What do I need to make a Holley carb work on stock 258 manifold - JeepForum.com
 12Likes
post #1 of 60 Old 05-18-2019, 09:38 AM Thread Starter
agear
I'm looking to get a Holley for my 258. I want to keep using the stock 258 bbl intake manifold . What are the options ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 60 Old 05-18-2019, 09:49 AM
Shawn Watson
Shawn Watson's Avatar
1983 CJ7
Are you talking about a Holley 4-barrel on a stock, I6 intake? I sure hope not
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
Shawn Watson is offline
post #3 of 60 Old 05-18-2019, 03:20 PM Thread Starter
agear
Originally Posted by Shawn Watson View Post
Are you talking about a Holley 4-barrel on a stock, I6 intake? I sure hope not [IMG class=inlineimg]/forum/images/JeepForum_2016/smilies/tango_face_surprise.png[/IMG]
Shawn
Any Holley......
agear is offline
post #4 of 60 Old 05-18-2019, 03:46 PM
Shawn Watson
1983 CJ7
I bet a Motorcraft 2150 would be a reasonable test.
Shawn
post #5 of 60 Old 05-18-2019, 08:01 PM Thread Starter
agear
Looks like I can adapt to a Holley 2300 series bolt pattern. Does anybody know if I can adapt to the stock 258 air cleaner to this Holley 2300 series street avenger ?
agear is offline
post #6 of 60 Old 05-19-2019, 07:53 AM
gutthans
gutthans's Avatar
I'm pretty sure anyone that's run a Holley on a 258 with the stock cleaner is dead...
If you aren't going to lose the stock intake, go with a Motorcraft 2150. If you insist on a Holley, use the 350 cfm 2-barrel and run a 9" or 10" aftermarket filter.
There's an old saying about trying to make a silk purse out of a sow's ear (trying to dress up a pig).
Shawn Watson, WindKnot and ddawg16 like this.
gutthans is offline
post #7 of 60 Old 05-19-2019, 09:34 AM
ddawg16
ddawg16's Avatar
^^ That ^^
I personally think Holley's are one of the most over rated carbs out there. 'Back in the day' when carbs were all we had, I tried a Holley on my 67 Camero....Ran good....but putting the Rockester Q-Jet back on made it run better....and it got better gas mileage.
ddawg16 is offline
post #8 of 60 Old 05-19-2019, 10:37 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Any Holley......
You have to be more specific.
What are you trying to do?
What improvements are you trying to get?
If all you want is to install a Holly simply for that purpose, I recommend a couple of stickers on the fender and call it good.
trailhead2004 and ddawg16 like this.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #9 of 60 Old 05-19-2019, 12:46 PM Thread Starter
agear
Why do you say you're pretty sure anyone who has tried to use a stock 258 cleaner on a Holley is dead
agear is offline
post #10 of 60 Old 05-19-2019, 01:44 PM
gutthans
gutthans's Avatar
Well, in a word...sarcasm. Old farts and people throwing on Holleys when it was a thing back in the day. Dead to the Jeep world by now , maybe actually dead. I don't come across people trying to do that anymore. Heck, I don't find many trying to install Holleys (except myself).
The stock air cleaner isn't well suited to a cfm improvement, particularly Holley/Edelbrock/Carter designs that need flow around the perimeter of the inlet flange, and like it coming in straight and above the inlet. Stock designs that push the filter below or level with the inlet and restrict air to a limited entry point don't work well for improved horsepower. That's a compromise design that maximizes hood space and plumbs all of the crazy emissions hardware. Plus, of course the idle warm-up benefit of the vacuum door on the cleaner snout (which is actually a good idea).
The stock cleaner is a restoration on an original, and perfectly good for around town grocery trips.
gutthans is offline
post #11 of 60 Old 05-19-2019, 02:31 PM Thread Starter
agear
Any Holley......
Lol. For better performance. A better fuel air mixture
agear is offline
post #12 of 60 Old 05-19-2019, 10:16 PM
Fourtrail
1974 CJ6
Stock air cleaner has too small of a hole to fit the holley 2300/motorcraft 2150, they need the larger 5 1/8" carb top flange and your stock air cleaner is 2 5/8". You can look for a holley 2280 off of a late 70's early 80's dodge v-8. bigger jets than your stock bbd and the air cleaner fits, but you either have to drill the hole in the lid bigger or swap over the bail/stud from your stock bbd to the holley. have to do a bit if adapting on the throttle linkage, but have to do that with most any different carb.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #13 of 60 Old 05-20-2019, 06:02 AM
jeepdaddy2000
1971 CJ5
Off idle performance? Mid range? WOT?
Smaller carbs work better for low and mid range work (that would be the 350 CFM model).
Maintaining the stock intake pretty much eliminates a 4BBL.
Installing any of the Holley 2BBL's is going to be about the same procedure as swapping on a 2100. Lots of info here on that swap.
On a side note, I've always wondered why nobody looks at the Rochester 2G series 2BBL. They came in a number of sizes and used a mechanical power valve which eliminates leaking.
Thomas Payne
post #14 of 60 Old 05-20-2019, 07:32 AM
Fourtrail
1974 CJ6
IIRC the Rochester 2G is a different bolt pattern from both the BBD and the 2100 series. There I believe are also 2 different Rochester 2bbl bolt patterns. so getting the correct adapter can be a bit of a chore.
post #15 of 60 Old 05-20-2019, 07:59 AM
Shawn Watson
1983 CJ7
Look at the manifold itself; the bores are already smaller than the throttle plates on your Weber and they shotgun the mixture right into the plenum heater.
Shawn
258 build suggestions McSyd Engines & Drivetrain 19 02-17-2019 07:30 PM
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
Hydroboost and P pump conversion Cobra Jeep YJ Wrangler Technical Forum 24 04-29-2018 06:47 AM
Where do I find 258 intake manifold heater gasket and o ring Sidney1921 Jeep CJ Forum 1 11-26-2017 05:46 PM
CrankyGypsy's 2004 Rubicon CrankyGypsy Jeep Builds 33 05-14-2017 09:03 PM
