What fan and shroud are you using ? - JeepForum.com
 5Likes
post #1 of 51 Old 05-08-2019, 03:05 PM Thread Starter
agear
I have a 1 inch body lift and am using a flex fan and a shroud that I had to modify. But it's kinda open at the top. I gotta use the shroud since I have a.c. . What are y'all using ? Is it safe to go to a little bit smaller fan or would that be pointless and lose some of the cooling of s larger fan just so I can use s shroud ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 51 Old 05-09-2019, 10:02 AM
ddawg16
ddawg16's Avatar
Electric.....solves lots of issues....I can turn it off when going through water....I can force it full on when I want.
And it doesn't care where my engine is.
Mine is a Ford Taurus fan with a variable speed controller.
Chrisinchwk and MN15078 like this.
ddawg16 is offline
post #3 of 51 Old 05-09-2019, 10:45 AM
MN15078
Which year Taurus and could you share the variable controller information?
MN15078 is offline
post #4 of 51 Old 05-09-2019, 12:10 PM
ddawg16
ddawg16's Avatar
There are a few different links on the fan....this one is pretty inclusive....
https://www.pirate4x4.com/forum/gene...plication.html
Fan control....this is the one I'm using...
http://www.dccontrol.com/constant_te...ontrollers.htm
Don't be afraid to email them....the guy is very responsive.
Flex-a-lite also makes bolt on kits....but pricey
ddawg16 is offline
post #5 of 51 Old 05-09-2019, 01:14 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
I'm using a Ford Contour/Mercury Mystique dual fan controlled by a Flex-A-Lite controller.
Originally Posted by ddawg16 View Post
url]http://www.dccontrol.com/constant_temperature_controllers.htm[/url]
If I was dying from thirst, I wouldn't buy a drink of water from him.
Long story, and after a lot of years of keeping the email exchange with him, I deleted them (finally let it go...). But a short synopsis: He refused to sell to anyone that was a member on Pirate4x4 (which I was).
I'm glad your experience was better. Mine was almost 15 years ago, and I still remember it. To quote Mr. Wonderful: 'He's dead to me'.
"In the end...It's all Hack."
HackFabrication is offline
post #6 of 51 Old 05-09-2019, 02:27 PM
ddawg16
ddawg16's Avatar
So.....how do you really feel?
I didn't realize he was like that. And I'm also a member on Pirate...not super active....but I think I've been on there for at least 15 years
ddawg16 is offline
post #7 of 51 Old 05-09-2019, 04:16 PM
Colt44
Colt44's Avatar
1983 CJ7
My CJ had a flex fan when I purchased it, but after re-gearing it was so loud I removed it and went back to an OEM style clutch type that I retrieved from the boneyard.
It's quiet, it's simple, and it works.
I had an issue because I'd dropped the transfer case an inch, which put the engine at a slight tilt.
All I had to do was drill new mounting holes (shroud to radiator bracket) and put it back on - perfect fit.
"The inherent vice of capitalism is the unequal sharing of the blessings.
The inherent blessing of socialism is the equal sharing of misery."
~ Winston Churchill
Colt44 is offline
post #8 of 51 Old 05-09-2019, 08:49 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Bagusjeep has the original fan and clutch but a plastic shroud taken from some unknown junker. A couple of quick holes and some wires and plastic ties and it sits just where it needs to be.
Puthijeep has all original, the blades did start hitting the shroud when I replaced the motor mounts but it is steel so a little bending and it is fine.
Gladys the J20 has no shroud, just the original fan and clutch. Must find one for her.
All these have the 258ci engine and none have ever overheated sitting in tropical sunshine. The mechanical fan pulls a substantial amount of air, even with an old clutch. Apparently the contour dual fans get close.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #9 of 51 Old 05-24-2019, 05:22 PM Thread Starter
agear
Do you guys think there would be no effect if I went from 17 to 16 inch fan but a more enclosed shroud.
It's kind of a trade going to a smaller fan so lose some air there but I'm going to a more enclosed shroud so I'll get some more intensity there. You think it will be an overall performance because I had to modify this one to work so its partially open at the top
agear is offline
post #10 of 51 Old 05-25-2019, 02:06 AM
80cj
80cj's Avatar
1980 CJ5
Maybe slightly smaller diameter but more blades.
80cj is offline
post #11 of 51 Old 05-25-2019, 08:07 AM
trailhead2004
trailhead2004's Avatar
1980 CJ7
I have a Flexi Lite in my CJ7 258. Fans are nice but their controller is a little janky. Had control problems wit it. I wired to battery so it would run for a while after shutting down. A little obnoxious, and I could take care of it by wiring to accessory.
All that said, the fans themselves are solid. If you could find a used set, and get a good controller youíd likely be happy. I do also like what others are doing with Taurus fans. Sounds like an inexpensive way to get electric fans.
"Johnny Cash, The Jeep in Black" Build Thread - Started 7 July, 2018
"Bad things happen to you because you're a dumba$$"
Red Foreman
trailhead2004 is offline
post #12 of 51 Old 05-25-2019, 12:32 PM
LumpyGrits
Cj
OEM fan and shroud.
When I did my 1" body lift. I just re-drilled the radiator mounting holes to put it back so the shrould was centered to the fan.
No big deal....
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #13 of 51 Old 05-26-2019, 06:19 AM
bob4703
1974 CJ5
I was a firm believer in electric fans until the relays started hanging up and burning up the fan motor and as a result killed the alternator. I'd bought a nylon flex fan several years ago that didn't fit and was still sitting on the shelf. I trimmed it to fit being careful to remove the same amount from each blade. Lo and behold it ran smooth with no vibrations.
As my neighbor said the real test will be if it cools on a hot day. Yesterday it was 94* and I took a 50 mile round trip through the country and into town. It held steady at 195-200*. In fact at stop I could see the gauge needle tick slightly as the thermostat opened and closed.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #14 of 51 Old 05-26-2019, 12:04 PM Thread Starter
agear
Nice. What I'm really looking for is a way to keep the condenser cool.
agear is offline
post #15 of 51 Old 05-26-2019, 12:10 PM
CJPondScum
1983 CJ7
I am running a clutch fan but having a hard time finding a shroud to fit. my CJ was frankensteind together and the blade sits lower and off the right of the radiator a bit. Need to find someone that can custom a shroud for me. Think a metal fabricator can get it done?
Kevin
1983 CJ7 - PondScum
360 TH400
35's 4:56
CJPondScum is offline
Fan Shroud Install on 1975 CJ5 w/ 304 V8 and 7 Blade Fan PottsyCJ5 Jeep CJ Forum 20 02-01-2019 05:26 AM
Missing Fan Shroud / MY DYI Fan Shroud Solution aldoylemini Jeep CJ Forum 15 09-08-2018 06:35 PM
My electric fan conversion (lots-o-pics) Soliloquy_LV ZJ Grand Cherokee Forum 5 06-09-2018 12:55 PM
Electric and Clutch fan Conversion: How to delete your Hydralic fan commandojack WJ Grand Cherokee Forum 10 05-07-2018 07:52 AM
Rad Fan Shroud Repair - Barnum Bros Fibre Inc moriartii Jeep CJ Forum 2 02-21-2018 03:48 PM
