What does the term "intermediate" refer to with CJ5s - JeepForum.com
post #1 of 26 Old 03-20-2015, 07:55 AM Thread Starter
vdubbles24
Ive recently acquired a 1974 CJ5, everyone refers to it as the intermediate CJ why is that?
vdubbles24 is offline
post #2 of 26 Old 03-20-2015, 08:53 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The '72-75 CJs are a slightly different design from the earlier Willys version and the later '76-86 version.
Matt
Matt1981CJ7 is offline
post #3 of 26 Old 03-20-2015, 08:57 AM
Fourtrail
1974 CJ6
72-75, they lengthened the front fenders/hood/frame to accommodate the strait 6 engine, but kept the tub/dash/windshield frame the same as the earlier models. For the 76 models they redesigned the dash and windshield frame. Kind of a transformation oddball set of years, some parts match from the 71 and earlier and some from the 76 and later when doing work on it.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #4 of 26 Old 03-20-2015, 09:24 AM
Matt1981CJ7
1981 CJ7
I believe the dash design changed around '73. I also think '72 was the first year for the full-floater Dana 30 front axle.
Matt
post #5 of 26 Old 03-20-2015, 09:29 AM
chromegrille
1947 CJ2A
It's an internet term, birthed by unknowns.
Elementary Jeeps, 1941-1971
Intermediate Jeeps 1972-1975
Senior Jeeps 1976-1986
chromegrille is offline
post #6 of 26 Old 03-20-2015, 12:55 PM Thread Starter
vdubbles24
So would the dash just be flat steel, or would it have a dash pad? I've googled cj5 dash and seen both versions.
post #7 of 26 Old 03-20-2015, 12:57 PM
Fourtrail
1974 CJ6
Matt
Open knuckle Dana 30, not full float. All front axles are full float.
There was a padded dash options, but it was different design from the 76+ as they changed the windshield hold downs.
post #8 of 26 Old 03-20-2015, 02:07 PM
CSP
Heater controls went from under the dash to in the dash panel in '76 and the steering column location also changed in the same manner along with being a different column. The 72-75 dash is the 99% the same as the '71 and older, other than bolt hole spacing on the sides where they bolt to the tub.
CSP is offline
post #9 of 26 Old 05-28-2015, 08:45 AM
bdatkins
1978 CJ5
Not to hijack this thread (totally hijacking this thread), I'm looking at a '74 right now. Other than the dash, heater controls and box, are there any critical parts that are hard to find for the intermediate years?
bdatkins is offline
post #10 of 26 Old 05-28-2015, 09:27 AM
Pathkiller
1974 CJ5
Gas tank filler neck. The metal part that bolts to the body, that the gas cap attaches to. It's unique and not found anywhere else or reproduced. The rubber gas filler hose is available from MTS, as is the breather hose, but not the metal insert that the breather hose attaches to, which goes into the main filler neck. The gas tank skid plate is unique to this era, but the tank itself mounts directly to the frame, so the skid plate isn't essential.
Seat brackets are unique to this era and sometimes difficult to find.
Bushings for the steering column are not available, the lower one typically gets worn out and allows some slop between the shaft and the column. The columns were also used in Commandos and Postal Jeeps, with minor differences.
Windshield hinges are not reproduced (applies to all 55-75 CJ-5's and CJ6's).
Tail-light assemblies are unique to the era (not just Intermediates, but around 68-75-ish) and aren't easy to find. The lenses are available from Grote, but you have to look for them.
That's about all I can think of for the moment, but I'm sure there's more. All of the above can be worked around, there's nothing that's a deal-breaker. The wiring harness is lousy, with no fuse panel and only a couple of inline fuses protecting the circuits. A fuse panel was added in 75.
The major advantages of the Intermediates are:
Flanged and centered Dana 44 rear axle.
Large drum brakes (11x2)
Most powerful V8 engine offerings (72-73 304's were about the most powerful offered by AMC before pollution controls knocked the HP ratings way back).
Transmission tunnel cover unbolts, allowing easy access to transmission and transfer case. If you've ever had to pull the top cover off the transmission you'll appreciate this, as you don't have to drop the entire transmission to do the job.
Pathkiller is offline
post #11 of 26 Old 05-28-2015, 09:58 AM
CSP
The cover on my '75 is welded on. I've never paid attention to any other '75s, but I was kinda surprised to see that when I bought it.
CSP is offline
post #12 of 26 Old 05-28-2015, 11:50 AM
Pathkiller
1974 CJ5
Yeah, 75 was the first year of the welded cover. Up to then they were bolted on. Came in handy a couple of weeks ago on my 74 when I had to pull the cover off the transmission. About 5 minutes to pull the trans tunnel cover.
post #13 of 26 Old 05-28-2015, 08:35 PM
Partsmke
75 also had a unique transmission/transfer case cross member, it connected to the top of the frame as well as the bottom using two separate brackets on each side connected to the bottom one piece cross member. It also was the first CJ that required a catalytic converter.
Partsmke is offline
post #14 of 26 Old 05-28-2015, 09:51 PM
CSP
Only the V8s had the catalytic convertor though.
CSP is offline
post #15 of 26 Old 05-29-2015, 12:54 AM
chevy71super
It is more difficult to find minor parts for intermediates but most "major" drive train parts are available. With creativity and a lot of searching the internet I have found most of what I need. I have a 75 which has the first fuse panel of any CJ. The 75 also had a stouter frame compared to the other intermediates. (Advantage over the 76+ is that they are not nearly prone to rust.) The most frustrating part is finding a decent top if you don't care for the Bestop option. (Which I don't) The original top manufacturere went out of business in the mid 80's.
chevy71super is offline
