06:57 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Do you have any lift?
Also, what engine, trans, and gears?
Hoss
If you had to choose between World Peace and a Jeep, what size tires would you run?
JoonHoss is offline
post #6 of 27 Old 08-07-2019, 07:09 PM Thread Starter
Splinter
1980 CJ5
I am not sure of the lift. It is suspension and sits very close to my cj5 which has an SOA and 33 tires. I put a 360 amc in it
Splinter is offline
post #7 of 27 Old 08-07-2019, 09:01 PM
MetalMountainGoat
MetalMountainGoat's Avatar
You will need at least 2.5" to run 33s. That is pretty much the minimum.
MetalMountainGoat is offline
post #8 of 27 Old 08-07-2019, 09:58 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
2.5" is not enough for true 33", you need closer to 4". (Many 33" tyres only measure 32", not such an issue).
It is the width of the rear wheel boxes and lips, you need to get the tyres lower so they do not rub the front and back of wheel box on full extension. With a leaf spring suspension, the upward extension is limited.
Of course, if you never flex at the mall you may never find this out. Lots of rigs out at the mall could manage with no lift.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #9 of 27 Old 08-07-2019, 11:54 PM
MetalMountainGoat
Mine is a weekend cruiser, so 2.5" with 33s works great.
post #10 of 27 Old 08-08-2019, 08:59 AM
Dngrs1
1979 CJ7
Of course, if you want a mud tire, there is the Interco Tryxus M/T. I have these on my CJ (with a 4" lift).
Dngrs1 is offline
post #11 of 27 Old 08-08-2019, 09:05 AM Thread Starter
Splinter
1980 CJ5
When I ordered the new body mounts I ordered the ones that included an one inch body lift. It appears PO installed new springs that should give another 4 inches. I remember a friend had Mickey Thompson tires that looked mean.
Splinter is offline
post #12 of 27 Old 08-08-2019, 09:09 AM Thread Starter
Splinter
1980 CJ5
How would I measure lift with the body off. If I go from 30 inch to 33 inch on the same rims what lift would I gain.
Splinter is offline
post #13 of 27 Old 08-08-2019, 09:23 AM
uw91
Junior Member
uw91's Avatar
I just put the KO2s on mine and love them so far.
PNW Represent
uw91 is offline
post #14 of 27 Old 08-08-2019, 09:29 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
It depends on the actual tyre diameter. Most websites will tell you this. A 33" can be 32" and still marketed as a 33" 9I woudl feel cheated).
Originally it had 29" diameter tyres, so a 33" true tyre will add 4"/2 = 2" of extra clearance under the axle.
post #15 of 27 Old 08-08-2019, 09:31 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
I have a set on my xj and they are fab. However all my CJ have Mud Terrains or what we used to call Town and Country tyres. This is because my Cjs move more slowly and pend less time on fast highways, more time on tracks and off road (or broke down, but we do not count that).
