Twin Shifter Comparison - JeepForum.com
 6Likes
post #1 of 23 Old 12-13-2019, 06:05 PM Thread Starter
Alabamacj71981
Alabamacj71981's Avatar
Forums can be great for getting a gauge on brands to avoid or product characteristics to look for. I haven’t seen anything on the forum comparing twin sticks (including conversion kits). What should you look for? Material differences? Tall vs short shifters? I see the usual brands. Leaning Novak for everything but have no valid reason.
I’m rebuilding my Dana300 transfer case in a couple of months and wanted to get feedback on this and the spring/ball mod to get it done right. Thanks!
Alabamacj71981 is offline
post #2 of 23 Old 12-13-2019, 06:53 PM
redfin188t
redfin188t's Avatar
1982 CJ7
JB Fabrication twin sticks are on my Christmas wish list.
Life is fraught with opportunities to keep your mouth shut. -Winston Churchill-
redfin188t is offline
post #3 of 23 Old 12-13-2019, 09:00 PM
87MJTim
87MJTim's Avatar
1987 MJ Comanche
I bought the Novak twin stick. I also swapped an AX15, so my issue may not apply to you. The AX15 is longer than the T5 I took out. Also, the AX15 required a clocking disk. Both of these pushed to D300 further back. I got the twin stick with the adjustable length. The adjusting plates have pre-drilled holes that allow positioning the pivot points for the shifters. However, I could not find a combination with the pre-drilled holes that did not have the shifters either a) hit the dash panel or b) hit the center console. I ended up taking the lower plates and drilling new holes in between the pre-drilled holes. Now the shifters do not hit either the dash or console.
Again, my issues may not be yours.
Edit: It shifts fine (now)
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.0 (93 XJ) AX15 (Formerly T5)
87MJTim is offline
post #4 of 23 Old 12-13-2019, 09:01 PM
Renegade82
Renegade82's Avatar
1982 CJ7
I think it's pretty hard to beat the design and price of the JB Fab twin sticks. And after 3 years with them now I have no complaints. Sans any non Jeep trans as mentioned above that would alter length.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #5 of 23 Old 12-13-2019, 09:08 PM
John Strenk
John Strenk's Avatar
1976 CJ5
My preference is to go with taller ones. Having them on the passenger side makes for a long stretch.
I made my own, it's not really that hard.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #6 of 23 Old 12-13-2019, 11:03 PM
RiverandSand
1980 CJ5
I also have the JB Custom Fab twin sticks, great setup. I visited their shop when I was in Oregon. These guys are hard core offroaders, so I don't have any reservations about recommending their products. I have 12" long sticks, they also come in 18", so if you have a console or just don't want to reach down then the longers ones are a good option.
RiverandSand is offline
post #7 of 23 Old 12-13-2019, 11:34 PM
RedNeckCorvette
1979 CJ7
Nice work John. Very nice.
RedNeckCorvette is offline
post #8 of 23 Old 12-14-2019, 10:23 AM
STJP
From John: My preference is to go with taller ones. Having them on the passenger side makes for a long stretch.
Pardon this "DUH!" question, but speaking of longer sticks; will the taller 1980 Dana 300 shifter create any issues if used with a 1985 dana 300 with stock 258 and T5? My thinking is the slightly shorter output shaft of the stock 1980 dana would not change the position of the shifter. I have wondered why the 1980 tall Dana shifter is rarely mentioned as a single stick upgrade.
JS
STJP is offline
post #9 of 23 Old 12-14-2019, 03:04 PM
John Strenk
1976 CJ5
JS
Depends which transmission you are hooking it up to I guess. The T-5 pushes the t-case way back.
What you see in the picture is a 1980 T-176/Dana 300 shifter (the long one) a 1984 T-176/Dana 300 shifter (the short one.)
Originally I had a T4/Dana 300 shifter and it moved the t-case shifter forward so it was inline with the T-176 shifter. This one got very close to the dash.
If you use a 1980 T-176/Dana 300 Shifter with a T-4 or T-5, it will probably sit back too far and not fit through the tunnel cover.
Did they have a T-5 or T-4 in 1980?
You could probably heat and bent the shifter to fit though or cut a couple of inches out your floor. .
post #10 of 23 Old 12-14-2019, 09:44 PM
DUX4LIFE
1977 CJ7
When I ordered mine from JB Fab I had a few questions and he answered them without a hitch. I told him I was doing a SBC swap and going with a 4L60 tranny. I also told him I planned on a 2" body lift and he said that he would put a bend in them and adjust the length. They worked perfectly the first time. And the price was much cheaper than I could imagine...
A Nation of Sheep Breeds a Government of Wolves!
DUX4LIFE is offline
post #11 of 23 Old 12-15-2019, 12:41 AM Thread Starter
Alabamacj71981
Thanks everybody. JB it is. Still looking at the mods you have to make inside the case.
post #12 of 23 Old 12-16-2019, 09:16 AM
STJP
Thanks John. Just the info I was looking for. Jim Allen's book "Jeep" indicates the T4 and T5 were not offered in 1980 as the T-176 was standard. If I choose to "go tall" I would bend the shifter........cut the tub?...over my dead body
Cheers,
JS
STJP is offline
post #13 of 23 Old 12-16-2019, 12:05 PM
John Strenk
1976 CJ5
Cheers,
JS
Yep, Bend the shifter. Easy if you have a hot enough torch.
I have a T-4/5 t-case shifter at home if you need some measurements.
You would have to bend near the eye and the bend on the top.
post #14 of 23 Old 12-16-2019, 08:57 PM
STJP
John,
A very kind offer. I have a T5 t-case shifter....somewhere. I'll dig it out when the time comes.
Thanks again,
JS
STJP is offline
post #15 of 23 Old 12-17-2019, 06:39 PM
tevans59
tevans59's Avatar
1979 CJ7
This mine but it’s not a true twin shifter. I did not remove the detent balls, i made the change cause I was changing ripped shifter boots on the T176/300 every year. Mine are a little forward than I would like but it will stay that way cause a new floor plate is 80$. I do like the little changes that you get over a single shifter.
tevans59 is offline
