Tow Hooks - JeepForum.com
 5Likes
post #1 of 24 Old 09-12-2019, 07:50 PM Thread Starter
BagusJeep
BagusJeep's Avatar
1981 CJ7
Tow Hooks
STJP asked me some time ago about the tow hooks on the front of my CJ7s following a Windshield Frame post where I included a picture of the front of one.
They were supplied in Indonesia as standard with CJ7s in the early 80s and are, as far as I can tell, Jeep part no. J536 2504-5
Well, John asked me to keep my eyes open for them and I spotted on lazada.com in Malaysia a set of "China OEM" brand tow hooks, sold by Carpartsmy.. They were roughly US$13 each. I bought all the stock of 3 to go on my 1951 CJ3A.
This price undercuts the weak looking hooks from Rugged Ridge by a lot.
Waiting to see what they are like, i distrust the chicomm.
Jim1611 likes this.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #2 of 24 Old 09-13-2019, 12:29 AM
keith460
keith460's Avatar
Any close up, clear pictures? Always wanted to know if the mounting hole spacing was same as CJ frame.
1984 CJ-7 Renegade
keith460 is offline
post #3 of 24 Old 09-13-2019, 02:21 AM Thread Starter
BagusJeep
BagusJeep's Avatar
1981 CJ7
They are the same as my CJ frame!!!!
I may have them off Bagusjeep in the next few weeks as i am sending them and the bumpers to paint. I will pic and measure
post #4 of 24 Old 09-13-2019, 09:53 AM
X-Army
X-Army's Avatar
1979 CJ5
Does this help? Maybe not...mine are at least mounted differently; still factory, tho.
X-Army is offline
post #5 of 24 Old 09-17-2019, 11:10 PM Thread Starter
BagusJeep
BagusJeep's Avatar
1981 CJ7
So, as I suspected, the ChiComm have supplied a part that does not fit the description. Where is the chrome????:
post #6 of 24 Old 09-17-2019, 11:17 PM Thread Starter
BagusJeep
BagusJeep's Avatar
1981 CJ7
Described as a 10,000 lb capacity hook it came with 2 No. M12 Grade 4.8 bolts x 60mm lg (25mm shank) and 2 washers. In shear they will take about 2,900lbs each. Do the maths.................
8.8 grade bolts will take about 7,300 lbs each, so they need changing or that hook will become a missile.
Distance of bolt holes is 35mm.
To be honest, pretty much what I expected from the Chicomm. I was going to paint them so not worried about lack of chrome, but they will need to be tested somehow when the new bolts are found..
post #7 of 24 Old 09-18-2019, 07:21 AM
Jim1611
Jim1611's Avatar
Bagus does McMaster Carr ship to you? They would have exactly what you need for hardware. https://www.mcmaster.com/ I use them for everything and have always had excellent service. I don't trust the Chicomms either!!
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #8 of 24 Old 09-18-2019, 07:39 AM
Hurricane4
Hurricane4's Avatar
1979 CJ5
Check out these tow hooks:
https://www.mcmaster.com/tow-hooks
For an easy towing connection, mount these hooks to a bumper or trailer. Maximum trailer weight is the total weight being towed.
Note: Capacity is reduced 25% in off-road use.
3D CAD models availableFor technical drawings and 3-D models, click on a part number.
Overall
Mounting
Hole
For Max.
Trailer Wt., lbs. Dp. Ht. Material Hook
Opening Wd. Dia. Ctr.-to-Ctr. Mounting
Plate Thick. Each
10,000 3 1/4" 5" Steel 1 5/8" 1/2" 1 3/8" 1" 2589T9 $11.91
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is offline
post #9 of 24 Old 09-18-2019, 07:22 PM Thread Starter
BagusJeep
BagusJeep's Avatar
1981 CJ7
impressive website and good prices, but how do you know they are not the same Chi Comm product?
This is my problem, the supply chain around the world is corrupted with cheap Chinese crap. I have worked in China and i know how it happens, very attractive pricing on sub standard parts leads to importers believing there is a profit to be made, goods are not tested, exporter cuts corners and the Chinese demand payment before shipping. Resellers in good faith pass on substandard products. Result is resources wasted, when a little bit more care could have produced a good product.
There is nothing to stop a workshop in Wuhan from taking McMaster's nice drawings and casting 20,000 tow hooks of pig iron, slapping some paint on and rating them at 10,000 lbs for export. Someone dies, no comeback.
i am going to proceed and then try to pull out a tree stump under controlled conditions.
post #10 of 24 Old 09-18-2019, 08:38 PM Thread Starter
BagusJeep
BagusJeep's Avatar
1981 CJ7
Yours may be mounted correctly. Here is the page from the parts manual. There are two additional bolts for each hook, but they may also be holding on the bumper. In which case mine are set back further on the frame.
You also have the tow eyes.
X-Army likes this.
post #11 of 24 Old 09-18-2019, 11:49 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
Bagus - FYI - Tow Hook Made in USA - See response from McMaster-Carr to my inquiry below:
Sent: Wednesday, September 18, 2019 11:43 PM
To:
Subject: Your Tow Hook Inquiry
Hi ,
The tow hook (2589T9) is manufactured in the United States.
Ruth
Winston Churchill
post #12 of 24 Old 09-19-2019, 04:49 AM
keith460
keith460's Avatar
McMaster-Carr sells high quality items and have been using them for both business and personal purchases for close to 40 years. Never had an item that was cheaply made from them, all good quality even down to the tinniest of hardware.
The hooks in the Jeep parts manual are like what Bagus has and always wondered how they utilized existing holes in both the frame and bumper and the spacing between the holes. Automotive manufactures typically use preexisting holes in frames, body structures that have plugs in them or some sort of guide outline so when an vehicle owner buys an approved accessory, it bolts directly on without having to drill any additional holes or a supplied template is included with the accessory for mounting. That's the importance of the hole spacing of the hook which Bagus points out to be 35mm or 1-3/8".
I don't know what the spacing is on my CJ offhand since I'm currently not near it, but there is a guide line on the front frame plastic overlay that gets removed for the installation of of said Tow Hook. I don't have any closeup photo of the front frame overlay at the moment either.
1984 CJ-7 Renegade
keith460 is offline
post #13 of 24 Old 09-19-2019, 05:53 AM
Hurricane4
Hurricane4's Avatar
1979 CJ5
I think the Jeep CJ tow hook bolt center to center is 1 3/8". McMaster-Carr Tow Hook # 2589T9 specifications:
For Maximum Trailer Weight 10,000 lbs.
Overall
Depth 3 1/4"
Height 5"
Material Steel
Hook Opening Width 1 5/8"
Mounting Fasteners Included No
Mounting Hole
Diameter 1/2"
Center-to-Center 1 3/8"
Mounting Plate Thickness 1"
https://www.mcmaster.com/2589t9
etrailer lists the same dimension 1 3/8" hole center to center for the Rampage Tow Hook - https://www.etrailer.com/question-369437.html
Winston Churchill
post #14 of 24 Old 09-19-2019, 07:37 AM
scottyDive
I bought a set of these a couple years back
They were OEM for USMC MB jeeps ifnyou want to Google and here is a sample of what they are. Mine bolted right on and are the real deal. There is a left and a right
https://www.truckspring.com/products...-10050-3B.aspx
Sent from my SM-G960U using Tapatalk
keith460 likes this.
Scott
86 CJ7 Laredo
84 CJ7 Renegade
70 Jeepster
scottyDive is offline
post #15 of 24 Old 09-19-2019, 09:33 AM
X-Army
X-Army's Avatar
1979 CJ5
Nice reference drawing. Interesting that they only show the front bolt...guess you have to stop the illustration somewhere.
Actually, those are my home-made version that work with my tow bar. But they work well for shackles, too.
X-Army is offline
