Warn Hub Question - JeepForum.com
post #1 of 6 Old 06-19-2019, 07:32 AM Thread Starter
BushPusher77
1977 CJ7
Cj Warn Hub Question
I have these hubs on my 1977 CJ7 and the previous owner used a heavy grease to lube them, which make them not work so good.
I am trying to remove the selector knob there is grease behind the sliding parts inside so it moves very hard, does anyone have any information on this style hub or even a breakdown or something that would help take them apart so i can get them working.
where they polished or painted when new ?
Thank you for any information on this
Roger
BushPusher77 is offline
post #2 of 6 Old 06-19-2019, 10:15 AM
only in a jeep cj
Before you take it apart, move the dial to full clockwise and mark where the two inner rings are meeting and where the plastic lines up in the metal body. This will be a tremendous help when it comes to putting it back together.
Under the sticker, there is a single Phillips head screw. Be sure to push in on the inside as you undo the screw or parts will go flying under the spring tension.
Originally painted black. And as a very rare option, Warn had a chrome version
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 6 Old 06-19-2019, 10:20 AM
only in a jeep cj
This thread may help
I have a picture in post 9 that should help too
https://www.jeepforum.com/forum/f8/c...aging-4335301/
Ed
1975 CJ-6 1983 CJ-8
post #4 of 6 Old 06-19-2019, 08:04 PM Thread Starter
BushPusher77
1977 CJ7
Thank you: only in a jeep ,I will check out the parts removed from the spline after i get all the grease off to make sure there is no damage to any of the parts before a think about removing the screw holding the selector in place if i have damage and with no part available going forward would make no sense.
Again Thank You for your help and the great information in the post
Roger
post #5 of 6 Old 06-20-2019, 12:48 PM
LumpyGrits
Cj
Dump those POS Warn's, and get some Mile Marker hubs.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #6 of 6 Old 06-20-2019, 05:12 PM
calcj7
X2
calcj7 is offline
