What is this bracket for ? - JeepForum.com
 2Likes
  • 2 Post By John Strenk
post #1 of 9 Old 02-12-2020, 06:54 AM Thread Starter
Cavjock22
Cavjock22's Avatar
1981 CJ7
AC? On board air pump?
Cavjock22 is offline
post #2 of 9 Old 02-12-2020, 07:50 AM
pedal2themetai
1956 CJ5
Hi That is ether for an AC compressor or an on borad air compressor
good luck
tim
pedal2themetai is offline
post #3 of 9 Old 02-12-2020, 07:55 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Yep Both!
Or even for an idler pull for a serpentine belt. with AC deleted.
Yes, this really is an OEM idler pulley
schardein and RedNeckCorvette like this.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #4 of 9 Old 02-12-2020, 08:48 AM
schardein
schardein's Avatar
1983 CJ7
Yep Both!
Attachment 3888503
Attachment 3888501
Yep, I've got one of those, original to my 1983 CA emissions 258.
1983 CJ7, 5.3, NV3550, D300 4:1, Fr D44 Detroit, Rr D44 OX, 4.56, 35" Falken A/T3W on beadlocks
schardein is online now
post #5 of 9 Old 02-12-2020, 11:15 AM Thread Starter
Cavjock22
Cavjock22's Avatar
1981 CJ7
oooh wow. Any ideas where I can find a air compressor that would fit there? What that available from the factory?
post #6 of 9 Old 02-12-2020, 11:27 AM
schardein
schardein's Avatar
1983 CJ7
Just to clarify, the term "air pump" in those years referred to a low volume, low pressure pump that injected air into the exhaust manifold and was a part of the emissions control system.
The bracket you pictured is for the air conditioning compressor. In the CJ years, that compressor is referred to as a York, it's brand name. They can be converted and work very well as on board air compressor because they have an internal oil reservoir for lubrication that most modern type AC compressors lack.
post #7 of 9 Old 02-12-2020, 11:43 AM
jimdavis577
Jeeper for life
jimdavis577's Avatar
1979 CJ5
Multiple vehicles used the yorks..... and you can get them in a variant of sizes as well..... they work either upright or on their sides as well .... very good offroad conversion .... just be mindful of the heat they produce alot !!!
79 CJ5, SBC, sm465/np205, Dana 60 axles, stretched and tubed
88 yj, SOA, AMC 304, dana 44 front and rear, on 35s
88 XJ, 4.0 all stock
2012 JKU, 4" inch lift on 35's , bumpers and winch, daily driver
jimdavis577 is offline
post #8 of 9 Old 02-12-2020, 01:32 PM
pedal2themetai
1956 CJ5
Hi they used the York A/C compressor as an on board air pump for compressed air. different than a emission air pump.
good luck
post #9 of 9 Old 02-12-2020, 04:54 PM Thread Starter
Cavjock22
Cavjock22's Avatar
1981 CJ7
Thanks gentlemen
