What's causing my Jeep to chirp - JeepForum.com
 3Likes
  • 1 Post By Fourtrail
  • 1 Post By jurgen24
  • 1 Post By layzdude
post #1 of 11 Old 06-22-2021, 11:38 AM Thread Starter
layzdude
I am getting a chirping/ squeeky sound coming from my 86 CJ7. It starts after its warmed up and only happens when in gear foot off clutch. Manual 5 speed. I replaced the water pump and power steering pump (both were original) but it has not stopped. could it be the clutch? The clutch does not slip. Was thinking maybe the throwout bearing. but wouldn't make more noise as I depress and release the clutch. Tired of replacing parts. lol
Ant thought?
layzdude is offline
post #2 of 11 Old 06-22-2021, 12:03 PM
Fourtrail
1974 CJ6
Sounds like a dry ujoint
JEEPFELLER likes this.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #3 of 11 Old 06-22-2021, 12:27 PM
258
258's Avatar
Fan clutch? Fan belt too loose? Or a random loose muffler bracket? I’ve had all 3 make noise but the last time was a simple muffler bracket in the rear that was the culprit. Drove me nuts and was not easy to find. Had a mechanic ride in the back while I drove it around. He pinpointed the location. Check all above and then move on!
258 is offline
post #4 of 11 Old 06-22-2021, 01:11 PM Thread Starter
layzdude
Thanks I will check out all the above.
Weird that it only happens in gear. As soon as I put it in neutral no mater my speed it stops
layzdude is offline
post #5 of 11 Old 06-22-2021, 01:16 PM
Techlight
Loose fan belt or an idler pulley/bearing starting to go out were my thoughts. As a temporary thing you could try some lubricant on the bearings or belt dressing to see if it goes away...it may be time for new belt(s). Should temporarily stop and then return.
,[_____],
_-o||||||||o-_
()_)ŻŻŻŻ )_) 1984 CJ7 Renegade, 4.2L-TBI, D30, AMC20, 4.5" OME lift
Techlight is offline
post #6 of 11 Old 06-22-2021, 01:44 PM
258
258's Avatar
Don’t apply lubricant but water with a spray bottle. The lube can cause future slippage. It may be a dried u-joint. Are yours greasable? If so, grease them. Also, grab the drive-shaft from underneath and wiggle it at the joints. Should be solid (no play).
To check your pulley bearings, at idle, carefully put a piece of wood or a long screwdriver on the pulley bolt. Be careful and mindful when doing this. If you have long hair, cap it! On the holding end, place your ear via your thumb knuckle to listen to the spinning bearing. It should be pretty quiet. If it’s a grinding noise, the bearing is shot and can squeak when it gets hot. Don’t buy a new pulley (expensive), simply replace the bearing/s (# 6203 1/2” 2RS WTW).
258 is offline
post #7 of 11 Old 06-22-2021, 01:53 PM
John Strenk
John Strenk's Avatar
1976 CJ5
This is so timely of a post. I took my jeep out for a shakedown before I go on a road trip.
So far I've only eliminated the hood hold down but there seems to be many more.
It only squeaks when the manifold vacuum is below 15 inhg.
So what does that tell you?
And it also squeeks just pushing the jeep so I think that that is a u-joint.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #8 of 11 Old 06-22-2021, 04:37 PM
jurgen24
Ant thought?
Squirrels?
Sent from my iPhone using Tapatalk
Techlight likes this.
jurgen24 is online now
post #9 of 11 Old 06-22-2021, 06:15 PM
mudbfun
1973 CJ5
How is the clutch adjustment? Does it have the proper free play?
mudbfun is offline
post #10 of 11 Old 06-24-2021, 01:11 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Grease is an underused 5 letter word!!!!
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is online now
post #11 of 11 Old 07-21-2021, 01:58 PM Thread Starter
layzdude
Well I finally tracked down the noise. It was the radiator clutch fan. $36 and abut 15 min and problem solved!
cjoffroad likes this.
layzdude is offline
