Used Distrubtor, what to look for. - JeepForum.com
post #1 of 42 Old 12-31-2011, 09:16 AM Thread Starter
waterdowg
waterdowg's Avatar
I did the Team Rush and Nutter a while ago, and the post Nutter vacuum tube clean up. So now I'm looking to change the distributor to a pre-computer unit.
I have checked the local parts stores and not one have units make R13/R18. I have loacted 1 from a 1980 AMC Concord w/ 6cylinder for under $20 at my local Junk Yard. So what should I look for so see if it is any good. How do I check for wear issues etc....
waterdowg is offline
post #2 of 42 Old 12-31-2011, 02:20 PM
BlueRubiconrich
better yet go with a 77 Ford truck with a 300 cap, rotor adapter and wires.
The ford cap is better ,the adapter is cheap and you get 9mm wires.
no screwdriver needed to open cap this has clips. This works great.I did it!
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 42 Old 12-31-2011, 04:06 PM Thread Starter
waterdowg
waterdowg's Avatar
Will the 77 distributor be a direct swap in a 258? If not what would I need to do?
post #4 of 42 Old 12-31-2011, 08:40 PM
JeepHammer
1973 CJ5
He's saying CAP,
Missed the part about looking for a distributor with advance.
What advance are you getting in the ones you find?
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #5 of 42 Old 12-31-2011, 09:28 PM Thread Starter
waterdowg
waterdowg's Avatar
Thanks. The ones I'm finding I think were like 6.75, 6, 7., 6.5 or something like that. I don't remember the exact numbers, but they were they had those numbers. I was mostly looking for 13 or 18, so I really didn't pay attention to the those number.
They will not order more since they have some in stock and the the computer tells them its the correct part. Computers.......
post #6 of 42 Old 12-31-2011, 09:59 PM
JeepHammer
1973 CJ5
Yup, that's the computer distributor you are finding.
You COULD find an older Ford distributor and swipe the advance head out of it...
Except for housing shaft and gear, the parts interchange.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #7 of 42 Old 01-01-2012, 07:35 AM Thread Starter
waterdowg
waterdowg's Avatar
I can get a used distrubutor from and 80 AMC concord with a 258. Shouldn't that work? If so what should I look for and how do I check for wear or issues.
I really don't want to mess with my original distributor. Would like to do a swap.
post #8 of 42 Old 01-01-2012, 08:22 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I got my re-manufactured Motorcraft distributer at NAPA. As you can see. It has the larger advance slots.
When you find one, I suggest flipping the head to use the 18 degree slot, and stick a lighter set of springs in it. You'll be surprised how it wakes up your engine.
Matt
Matt1981CJ7 is offline
post #9 of 42 Old 01-01-2012, 08:28 AM Thread Starter
waterdowg
waterdowg's Avatar
Matt
Thanks I went to my local NAPA, and they only had the computer ones. Do you have the part number on the springs you used?
post #10 of 42 Old 01-01-2012, 09:02 AM
Matt1981CJ7
1981 CJ7
I had trouble finding light enough springs, so I made my own from standard hardware store springs.
Matt
post #11 of 42 Old 01-01-2012, 09:27 AM
JeepHammer
1973 CJ5
'C' clip with tails under that oiling felt at the top of the shaft,
And the springs,
Are the only things holding that advance head on the shaft.
If you find that Concord from a I-6, it will fit right into your engine.
Depending on year, it will either have the large advance head, or the computer advance head.
There really isn't anything to wear out stupidly on these distributors,
They aren't like breaker points distributors, they work on like 0.035" clearances, so you can run one when it's way warn with no issues.
That's why the factories all jumped on them and got away from breaker points.
You can use the 'Chevy' tuning springs, they are available everywhere for cheap.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #12 of 42 Old 01-01-2012, 10:07 AM Thread Starter
waterdowg
waterdowg's Avatar
Ok thanks. So as long as it has the 13/18 stampings. I should be good then. I will check on tuesday on my way home from work. I is out of thr car already. They just have verify they still have it.
As for the Chevy springs what do I look for?
post #13 of 42 Old 01-01-2012, 11:51 AM
JeepHammer
1973 CJ5
Go get a 'Tune Up' kit for a chevy distributor,
At the parts stores, it's usually 'Mr. Gasket' p/n 929 or Moroso p/n 72310 if I remember correctly...
Throw away the weights/bushings, you don't need them for the 'Ford' distributor.
The springs are all that you will be using.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #14 of 42 Old 01-03-2012, 03:32 PM Thread Starter
waterdowg
waterdowg's Avatar
Well the yard did not have the distributor. There is another yard about 45 min away that does, and they are twice the price. So, looks like I may try to get a ford and swap the heads.
What year and make ford should I ask for. I really don't have a u-pull closer then an hour away.
Are the ford advance plates available I after market parts?
Or if someone has a pre-computer dizzy they could sell me shipped for $20-$30.
post #15 of 42 Old 01-03-2012, 04:01 PM
scrapman
If all else fails, take off your advance head and open up the slots. I think jeephammer does this all the time, and has some sort of template he goes by. You could eyeball the slot openings from the picture in this thread..
scrapman is offline
Pls Help HEI Distrubtor install Questions marcaurell Jeep CJ Forum 3 01-09-2011 07:32 PM
