What did you do to your CJ today? - Page 1839 - JeepForum.com
 4509Likes
post #27571 of 27981 Old 07-02-2021, 06:28 AM
Axhammer
Axhammer's Avatar
Originally Posted by RARECJ8 View Post
Builder parts for front YJ pax. So long 2Ē pac. We believe all needed. Challenge is centering app hangers. From 2Ē oem to 2.5++ for YJ mounts. Lots of geometry and science, plus book learning.
Are you going to do a shackle reversal as you do the 2.5Ē YJ spring swap?
Iím on the fence as far as going shackle reversal on my build when I do my SOA with YJ leafs conversion. Your thoughts on SR & SOA with new aftermarket replacement YJ springs on a CJ-7?
Why do I own a CJ? I like to ďBalance the wrench and the steering wheelĒ
1985 CJ-7 Sebring Red, White hardtop, 284 CID inline six (4.7) TF 999 auto
2020 JLU Black, Black hardtop, EcoDiesel, 35ís on 2Ē Mopar lift
View my Pontiac in my profile
Axhammer is offline
post #27572 of 27981 Old 07-02-2021, 08:20 AM
downs
downs's Avatar
1995 XJ Cherokee
Got the master cylinder and calipers replaced, rebled the brakes on my brother's CJ7. One step closer to getting this thing out of my garage lol. I also took the repro fender flares I removed off my CJ5 and replaced the front flares that were basically falling off. I'll be doing the rears later I just ran out of gas as I got started on this late and called it quits.
1995 Jeep Cherokee Country 4X4 Stock
AW4/NP231/C8.25/D30/"UpCounty" suspension
downs is offline
post #27573 of 27981 Old 07-02-2021, 08:23 AM
agear
Calipers look good
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #27574 of 27981 Old 07-02-2021, 10:19 AM
zcostilla
zcostilla's Avatar
1966 CJ5
Originally Posted by bob4703 View Post
What is the problem with the Spartan TS? I have one that semi worked when I replaced it. PM if you want it.
I added you as a friend, but canít find where to PM you. Iím as new to the forum as I am to Jeeps (a week in!). Saw you live in Easley. We live in Fountain Inn, but almost bought a house on C St. there in Easley. Loved the 2-story porch on it, but it didnít work out.
Our Jeepís a 1966 CJ5, and itís my sonís first vehicle. He saved and we bought it to wrench on together. He wants to keep it mostly stock except for safety items (better headlights installed, and weíre looking to go with taller seats and 3-point seat belts). Of course the motor isnít ever going to be stock, as we bought it in Seneca, SC from a guy who had already swapped in a 4.3L Vortec. Thinking we might re-gear the transmission when it needs rebuilt (likely soon, since it wonít stay in 2nd gear), but weíll cross that bridge when we get there.
The Spartan turn signal switch has worn through the wires in the unit, and the auto-canceller isnít working. But I canít even get it to flash. I replaced the flasher yesterday, but it still isnít working (nor do the brake lights), but the tail lights come on fine when I turn in the headlights.
Iím either riding, wrenching, fishing, or playing guitar
zcostilla is offline
post #27575 of 27981 Old 07-02-2021, 11:12 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
its already SOA and SR-- been like that for 15 years but the skinny CJ pax are about shot and we believe this might be affecting the rear spring troubles, documented here under leafspring nightmare thread. we shall see. YJs are an inch longer so must re position the front hanger and widen it up. nothing is easy.
Axhammer likes this.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
Facebook: Hillís Angels 4x4 Club
RARECJ8 is offline
post #27576 of 27981 Old 07-02-2021, 03:01 PM
downs
downs's Avatar
1995 XJ Cherokee
Originally Posted by agear View Post
Calipers look good
They're just some remans from Rock Auto. Nothing fancy. I've gotta ship these old ones back for core.
downs is offline
post #27577 of 27981 Old 07-02-2021, 05:52 PM
258
258's Avatar
258 is offline
post #27578 of 27981 Old 07-02-2021, 08:15 PM
Rtracy2001
The Jeep moved under its own power for the first time in more than a year. It took a hour of troubleshooting to figure out the fuel pump relay was bad and once that was fixed, I found the hydraulic clutch needs some work, but I was able to drive it around the yard a bit.
gr8dain, downs and TimmyD7 like this.
Every 20 minute job is just one broken bolt away from a three day ordeal.
Rtracy2001 is offline
post #27579 of 27981 Old 07-02-2021, 08:26 PM
agear
Calipers look good
Oh they look painted
agear is offline
post #27580 of 27981 Old 07-02-2021, 08:45 PM
downs
downs's Avatar
1995 XJ Cherokee
Bare cast iron unless the reman place coated them with something.
downs is offline
post #27581 of 27981 Old 07-03-2021, 07:56 AM
bob4703
1974 CJ5
Originally Posted by zcostilla View Post
I added you as a friend, but can’t find where to PM you...
The Spartan turn signal switch has worn through the wires in the unit, and the auto-canceller isn’t working. But I can’t even get it to flash. I replaced the flasher yesterday, but it still isn’t working (nor do the brake lights), but the tail lights come on fine when I turn in the headlights.
Welcome. You can send me a personal message by clicking on my name on the left. This site isn't too user friendly. I have just gotten used to it over time.
I sent you a PM with my email info.
You'll find manuals for your Jeep here https://oljeep.com/edge_parts_man.html
They contain wiring diagrams.
The turn signals and brake lights are independent of each other. If you have a fuse box your Jeep has been rewired. With a 4.3 I suspect it has been. if not that will be a needed project.
zcostilla likes this.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #27582 of 27981 Old 07-03-2021, 10:33 AM
BruceinGA
New Seatbelts, new center console from a few weeks ago, and new BFG 32 11.5 x 15. My wife is nice enough to be volunteering her efforts, using paint remover to take the old clear coat off the wheels to expose the nice chrome. Also found some guy on eBay selling an OEM Mopar turn signal switch assembly manufactured in 1989...LOL. So, I will replace that switch and the auto signal disengage cam on steering column due to left turn signal not disengaging.
A9FD1B8F-058C-4E80-BD40-AE3562A31041_1_105_c.jpg   303BC9EE-39ED-4E6C-B0D1-2FCD4E167F65_1_105_c.jpg   9816E46D-0B99-47B5-8B2E-94F77EE71A90_1_105_c.jpg
downs likes this.
Last edited by BruceinGA; 07-03-2021 at 12:18 PM. Reason: sentence was not properly constructed.
BruceinGA is offline
post #27583 of 27981 Old 07-03-2021, 01:27 PM
agear
Ordered quadratec led tail lights . Supposedly no socket terminals to wear out. Just like a board in there. Almost failed inspection
John Strenk likes this.
agear is offline
post #27584 of 27981 Old 07-03-2021, 06:13 PM
agear
Eastwood makes some tough a$$ brake master cylinder paint i used. Years. Later it still looks great.
downs likes this.
agear is offline
post #27585 of 27981 Old 07-03-2021, 06:32 PM
KPCJ76
KPCJ76's Avatar
Originally Posted by woody-77 View Post
This thread was floating around in the TJ forum when I was down there......so I'm stealing it.....
Wash and wax!
Kevin Holladay
KPCJ76 is offline
whollsee
I just got my first CJ5 today! bannings Jeep CJ Forum 14 04-06-2018 04:35 PM
Got another CJ today!! fastas69 Jeep CJ Forum 9 03-01-2016 07:12 AM
What Did You Do To Your CJ Today? Renegade86 Jeep CJ Forum 4 08-01-2010 09:31 PM
Nutter'ed my 84 CJ7 2.5 today! 79cherokee Jeep CJ Forum 2 10-11-2008 10:06 AM
got my cj-5 today....:D supersly_jones Jeep CJ Forum 11 06-17-2004 07:32 PM
