What is my stock gear ratio? - JeepForum.com
 2Likes
  • 1 Post By jeepdaddy2000
  • 1 Post By John Strenk
post #1 of 11 Old 05-23-2019, 09:11 PM Thread Starter
weider1717
Guys, I have looked online and nothing really says point blank what gears I would have.
1978 golden eagle
304
3sp
I have 35" tires on it now and I know the past two owners the gears are what was in it stock it was only lifted and big tires put on very recently. My thought was I'll need to re-gear but whatever is in it does pretty good turning the 35's you wouldn't be crawling with it too good but otherwise not bad at all plenty of power but I may still re-gear.
thanks
weider1717 is offline
post #2 of 11 Old 05-23-2019, 09:41 PM
Superjeep3
Superjeep3's Avatar
This is what I found. I hope it helps.
https://www.automobile-catalog.com/auta_details1.php
Looks to be 3.54 stock with 4.09 being an option.
Superjeep3 is offline
post #3 of 11 Old 05-23-2019, 10:03 PM
RiverandSand
1980 CJ5
You should have an AMC20, there should be stamped letter(s) on the right rear side near the diff cover. Jeeptech under the Amc20 tab has the code breakdown. Of course that's if the gears haven't been changed by a PO.
RiverandSand is offline
post #4 of 11 Old 05-23-2019, 11:49 PM
ddawg16
ddawg16's Avatar
Or....jack up one tire....spin the wheel and count driveshaft turns.
Don't forget to multiply by 2. With one wheel blocked, the DS will turn half as fast.
Say you have a 3.00 ratio....that means your driveshaft turns 3x for each turn of the wheel. With a standard diff, if you block one wheel, then 3 turns of the ds means 6 turns of the wheel.
Since it's easier to turn the wheel vs the DS....use a piece of chalk....mark a line on the DS (I like doing it at the pinion for reference)...mark a spot on the wheel (I like using the body side as a ref)....then turn the wheel.
You don't have to be exact.....the real world ratios are not very close.
ddawg16 is offline
post #5 of 11 Old 05-24-2019, 04:01 AM
keith460
Jeep. There's Only One
keith460's Avatar
I'm pretty sure the axle ratio's available for 1978 were standard 3.07 and optional 3.54. You can check the letter code on the right side of the rear axle cover, stamped into the casting just to the left of where the axle tube meets housing.
Standard X = 3.07
Trac-Lok Y = 3.07
Standard A = 3.54
Trac-Lok N = 3.54
1984 CJ-7 Renegade
keith460 is offline
post #6 of 11 Old 05-24-2019, 06:17 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Ya know, you may just want to drop the rear diff cover and do a tooth count.
This will give you a positive answer.
It will tell you if there are any other issues in there. Things like a bad LS or chunking of the axle/side gears.
It will let you see if a PO has installed anything else in there.
It will put fresh 90WT into the diff.
Regardless of what the stock gearing is, 35's are gong to require at least 4.11 or lower gears (transmission dependent)
Might think about a set of one piece axles as well.
WindKnot likes this.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #7 of 11 Old 05-24-2019, 07:23 AM
BrutusBlue
1982 CJ7
What’s your rpm at any given speed? easy to calculate your ratio without lifting a finger.
Otherwise, pop the diff cover.
BrutusBlue is offline
post #8 of 11 Old 05-24-2019, 09:25 AM Thread Starter
weider1717
Thanks for the replies!
3.54 is what I was finding online also but someone on here told me it was wishful thinking that I probably has I think they said 2.73 or 3.31. So, I thought I would ask.
When I am back home I will be sure to check out the stamp code first and go form there, thanks!
post #9 of 11 Old 05-24-2019, 09:30 AM
jp360cj
1977 CJ7
Most likely 3.54s, which were standard. 4.10s were optional. IMO, it would be best to pop the covers, verify the tooth count, inspect, and fill with fresh fluid. This will also give you a chance to check the diff for a limited slip/locker.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #10 of 11 Old 05-24-2019, 01:26 PM
John Strenk
John Strenk's Avatar
1976 CJ5
One last way to check is to put a chalk mark on the drive shaft and just push the jeep forward one wheel revolution and count the turns of the DS.
If it turns 3 and 1/2 times it's probably 3.54
If it turns 4 times then it's probably 4.10.
No jacking up
No removing a rear cover
No trying to read a rusted ID label.
Not that those are not good ways
ddawg16 likes this.
John Strenk is offline
post #11 of 11 Old 05-25-2019, 02:10 AM
80cj
80cj's Avatar
1980 CJ5
Standard X = 3.07
Trac-Lok Y = 3.07
Standard A = 3.54
Trac-Lok N = 3.54
3.07 came out in 1980 and I believe that was the only year it was used in CJ's. Optional for 80 was 3.54.
80cj is offline
Regearing from 4.88 to Revolution Gear's new 5.38. Jerry Bransford TJ Wrangler Technical Forum 45 04-26-2019 10:09 AM
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
selecting axle gear ratio freedom_in_4low TJ Wrangler Technical Forum 34 10-27-2018 12:23 PM
P0732 Gear 2 Incorrect Ratio?? JKWags JK Wrangler Technical Forum 18 09-11-2018 05:43 PM
To Find Gear Ratio rsurran TJ Wrangler Technical Forum 51 07-12-2018 09:09 PM
