Transmission Help - JeepForum.com
 2Likes
  • 2 Post By jeepdaddy2000
post #1 of 6 Old 09-27-2021, 02:29 PM Thread Starter
Ken Tull
1976 CJ7
Transmission Help
I have a 76CJ7 that the transmission fluid will come out of the dip stick when cranking some times and if i drive a while seems like it boils out through the same tube.
Ken Tull is offline
post #2 of 6 Old 09-27-2021, 08:39 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
The OIL DIPSTICK????
Manual or automatic tranny?
Why do you think it's tranny juice coming out?
----JEEPFELLER
JEEPFELLER is offline
post #3 of 6 Old 09-27-2021, 08:57 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
----JEEPFELLER
76 CJ7 with an auto would have a turbo 400.
I would suspect one of two things. Either the vent tube is blocked or the transmission is overfull.
houstoniancj and mudbfun like this.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #4 of 6 Old 09-28-2021, 02:41 AM
mudbfun
1973 CJ5
You are checking the fluid level when it is hot, right? You might also inspect your transmission cooler lines to make sure one isn't damaged and causing a blockage.
mudbfun is offline
post #5 of 6 Old 09-28-2021, 04:56 AM
houstoniancj
houstoniancj's Avatar
Check the vent tube first for dirt daubers nest or anything like that. Its on the top right side looking down from above, super easy to get to with the shifter cover removed.
IF all good with the vent,
I would recommend a drain and refill. Typically an auto transmission barfing fluid is from an overfill.
Just remember to refill until it just hits the dipstick then let it warm up and check the fluid level on level ground with the engine running as you do your final fill.
1985 Jeep CJ7
houstoniancj is offline
post #6 of 6 Old 09-28-2021, 05:33 AM
jeepdaddy2000
1971 CJ5
There is also a procedure.
Idling hot:
Set the parking brake.
Starting in park, run through each gear slowly, all the way down to low, then back to neutral. Check the level there.
Chesty Puller
