Turns signals dont work hazards do - JeepForum.com
post #1 of 16 Old 12-28-2019, 03:46 PM Thread Starter
agear
Okay my problem has been intermittent. 1 time the turn signals work and then later they dont. My hazards work. I grounded the grille wire on the passenger side and the wire that's on the drivers side to the battery. And verified continuity between them. Hazards illuminate all the lights they should , front grille , front fenders and tail lights. I hooked my test light to both terminals inside the front grille lights and the one of the two terminal flashed my test light when hazards were on but nothing when turn signals were on. If all these lights work then I dont see why it would be a ground issue but I dont know. I had my hand on the turn signal switch connector squeezing the wires but nothing came one. I also hear what I guess is my flasher click when I turn on either signal. What do you think ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 16 Old 12-28-2019, 04:25 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Turn signal flasher, turn signal switch, or a corroded connection somewhere would be my guess.
Matt
Matt1981CJ7 is offline
post #3 of 16 Old 12-28-2019, 04:46 PM Thread Starter
agear
I wonder which wires go where so I can try to jump the wires to power
agear is offline
post #4 of 16 Old 12-28-2019, 04:58 PM
Matt1981CJ7
1981 CJ7
Do you have a TSM? The wiring diagrams are a good place to start.
Matt
post #5 of 16 Old 12-28-2019, 05:00 PM Thread Starter
agear
Matt
Yeah, no I dont. I wish I could see your attachment but cant view much of them on this forum .
agear is offline
post #6 of 16 Old 12-28-2019, 05:09 PM
Matt1981CJ7
1981 CJ7
agear,
With all the tinkering you seem to do on your CJ, you really need a TSM. Here is a link to the 1982 TSM. I like it much better than the '84-86 TSM.
Download each section to a folder on your computer. Then you will always have it. I use the alphabetical index to find which section has the info I'm looking for.
Matt
post #7 of 16 Old 12-28-2019, 05:18 PM Thread Starter
agear
Sweet ! It worked. Thanks for that
agear is offline
post #8 of 16 Old 12-29-2019, 06:15 AM Thread Starter
agear
Tried a new flasher no dice
agear is offline
post #9 of 16 Old 12-29-2019, 08:25 AM
Matt1981CJ7
1981 CJ7
I'd trace the power from the turn signal switch to the flasher, then from flasher to turn signals. Somewhere along the line you are losing power, assuming all your grounds are good.
FYI, the turn signals ground thru the special shouldered screws that hold the TS housing to the grill.
Matt
post #10 of 16 Old 12-29-2019, 01:21 PM Thread Starter
agear
Matt
Thanks pretty much what mechanic told me to do. We went kinda around our elbow because all along the flasher i replaced was for my hazards. My t.s. flasher is not mounted to the fuse panel but just hanging along the harness. Thanks guys. I also found a dim headlight which was a dirty chassis ground. Thanks again. Always something on mine.
agear is offline
post #11 of 16 Old 12-30-2019, 02:37 PM Thread Starter
agear
What do the front fender turn signals get grounded to. If I remove the front grille turn/parking light the fender light will not come on. But if I put that turn signal on it will stay on solid not blinking.
agear is offline
post #12 of 16 Old 01-01-2020, 09:23 AM
Spieg8
1984 CJ8
The grill and fender lights are on the same weird circuit (kinda wired in series). You aren't using LED bulbs by chance are you? Do they behave any differently with the parking lights on/off? I assume the rear signals are working okay?
It's not the Voltage, but the Amperage that will kill you.
Spieg8 is offline
post #13 of 16 Old 01-01-2020, 09:31 AM
Matt1981CJ7
1981 CJ7
This may help to understand the TS/Parking light circuit.
Compliments to John Strenk.
Matt
post #14 of 16 Old 01-01-2020, 11:08 AM Thread Starter
agear
Matt
I would like to see it. Cant see 75% of the pictures on here
agear is offline
post #15 of 16 Old 01-01-2020, 11:25 AM
Matt1981CJ7
1981 CJ7
Time to upgrade your browser, bud. It's difficult to help you, if you can't see attachments.
Matt
