Time for a Dana 300 rebuild :( - JeepForum.com
post #1 of 3 Old 11-02-2020, 07:25 PM Thread Starter
Horatio
1980 CJ7
Swapped the fluids and found quite a bit of metal on the magnetic drain plug. Any guesses where it could be coming from? I hear a low and rhythmic grinding sound coming from the area of the 300. It seams to have gotten slightly better after the fluid swap. Input/output shaft bearings?
Horatio is offline
post #2 of 3 Old 11-03-2020, 09:47 AM
oldschool74cj5
hello
its probably a bearing that is going bad. have you ever flat towed it with the rear driveshaft still installed. that has a tendency to take out the output shaft bearings. the only good thing is the d300 isnt that hard of a transfercase to rebuild.
oldschool
oldschool74cj5 is offline
post #3 of 3 Old 11-03-2020, 05:54 PM Thread Starter
Horatio
1980 CJ7
Originally Posted by oldschool74cj5 View Post
hello
oldschool
I have never flat towed it, but when I bought it there were shackles attached to the front bumper. So, yes, it was likely flat towed.
Horatio is offline
