Uneven height on rear left corner... - JeepForum.com
post #1 of 13 Old 05-27-2013, 06:38 PM Thread Starter
DGRobles
My toy is a CJ-7 '86... recently I installed a new rough country 2.5 lift suspension+1.25" shackle (Daystar)... works fine but a little hard... anyway, recently I noticed that my rear driver side is dropped by 1 inch... I search for possible cause but had not clue...
Does anybody know which could be the reason? Could this be caused by a bad shock absorber?
Diego Robles / XE1XZQ
DGRobles is offline
post #2 of 13 Old 05-27-2013, 06:53 PM
CJ7nvrstk
CJ7nvrstk's Avatar
Shocks don't support weight so a bad shock would not cause a sag. Check your u bolts and see if they may have worked themselves loose.
RED Friday. Remember Everyone Deployed
45 MB, 67 Commando, 85 CJ, 08 JKU, 11 JKU
CJ7nvrstk is offline
post #3 of 13 Old 05-27-2013, 10:11 PM
LumpyGrits
Know'n RC springs(don't lik'em at all)and their 'history'. You have a spring issue for sure.
LG
LumpyGrits is offline
post #4 of 13 Old 05-28-2013, 07:03 AM
Truck633
GO ONE MORE!!
Truck633's Avatar
LG
THIS!!
I installed my RC lift a few years back and when they arrived I noticed they had been re-bent in a press. They were quick to send out a replacement, however it hasn't been right since (pass front sags over an inch) I just wrote it off as crappy product and will replace it with a BDS lift when time allows!
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #5 of 13 Old 05-28-2013, 11:04 AM Thread Starter
DGRobles
Thanks for your comments... I will check today on detail the shackles as that one on that side has a little inclination, however not that much to lose 1 inch.. I will check if the bushing are ok...
DGRobles is offline
post #6 of 13 Old 05-29-2013, 07:22 PM Thread Starter
DGRobles
LG
Well looks like I do have a spring issue, I took measures, shackles are ok, seeing the leaf spring, right one has more curvature than left one.
Took some pics,
DGRobles is offline
post #7 of 13 Old 05-29-2013, 07:26 PM
LumpyGrits
1/2" is nut'n on a CJ.
Swap the rear springs .....
How's the front ones??
LG
post #8 of 13 Old 05-29-2013, 07:30 PM Thread Starter
DGRobles
LG
Good shape, are well levelled, just the rear ones are the issue.
DGRobles is offline
post #9 of 13 Old 05-29-2013, 07:41 PM
Manhattan
Manhattan's Avatar
1981 CJ8
I hope it's the spring... but it could be the infamous "Jeep Lean" - made more noticeable by the lift. Albeit a pain in the ***, the best test is to swap the rear springs left to right and see how it stands.
You can't go by the apparent/current curves in the springs - the Jeep Lean WILL flex the springs differently.
1981 CJ8, Chevy 5.7, SM465, D300, RE 4.5, 35" BFG MTs, 20/30 4.56, Detroits, Warn 9500ti
Manhattan is offline
post #10 of 13 Old 05-29-2013, 07:41 PM
74Maverick
Mine does that a bit, it has new springs under it but the real issue in mine is that I weigh about 320lb. so check your scale.
The Last Great American Hero... the demi-god... to which speed means freedom of the soul.
74Maverick is offline
post #11 of 13 Old 05-29-2013, 07:55 PM Thread Starter
DGRobles
What about the rear spare tire? Its a 33" BFG with Procomp 16"... Could that be a possibility?... The warn rockcrawler tire carrier is more charged to the left... I will remove it to see how behaves...
DG!
DGRobles is offline
post #12 of 13 Old 05-30-2013, 06:45 AM
Truck633
GO ONE MORE!!
Truck633's Avatar
I thought jeep lean was caused by bad springs, different relax levels. Where are you suggesting it comes from?
Truck633 is offline
post #13 of 13 Old 05-30-2013, 10:09 AM
jeepwhore
jeepwhore's Avatar
Nope. There have been many people complain of the lean even after installing a brand new, high quality lift. Some have suggested there was a problem with the frame jig in the factory and its obvious quality control wasn't at the forefront with AMC so it's entirely possible.
Whatever the cause, I'm just thankful mine doesn't have it.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
