TRANSFER CASE making a clicking/grinding noise when moving - JeepForum.com
post #1 of 3 Old 12-05-2019, 01:46 PM Thread Starter
calebcj7
1977 CJ7
Cj TRANSFER CASE making a clicking/grinding noise when moving
VIDEO OF THE NOISE:
Hey guys, I have 1977 Jeep CJ7 with a DANA 300 t-case and a T150 tranny. Just finished swapping in a 304 and took it out for a test drive and heard a grinding noise coming from what i thought was the tranny, so I changed the fluid and the noise went away in 2wd only, so I knew it was a t-case problem. Then it started grinding in 2hi as well as 4hi and 4lo. I changed the t-case fluid and it came out a a light brown color, but didnt look too bad, also no metal flakes and rubbed my finger in it with no grit.
So I am assuming its not internal since there is no metal in the gear oil?
I checked the u-joints and they seem okay, but i honestly dont know how to inspect them that well other then them having a cap falling off or something obvious. Linkage is pretty loose a lot of play in the T-case lever when in gear so maybe thats it? goes into gear pretty easy though if im moving.
Also I put the t-case in neutral and ran it through the gears with no noise so I know its not the tranny.
Any help would be appreciated!!!!!
calebcj7 is offline
post #2 of 3 Old 12-05-2019, 02:19 PM
John Strenk
John Strenk's Avatar
1976 CJ5
It's probably a dana 20 t-case on the back of the T-150.
You could probably drop the pan off the t-case for a visual inspection.
I've heard a similar sound like when I wasn't fully in engaged in one range or the other.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #3 of 3 Old 12-05-2019, 08:59 PM Thread Starter
calebcj7
1977 CJ7
Ok, yea it probably is.
So what would be causing it to not be fully engaged? Could it be a hub issue, I had the passenger one of recently to do a u-joint up front, and realized i never even put in 4wd after that to test it, maybe i re-assembled it wrong?
I appreciate the quick response
calebcj7 is offline
cj7 , dana300 , grinding , jeep , transfer case
