What oil do you use? - JeepForum.com
 14Likes
post #1 of 47 Old 07-22-2020, 08:50 AM Thread Starter
Submariner
Submariner's Avatar
1976 CJ5
I have picked up a 76 cj5 with a 360 v8 in it.
Going to change the oil in it and a "hotrodder" suggested that if I wanted my engine to last for a long time I should use oils that are more old school and have sulfates in it then the new synthetic oils.
I was thinking not a bad idea but then I thought it may be "BS".
So what is your take on the subject?
Submariner and you wonder why I am this way LOL
Submariner is offline
post #2 of 47 Old 07-22-2020, 09:28 AM
Nor Cal CJ5
Nor Cal CJ5's Avatar
1972 CJ5
Here's some good read on oil and it even gives determinations on what oil to use. I have no idea what will work for you. My recommendation would be to use an oil that meets the manufacturers API standards for your motor.
http://540ratblog.wordpress.com/2013...-test-ranking/
1972 CJ5 304 V8, 3 speed manual trans
Nor Cal CJ5 is offline
post #3 of 47 Old 07-22-2020, 09:30 AM
Axhammer
Axhammer's Avatar
Truth. The flat tappet cam needs the zinc that has been removed from the new oil. You can run an additive to make up for it, or you can buy oil that has zinc in it. Racing oil usually has the higher zinc content, but it is expensive. After an engine has been broke-in, it needs the zinc less than the initial startup.
I run Napa 10/40 oil and a pint of STP (for the zinc) in my 258.
I run Rotella 15/40 diesel oil with a pint of STP (for the Zinc content) and a quart of Lucas oil stabilizer in my flat tappet cam Pontiac race engine.
Ill run Rotella 15/40 diesel oil and a pint of STP (for the zinc) in my new 4.0 based 4.7 Mopar inline six engine thats going in my CJ-7. Im not sure how it will affect the catalytic converter, but Ill find out.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is offline
post #4 of 47 Old 07-22-2020, 09:34 AM
bob4703
1974 CJ5
Everyone on this forum who sees this will give you different advice. If you use a quality oil that was in use at the time the engine was new you can't go wrong. I put a crate 258 engine in our 74. The paperwork that came with it said I could use any modern oil in either 30HD or 10W-30 weights. I use a 10W-30 blend of conventional and synthetic. I personally wouldn't use an oil designed for a diesel engine simply because it ain't a diesel. Others will disagree.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #5 of 47 Old 07-22-2020, 09:46 AM
oldschool74cj5
hello
i run a hotrod oil because it is actually the older specs from the late 80's when the oil had a higher level of dzzp. dzzp is zinc dialkyldithiophosphate. it leaves a sacrificial film on the cam lobes and lifters that wears instead of the part. if i dont use that then i add a bottle of dzzp to the dino oil that i am running. the goverment mandated dzzp to be reduced because it eventually clogs up the cats. todays specked oil has less then 1/3 of it then years ago. even todays diesel oil has less then half of what it did 20 years ago. that is part of the reason the big three started going to roller lifters. they knew without the dzzp in the oil the flat lifters will start spalling.
my philosophy is run the products that were used back when the vehicle was designed and made. new stuff is nice for new stuff but doesnt work the best for older stuff. example manual transmissions back then want gl4 gear oil. today its hard to find gl4. gl5 spec is used in rear axle with a posi without adding the additive. if you run that in a manual transmission it will ruin the brass synchros.
oldschool
uptillnow likes this.
oldschool74cj5 is offline
post #6 of 47 Old 07-22-2020, 10:44 AM
uptillnow
uptillnow's Avatar
Similar to oldschool, I use the "hot rod" oil, or 4 stoke "motor cycle oil" for the higher level of ZDDP.
I have been using a 10W-30 Grp IV & Grp V synthetic from Red Line Oil Co. I have been known to add 4 oz of the 16 oz bottle of engine break in oil supplement from Red Line Oil Co. for the additional ZDDP protection. (without catalytic converter)
Like stated above, many use the diesel oil (CI-4 plus) for the higher ZDDP content without issues.
My $0.02 worth
UTN
Submariner likes this.
uptillnow is offline
post #7 of 47 Old 07-22-2020, 11:03 AM
oldschool74cj5
hello
actually im glad this came up. i went in the garage and saw i only had one bottle of dzzp additive left. i checked amazon for some more and found a great price so ordered more. last time i paid 5 bucks a bottle for it.
https://www.amazon.com/Rislone-4405-...66&sr=8-2&th=1
oldschool
Nor Cal CJ5 likes this.
post #8 of 47 Old 07-22-2020, 12:30 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
I use Valvoline VR1 10W-30 motor oil with a WIX 51258 oil filter in my 79 CJ5 304 V8. Runs fine.
RedNeckCorvette likes this.
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is online now
post #9 of 47 Old 07-22-2020, 12:33 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
YouTube Video on ZDDP in Motor Oil, why you may need it and where to get it.
Winston Churchill
post #10 of 47 Old 07-22-2020, 02:48 PM
Nor Cal CJ5
1972 CJ5
How many here have used zinc and still wiped a cam lobe?
The author of the link in post #2 premise is:
The only thing that truly matters is an oils film strength load carrying capability, NOT merely how much zinc it has.
I know some may be suspect as zinc can't hurt (right?). But more important, the author is stating that the strength and tested quality of the oil to prevent wear first and foremost - is the key.
uptillnow and Submariner like this.
post #11 of 47 Old 07-22-2020, 03:01 PM
Axhammer
Axhammer's Avatar
I have never wiped a lobe. I have always have used some sort of zinc additive since the early 2000’s
Blame it on the internet.
Axhammer is offline
post #12 of 47 Old 07-22-2020, 03:07 PM
Nor Cal CJ5
1972 CJ5
Originally Posted by Axhammer View Post
I have never wiped a lobe. I have always have used some sort of zinc additive since the early 2000s
And I just bought a case of zinc additive that oldschool recommended.
Yap, blame it on the internet!
post #13 of 47 Old 07-22-2020, 03:13 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Valvoline VR1 is the only oil I've put in my 360, because of the high ZDDP content.
Matt
Matt1981CJ7 is offline
post #14 of 47 Old 07-22-2020, 03:40 PM
uptillnow
uptillnow's Avatar
The only thing that truly matters is an oil’s film strength load carrying capability, NOT merely how much zinc it has.
I ran a Jobber machine shop for 10 years in the 70's and 80's.
I built a few engines in that 10 years, and had 4-6 NEW cam failures.
I believe it had to do more with the manufactures grind, ZDDP and the film strength.
Also, my cam "re-grinder" would grind a 2 degree taper in the lobe, and re-grind the NEW lifters to a 50" radius, I never had a re-grind go bad. see picture
I used Torco 20W-50 with MPZ (molybdenum, phosphorus, and zinc) and cam break in oil supplement on 90% of the engines I built.
post #15 of 47 Old 07-22-2020, 05:33 PM
hp_lovecraft
1981 CJ5
According to oil companies, they have replaced the zinc with moly, and is supposed to do the same thing protecting old and new engines.
I don't buy that, but I'm not an oil scientists, so I don't really know.
Instead, for the last 15 years, I've used whichever 'diesel oil' happens to be on sale.
All things being equal, the diesel oils have higher zinc, and detergents, and other additives that standard oil. Maybe it helps, maybe it doesnt. But that has worked for me
hp_lovecraft is offline
