Tow hitch bar - Help - JeepForum.com
 2Likes
  • 1 Post By CJ7-Tim
  • 1 Post By Axhammer
post #1 of 6 Old 08-25-2019, 08:28 AM Thread Starter
pipesbull1
New to Forum and needing help... Wanted to check with the experts on what tow hitch set would be the best for a 1981 CJ7 jeep. Looking to pull a seadoo.
Appreciate any assistance and suggestions. Have a great day!!!!!
pipesbull1 is offline
post #2 of 6 Old 08-25-2019, 09:49 AM
jurgen24
What does your bumper look like?
Here is my setup, pin behind bumper.
Sent from my iPhone using Tapatalk
jurgen24 is offline
post #3 of 6 Old 08-25-2019, 10:05 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Some CJ trailer hitches mount to the rear crossmember, and some mount to the frame rails. Frame rail mounted hitches are best.
Cutlass327 likes this.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #4 of 6 Old 08-25-2019, 10:27 AM
Axhammer
Axhammer's Avatar
My 1986 CJ-7 came with a factory tow bar that worked fine for me. I towed a three rail motorcycle trailer with a Honda XL600 on it from Mobile AL to Port Angeles WA in the summer of 1986. Then in PA, I towed a 16’ aluminum runabout boat with a 55 HP (three cylinder) outboard motor on it. There were two lakes about twenty miles from town that I used that boat for water skiing every summer. One time, a reservist’s car broke on the way to PA to do his weekend duty, it was a Ford Mustang, I think it was a 1969, but I’m not sure. We rented a uhaul car dolly and I towed his Mustang on that dolly, from Sequim WA to his house near Seattle using my CJ-7. It had a all stock 258, manual 4 speed with overdrive, and 411 gears on 31’s at the time.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is offline
post #5 of 6 Old 08-25-2019, 01:18 PM
trailhead2004
trailhead2004's Avatar
1980 CJ7
My recommendation is to avoid any hitch which is primarily attached to the rear cross member. While my circumstance is different than you described (towing the Seadoo), the rear crossmember isn’t ideal for attaching a hitch.
My circumstance was towing a heavy trailer with a bit of tongue weight and also putting a dirt bike on a Joe Hauler. My hitch is built into the bumper which was bolted to the rear crossbrace. The weight on the hitch torqued the bumper down and started to crack the mounting holes in the crossbrace. I will be replacing the crossbrace when I get back to the frame work on my rebuild.
Obviously, it was a user error, but others may think the crossbrace can handle it but it can’t.
trailhead2004 is offline
post #6 of 6 Old 08-25-2019, 04:19 PM Thread Starter
pipesbull1
I don't have it at my house. Appreciate your help.
