What did you do to your CJ today? - Page 1872 - JeepForum.com
 4600Likes
post #28066 of 28125 Old 11-22-2021, 07:17 AM
dolsoncj7
1981 CJ8
Did the POR-man's powder coat on the AMC 20. I'm impressed with how that stuff flows out with a brush. This is the preventative as the first coat and then their chassis black top coat.
-DO
○|||||||○ likes this.
1981 CJ8 Scrambler
1985 CJ7 Renegade
dolsoncj7 is offline
post #28067 of 28125 Old 11-22-2021, 01:09 PM
agear
Ordered swaybar quick disconnects. Should improve movement in that small amount of space
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #28068 of 28125 Old 11-22-2021, 02:41 PM
258
258's Avatar
Cj
-DO
Looks good! I started using Por-15 and love the way it flows; pretty cool. Only draw back is you pretty much have to toss any brush you use.
258 is offline
post #28069 of 28125 Old 11-22-2021, 07:17 PM
Big Daddy CJ5
1978 CJ5
Cj Got a new one.... 78 CJ5
Got this thing home Sunday.... worked on it all afternoon, and then some today. Rewired the engine compartment, rebuilt the carb, tightened multiple loose crap, vacuumed, pressure washed, installed a Smitty swing-type spare holder, new rear bumper, messed with the top.. a whole bunch of little crap. When I get it where I want it, I won't have to post in here ever again.. right?
LOL.
Big Daddy CJ5 is offline
post #28070 of 28125 Old 11-22-2021, 08:50 PM
dolsoncj7
1981 CJ8
Yeah, and there's a spot on my hand that seems impervious to acetone.
Down here in Southeastern NC, there aren't a lot of options for powder coating so they can command some pretty good pricing. I was quoted $200 for sandblasting and $250 to powder coat it. I'm into it for probably $50 in paint, brushes and various wheels for my angle grinder and I have something that's pretty good - and I can touch it up. Adding the limited slip kind of broke my budget.
1981 CJ8 Scrambler
1985 CJ7 Renegade
post #28071 of 28125 Old 11-22-2021, 10:20 PM
258
258's Avatar
Cj
Try using Baby Oil on your hand. It will remove it! The oil absorbs under the surface of the paint and in-between your skin. Works like a charm!
258 is offline
post #28072 of 28125 Old 11-23-2021, 07:59 AM
BruceinGA
Installed LED front turn signals a month ago. They functioned perfectly for weeks, and all of a sudden, flashing very fast. So, I installed the relay I originally purchased at the same time to solve that. I also replaced a 12 inch section of rubber fuel line in the engine bay since it was cracked/dry rotted. Checked the oil and found that I was low about 2-3 quarts. 8 months ago it got a rear main seal service with of course an oil change. So, apparently my engine with only 127k on it is burning oil and I've only driven it about 1200 miles this year.
BruceinGA is offline
post #28073 of 28125 Old 11-23-2021, 08:25 AM
mdlott
1978 CJ7
After 10 years of not having my reverse lights come on automatically, I finally took the time to identify the wiring (the PO used a non-standard wiring harness, so nothing matches color codes in the FSM), build a wiring harness for the circuit, install a new switch on the transmission, and hook it all up. I'm not sure it makes that much of a difference, but it's been bugging me for a while.
While I was messing with wiring, I also installed a hidden switch under the dash wired to a garage door opener that's tucked away next to the back of the speedo.
Up next is LED bulbs for the dash and then all the minor electrical is done and I can start working on the engine (carb rebuild, fix timing, etc.).
mdlott is offline
post #28074 of 28125 Old 11-23-2021, 04:17 PM
TimmyD7
Not today, but last weekend I cut up my old poorly fit plow mount and fabbed some new mounting brackets. Hoping to weld it all up this weekend.
The Mountains are calling and I must go
TimmyD7 is offline
post #28075 of 28125 Old 11-24-2021, 11:14 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Pictures!! I'd like to see some alternate designs. Mine bolts to my axle.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #28076 of 28125 Old 11-24-2021, 11:54 AM
JERSEYJOE
JERSEYJOE's Avatar
Mounted my bumper
I fabricated a front bumper from some rectangular tube and added a trailer hitch receiver. Just got it back from the powder coater and now I am waiting for the plate that mounts on top for the winchbumper-2.jpg
John Strenk, 258, Axhammer and 2 others like this.
SPEED COSTS MONEY: HOW FAST DO YOU WANT TO GO?
JERSEYJOE is offline
post #28077 of 28125 Old 11-24-2021, 06:02 PM
agear
Had to order some different swaybar disconnects as the first pair require welding which im not gonna do
agear is offline
post #28078 of 28125 Old 11-24-2021, 06:13 PM
JERSEYJOE
JERSEYJOE's Avatar
Also mounted the rear bumper
Mounted the rear bumper before I dropped the body on. Has a vintage pair of CARR aluminum steps.sat-2.jpg
Axhammer and ○|||||||○ like this.
post #28079 of 28125 Old 11-24-2021, 06:20 PM
258
258's Avatar
That’s a really nice bumper . . . Beefy!
258 is offline
post #28080 of 28125 Old 11-25-2021, 11:10 AM
agear
Put my b.i.l.s tunnel cover back on with boots. We put twin sticks on. Replaced his clutch fork boot
agear is offline
I just got my first CJ5 today! bannings Jeep CJ Forum 14 04-06-2018 05:35 PM
Got another CJ today!! fastas69 Jeep CJ Forum 9 03-01-2016 08:12 AM
What Did You Do To Your CJ Today? Renegade86 Jeep CJ Forum 4 08-01-2010 10:31 PM
Nutter'ed my 84 CJ7 2.5 today! 79cherokee Jeep CJ Forum 2 10-11-2008 11:06 AM
got my cj-5 today....:D supersly_jones Jeep CJ Forum 11 06-17-2004 08:32 PM
