Transmission Drain Plug Leak - JeepForum.com
 4Likes
  • 1 Post By Rsb201
  • 2 Post By keith460
  • 1 Post By PJM86
post #1 of 11 Old 06-25-2019, 02:41 PM Thread Starter
PJM86
PJM86's Avatar
I have an 86 cj7 with Borg Warner T5. The drain plug is leaking and wondering best solution. Iíve tightened it, still leaks. Wouldnít be a big issue, but it leaks about teaspoon a week or so. It also runs down tranny onto skid plate and makes a mess. Thinking of draining, using some rtv, and then refilling after it sets up. Good idea, or bad? Appreciate the help..
PJM86 is offline
post #2 of 11 Old 06-25-2019, 06:46 PM
Rsb201
Rsb201's Avatar
Teflon tape may seal it off
baldfatdad likes this.
1986 CJ7 4.2 Weber T176 D300
Rsb201 is offline
post #3 of 11 Old 06-25-2019, 09:46 PM
acgcoug
acgcoug's Avatar
1979 CJ5
I use Permatex Super 300 on the threads of drain/fill plugs. It has other good uses as well. It is non-hardening.
https://www.amazon.com/Permatex-8005.../dp/B000HBI9DM
_________________________
Adam's 1979 CJ5 Frame-up build:
acgcoug is offline
post #4 of 11 Old 06-25-2019, 10:24 PM Thread Starter
PJM86
PJM86's Avatar
I will try both, thanks.
PJM86 is offline
post #5 of 11 Old 06-26-2019, 04:30 AM
keith460
Jeep. There's Only One
keith460's Avatar
The plugs are standard pipe threads so they are tapered. Teflon tape should be all you need.
Sent from my iPhone using Tapatalk
baldfatdad and pedal2themetai like this.
1984 CJ-7 Renegade
keith460 is online now
post #6 of 11 Old 06-26-2019, 10:11 AM
EricRThompson
1979 CJ7
Permatex makes a sealer specifically for transmission fluids. Try this:
https://www.permatex.com/products/ga...-gasket-maker/
EricRThompson is offline
post #7 of 11 Old 06-26-2019, 11:38 AM
rbunch4468
1983 CJ5
I know you said transmission plug leak... but... I also battle collection of leaky fluids in the crossmember. I have a 258, which like to leak at the rear of the valve cover. Is it possible that both the valve cover and tranny drain plug leak? Just sayin...
rbunch4468 is offline
post #8 of 11 Old 06-26-2019, 11:47 AM
baldfatdad
1984 CJ8
I haven't fooled with stick tranny's for years so I could be wrong. Does it have a vent? Check to see if its clogged that could help cause a leak.
baldfatdad is offline
post #9 of 11 Old 06-26-2019, 11:48 AM
tdagner
1980 CJ5
Teflon tape or maybe some pipe dope from the local hardware store.
tdagner is offline
post #10 of 11 Old 06-26-2019, 07:29 PM Thread Starter
PJM86
PJM86's Avatar
Appreciate all the help, I drained the transmission this evening, used the Teflon tape (as per Keith and couple of the other forum members), refilled it with penzoil synchromesh, took it for a spin and got it nice and hot, came home parked it for an hour or so and no leaks. Think I fixed it. Thanks for the advice.
Rsb201 likes this.
PJM86 is offline
post #11 of 11 Old 06-27-2019, 04:27 AM
keith460
keith460's Avatar
Originally Posted by PJM86 View Post
...refilled it with penzoil synchromesh...
Penzoil Syncromesh, good oil and is what I been using for the last 8 years driving around. Shifts are as smooth as butter.
1984 CJ-7 Renegade
