Turn signals turn on but dont blink - JeepForum.com
post #1 of 7 Old 02-26-2006, 09:21 PM Thread Starter
JDGordon
Guest
I replaced the tail light assemblies, the original ones were cracked and broken.
The connector plug on the new lights did not match up with what was on the Jeep so I cut the wires and spliced it all together with crimp type connectors.
The tail lights work when I turn on the head lights, also when I press the brake pedal and shift into reverse.
They dont blink on and off when I flip on the turn signals.
They light up and stay on.
Does anyone know how to fix this?
Thanks,
Jon
JDGordon is offline
post #2 of 7 Old 02-26-2006, 09:45 PM
kaibab
check the blinker solinoid
kaibab is offline
post #3 of 7 Old 02-26-2006, 11:58 PM
Geer_hed
Guest
Do the front signals blink appropriately?
If not, did they blink before you replaced the rear turn signal housings?
How about the speedo cluster turn signal indicators? Do the come on AND flash?
When you say the rear signals "come on", do they get bright and stay that way as if the brakes were being applied, or do they just come on as if the marker lamps were on?
If none of your turn signals flash, but they all come on, then yeah I'd start with the thermal flasher like kaibab suggested, but if the front and cluster indicators flash, while your rear signals do not, that suggests a wiring issue OR - and you wouldn't be the first to do this - you're not using dual-filament 1157 bulbs. Without the second filament, there's nothing to "flash". Just a thought.
Geer_hed is offline
post #4 of 7 Old 02-27-2006, 08:49 AM
Mud Machine
Mud Machine's Avatar
Try running a temporary ground wire from the taillight to the frame and see if they work. If so make it permanent.
BDS Springs, MetalCloak Arms, Fox Shocks, Warn Winch, Savvy Ft Bumper, Antirock, GenRight Fenders, GR8 Top, 35" Pittbulls, 5.13's, Revolution Axle Shafts, LS/6.0, 4L80e
'76 CJ-7, 33" Swampers, 6-Point Cage, 4-Speed, Dana 300 Twin Stick
Mud Machine is offline
post #5 of 7 Old 02-27-2006, 10:33 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Sounds like the ground didn't hook up through the mounting holes.
If the mounting bolts are the ground then scrape some paint or rust away from the mounting points and see if it is better.
If that's the problem then conside running the wire as MudMachine suggested because you will have ground problems later on and the wire may help.
Luck,
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #6 of 7 Old 02-27-2006, 12:55 PM
Rockram1
If front and rear light up replace the flasher unit. Little round silver thing under the dash on the fuse block. About 1" in diameter.
86 CJ7, 258, t18, D300, D44's 4.56's, Detroit front, Warn shafts and CTM joints, spool rear, SOA, SRS, waggy springs, 6 point cage, Warn winch, 38" Tsl, Allied beadlocks.
Rockram1 is offline
post #7 of 7 Old 02-27-2006, 05:17 PM Thread Starter
JDGordon
Guest
Yes the front and rear did light up, just stopped flashing.
I bought a "flasher" during lunch hour today, and I just got home from work and installed it.
The blinkers are blinking now!!!!!!
Thanks a bunch for all the responses!!!!
Regards,
Jon
JDGordon is offline
Left turn signal won't blink meater Jeep CJ Forum 5 12-21-2009 09:01 PM
85 CJ 7 no turn signals ronin2336 Jeep CJ Forum 2 10-29-2008 02:54 PM
Turn signals TATTER67 Jeep CJ Forum 10 02-06-2008 11:16 AM
turn signals - now what? Gummo Jeep CJ Forum 6 09-06-2007 07:29 PM
turn signals boosteddsm Jeep CJ Forum 2 06-23-2004 10:14 AM
