Tranny help? - JeepForum.com
 3Likes
  • 1 Post By Tinker0000
  • 1 Post By jeepdaddy2000
  • 1 Post By 80cj
post #1 of 13 Old 03-05-2020, 06:29 PM Thread Starter
thejeepman23
1980 CJ7
Tranny help?
So I popped my clutch (while in first gear) ... and instead of stalling, the engine kept running despite being in gear. Now, no matter what position the gear shift is in (including reverse), it feels like I'm in neutral.
Pushing in or letting out the clutch has no effect. Zero gears engaging. Anyone have an idea what I might've broken?
★1980 CJ-7 ★AMC 360 ★T176 4 speed
thejeepman23 is offline
post #2 of 13 Old 03-05-2020, 06:36 PM
Tinker0000
Junior Member
Check to make sure your transfer case didn't pop into neutral?
OrangeCJ-5 likes this.
Tinker0000 is offline
post #3 of 13 Old 03-05-2020, 06:41 PM Thread Starter
thejeepman23
1980 CJ7
Good thought, Tinker. I should've mentioned that I already verified that didn't happen. Thanks.
post #4 of 13 Old 03-05-2020, 07:09 PM
Fourtrail
1974 CJ6
Spun hub on 2 piece rear axle shaft. Lock in the front hubs and put it in 4wd and see if it moves.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #5 of 13 Old 03-05-2020, 07:57 PM Thread Starter
thejeepman23
1980 CJ7
Thanks Fourtrail. Already tried that too. No dice.
post #6 of 13 Old 03-05-2020, 08:23 PM
80cj
80cj's Avatar
1980 CJ5
Wonder if the splines on the trans mainshaft stripped. I've seen those splines get pretty worn (ramped over sorta). The one pictured here is in good shape.
80cj is offline
post #7 of 13 Old 03-06-2020, 05:54 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
1 Broken hub on clutch disk. This is usually accompanied by a grinding or rattling noise.
2 Blown input/counter shaft. Knocking teeth off the input/countershaft will give you nothing but 4th gear. Might try starting in 4th and see if it engages.
3 Broken shifter. Can you feel the rails moving through the shifter?
In the end, you may need to pop the transmission lid and see what is and isn't turning in there. Be careful, engaging the clutch while the engine is running and the lid is off can spray oil all over the interior. You will have to slowly engage the clutch to do your observation.
If all is good, then you may need to do the same with the t case.
John Strenk likes this.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #8 of 13 Old 03-06-2020, 08:05 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Or just snapped the output shaft.
In the end you are going to have to remove the top to see what is moving and what is not.
I've heard the output shaft on the dana 300 is weak but if that broke then you should still move in 4WD and front hubs locked.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #9 of 13 Old 03-06-2020, 10:16 AM Thread Starter
thejeepman23
1980 CJ7
JeepDaddy2000 ::: Thanks for the thoughts.
1 :: There's no grinding or rattling.
2 :: I'll try the 4th gear thing, but if I recall none of the gears had any effect.
3 :: I can feel the rails moving with the shifter like "normal" but nothing ...
Jesus. Wife. Kids. CJ. ★80 CJ7 Golden Eagle ★AMC 360 ★5.5" Suspension/Shackle Lift ★35x12.5 BFG Muds
post #10 of 13 Old 03-06-2020, 10:19 AM Thread Starter
thejeepman23
1980 CJ7
80cj ::: Could they all strip at once? Wouldn't I hear grinding? I hear nothing (like it's in neutral) even though my sick shift is "in gear."
post #11 of 13 Old 03-06-2020, 10:21 AM Thread Starter
thejeepman23
1980 CJ7
John ::: Would that result in the symptoms I'm describing? I've still got nothing in 4WD with the hubs locked.
post #12 of 13 Old 03-06-2020, 10:41 AM
John Strenk
1976 CJ5
Yes, no connection between the tranny and the t-case so no movement despite what gear your in.
It would be like the t-case being in neutral.
Waiting to see your 4th gear results.
post #13 of 13 Old 03-06-2020, 11:54 AM
80cj
80cj's Avatar
1980 CJ5
I saw a pic of a trans mainshaft that had broken off in the turned down area ahead of the splines. Don't know how often that happens. Can't understand why they reduce the diameter of the shaft so much.
80cj is offline
