TJ Skid with YJ tank in a CJ - JeepForum.com
post #1 of 11 Old 09-17-2018, 09:59 AM Thread Starter
nickmorris27
nickmorris27's Avatar
First post here...
Just wondering if anyone has done this or what would need to be done. If this doesn't work, I may go about making my own.
1st- I am wondering if a Warn TJ gas tank skid plate will hold a 90's YJ plastic 20gal tank. I could get a TJ tank, but would that fit?... I do have 1" body lift.
2nd- Will a TJ gas tank skid fit a CJ7 frame? Exhaust can be modified.
Thanks in advance.
nickmorris27 is offline
post #2 of 11 Old 09-17-2018, 10:09 AM
jeepwhore
jeepwhore's Avatar
I think you're putting the cart before the horse......unfortunately the YJ tank is too wide to fit between the CJ frame rails so your questions are kind of moot....Sorry to be the bearer of bad news, lol.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #3 of 11 Old 09-17-2018, 09:45 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Also the filler is in a different position, so a fair bit of work to get it on, even if the frame was big enough.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 11 Old 09-18-2018, 06:18 AM
REDnBLUES
REDnBLUES's Avatar
1977 CJ7
I have a YJ tank in mine using a CJ skidplate. I used a MTS replacement tank for an early YJ 4 cylinder when I went fuel injection, and yes it fits.
Sorry I can't comment on the TJ skidplate though.
Sent from my SM-T230NU using Tapatalk
1977 CJ7 - LT1/700R4 Project
2015 JKU Rubicon Hard Rock - stock
2013 JK Sahara - gone
REDnBLUES is offline
post #5 of 11 Old 09-18-2018, 07:33 AM
jeepwhore
jeepwhore's Avatar
That would be a YJ 15 gal. tank, not the 20 gal being asked about though.
post #6 of 11 Old 09-18-2018, 08:08 AM Thread Starter
nickmorris27
I currently have a YJ tub and left the gas filler on the driver side. I am currently using an early YJ metal 15gal tank that is similar to the CJ 15 gal tank with CJ skid. No fuel pump in the tank and filler necks are on the driver side. Now I am doing a 4.0L swap and got a 15/20 Gal (same footprint) plastic YJ tank with it since i need fuel pump. I liked the idea of having an internal factory pressure pump. I thought the frame rails had the same inner dimensions in the rear. I know the front is different. Does anyone know the size difference. I guess the question now is that..
post #7 of 11 Old 09-18-2018, 10:28 AM
Bobs85Reny
Bobs85Reny's Avatar
I have both a yj and cj's. The yj we are doing exactly what you are looking to do. It has the 20 gal tank with the mts fuel system. I can give you some measurements tonight but there is no way that tank would fit in the cj frame. even using a yj tub.
Told my girl I just had to forget her, Rather buy me a new cartburettor,
So she made tracks sayin' ths is the end now, Cars don't talk back they're just four wheeled friends now
"Queen"
Bobs85Reny is offline
post #8 of 11 Old 09-18-2018, 10:33 AM
Bobs85Reny
Bobs85Reny's Avatar
here is a link for what we did so far.
https://www.jeepforum.com/forum/f12/...grade-4118161/
"Queen"
post #9 of 11 Old 09-18-2018, 11:06 AM Thread Starter
nickmorris27
Thanks Bobs85Reny
I think I'm going to get the fuel pump for the 15gal sending unit and add it the the existing unit in the tank.
Not the direction I was hoping for, but I guess I'm kinda stuck here.
post #10 of 11 Old 09-18-2018, 09:42 PM
REDnBLUES
REDnBLUES's Avatar
1977 CJ7
Oops, missed that. Sorry guys
Sent from my SAMSUNG-SM-G890A using Tapatalk
post #11 of 11 Old 09-18-2018, 11:30 PM
jeepwhore
jeepwhore's Avatar
The difference in width at the rear is equal to the thickness of both frame rails. On a CJ, the outside of the frame rails lines up with the sides of the inner wheel well. On a YJ, it's the inside of the frame rails that does.
cj , gas tank , gas tank skid , gas tank skid plate , tj
