What to do about hose on paint - JeepForum.com
 3Likes
post #1 of 16 Old 01-11-2020, 07:46 AM Thread Starter
agear
I installed a new ac hose. I really dont want to drill a new hole in my painted inner fender to put another cushion clamp(but may have to). So I'm looking for alternatives to that. Maybe there is some fabric insulation I could put over the hose to protect the paint. Looking for ideas
I have these 3m zip tie mounts I could stick to the paint and run a zip tie to but I dont know if the paint will come off if I peel it off one day. I think that's what I'll try
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 16 Old 01-11-2020, 08:31 AM
pedal2themetai
1956 CJ5
you can always buy some clamps / brackets that hold in place and off the paint
good luck
tim
pedal2themetai is offline
post #3 of 16 Old 01-11-2020, 08:33 AM
keith460
keith460's Avatar
Copper hot water line insulation comes to mind, in black foam.
1984 CJ-7 Renegade
keith460 is offline
post #4 of 16 Old 01-11-2020, 09:47 AM Thread Starter
agear
Okay well I went with the sticky zip tie mounts . But I still need to do something for where it hits the battery and tray . I'll go to the store. May end up with the copper pipe foam . If it will hold up. Would have to check it after a few ...
agear is offline
post #5 of 16 Old 01-11-2020, 09:58 AM Thread Starter
agear
good luck
tim
Yes but I didn't want the bracket on the paint. I thank you though. I went with zip tie mounts
agear is offline
post #6 of 16 Old 01-11-2020, 10:04 AM Thread Starter
agear
It would be on the ac hose that gets warm so I guess that wouldnt hurt
agear is offline
post #7 of 16 Old 01-11-2020, 10:10 AM Thread Starter
agear
Thanks y'all
agear is offline
post #8 of 16 Old 01-11-2020, 01:04 PM Thread Starter
agear
Here it is . I'm not sure I like it yet
agear is offline
post #9 of 16 Old 01-11-2020, 07:58 PM
Spieg8
1984 CJ8
Maybe its just the perspective of the photos, but it looks to me like you could just hang the hose from the grill support bar and it wouldn't touch fender paint at all.
It's not the Voltage, but the Amperage that will kill you.
Spieg8 is offline
post #10 of 16 Old 01-11-2020, 09:01 PM
Renegade82
Renegade82's Avatar
1982 CJ7
Late to the party but I was going to suggest using a piece of weatherstrip foam. A 6-8" piece of 3/8" thin, compressible foam with the self adhesive side stuck to the bottom of the hose would be hidden and needs nothing adhered to the paint.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #11 of 16 Old 01-12-2020, 05:44 AM Thread Starter
agear
I was thinking the foam would still rub the paint.
pedal2themetai likes this.
agear is offline
post #12 of 16 Old 01-12-2020, 07:53 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
You are worried about the paint under the hood, yet you put your large batch of KEYS on the exposed painted fender?? You better break that habit now!
EricRThompson likes this.
Rick
Cutlass327 is offline
post #13 of 16 Old 01-12-2020, 08:55 PM
1970pelle
You need to take that A/C hose off and have it remade. I'm very sure there is a shop that makes custom A/C hoses(lines) for custom Hot Rod,Street Rod installs. That can clean that up, with a couple of tweaks. And it will keep the hose away from the inner fender.Those plastic sticky hold downs are for lite wiring, they will not be sticking around very long. And you can tie the two hoses together as the run forward. For a much cleaner look. Rather than a after thought and everything just thrown together. You might spend $30.00 on the hose. Its to nice of a Jeep to not do it just right. I may own worthless opinion.
Cutlass327 likes this.
The successful warrior is the average man, with laser-like focus.
Bruce Lee
1970pelle is offline
post #14 of 16 Old 01-13-2020, 01:06 PM Thread Starter
agear
Okay thank you. . Yeah I try to be careful. Sometimes I slip up. The hose I can definitely make a little shorter. The problem I have Is that fitting at the compressor for that line is a 90 degree fitting so the way I had it before was routing it straight toward the grille putting a curve in the hose tight at the fitting and I broke the fitting. The factory has the hose routed toward the firewall then back like I do. . I got lucky with the zip tie mounts because the hose sits on them zip ties.. I may have that hose shortened I just have the system charged already. I gave it too much slack to bend back.
agear is offline
post #15 of 16 Old 01-14-2020, 07:10 PM
1970pelle
You missed my point. They make fitting for every make A/C compressor made, that has different angle bends. So A/C compressors can be swapped into just about anything made. And its not that hard to make your own hose ends yourself. Just saying.
https://coldhose.com/specialty-fitti...ale-flare.html
https://nostalgicac.com/fittings-hos...-fittings.html
Bruce Lee
