For Those who installed an H1 box... - Page 11 - JeepForum.com
 15Likes
post #151 of 308 Old 01-22-2014, 07:21 PM
Viencent
1982 CJ7
Yes upgrade the brackets. Did mine two months ago and didn't. Now my bracket broke waiting for it to get here.
Viencent is offline
post #152 of 308 Old 01-23-2014, 09:43 AM
78FordF150
78FordF150's Avatar
1983 CJ7
Yes I think im just going to go ahead and order the braket and be done with.
Measure with a Micrometer
Cutter with an ax
Beat it to fit
Paint it to match
My NP435 install
78FordF150 is offline
post #153 of 308 Old 11-12-2014, 10:38 AM
AlexThePhotoGuy
I know this is an older thread, but wanted to let everyone know I just ordered an H1 box from JCWhitney online for $152 (with a coupon code found online). With the core return, ends up being $122 if I actually decide to return it. I was thinking about doing a J20 upgrade on my CJ7, but with the bell coupler it would have been the same price as the H1.
Waiting on UPS now!
AlexThePhotoGuy is offline
post #154 of 308 Old 03-14-2015, 04:53 PM
jorns
Originally Posted by keith460 View Post
[B]Comparing the two gearboxes
The input shaft size and spline count are the same for both units. This is the area that counts when swapping out different steering gearboxes and was the reason one should use the Hummer H1 unit over the popular J20 unit.
Both gearboxes have 13/16" diameter input shafts with 32 splines each.
Hi.
I am doing the swap, but the umbraco screw broke on the Borgersom steering shaft so i have to buy a new u-joint to my steering shaft.
But, i am not sure what size to buy, is it correct that the splines on the inputshaft on the steering box is 32? I cant find that count on the Borgerson website.
(I am swaping a oem power steering gearbox with the H1 box)
UPDATE:
I sent Borgeson mail and they said that it is 36 splines on the 86 Cj7 w/power steering. They told me to order the vibration reducer #034940 ( 3/4DD X 13/16-36 )
1986 Jeep Cj7, 258CID, Dana300/30/44, Automatic, frame off 2010/11.
jorns is offline
post #155 of 308 Old 03-15-2015, 03:38 PM
nosheep
1983 CJ7
eyeing this thread I need to swap my gear box I Have a MORE HD mount/brace and a new pitman arm to go in as well but don't know If I should go stock box or H1.
EDIT: I want to go with the H1 box what's the best place to get one at this time?
nosheep is offline
post #156 of 308 Old 04-12-2015, 10:50 AM
nosheep
1983 CJ7
^---update:
I just finished yesterday installing H1 gearbox I had a bit of trouble locating one and went with a 2001 H1 box from autozone for a tad less then $200 after core.
The box came with new O rings for my power steering lines and they actually fit so I used them. I installed the Zinc plated HD mount from MORE and there brace kit. I installed a new HD steering shaft Borgeson with vibration reducer from morris Thanks to them I got a discount code in my E-mail and deleted it by mistake before my order and I asked the guy in chat if he could hook me up and he did give me the code for $10 off so thanks morris. Everything bolted right in fairly smooth (Its a jeep so it betrayed me a tad) . I bleeded the system and started the motor to find no leaks but have not driven yet due to my jeep running like crap and stalling while cold, kinda leaning to a howell problem to lean while cold. Idles great when fully warm.
nosheep is offline
post #157 of 308 Old 05-26-2015, 05:41 AM
jorns
I did this swap a month ago.
The Jeep feels way bether, but i have noticed that there is a slack in a couple of millimeters between the 13/1 to 16/1 gear when i am driving on the highway. I thought this should be a smooth transition, but i have to turn the steering wheel a couple of mm to make it turn again.
This is when i turn both to left and right.
Have anybody noticed this? Or is it my H1 gear box that is defect?
-jorns
jorns is offline
post #158 of 308 Old 05-26-2015, 02:44 PM
jeepwhore
jeepwhore's Avatar
A couple mm's could've anything from slop in the steering shaft to ball joints, bearings or tie rods. It could even be something as small as tire flex. I would doubt there is anything wrong with the box. If you are looking for steering that tight you won't find it in a jeep.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #159 of 308 Old 01-04-2016, 05:28 PM
jay5.9l
Thanks for the great thread. I did the H1 box repalcement on my 86 CJ7 with a HD steering mount/brace etc. Works great and feels tottaly different than the old stocker that leaked constantly. The new o rings in the kit stoped the leaking and it feels so much safer. Takes a little more effort than the old box but that could be from the axle swap and bigger tires.
Best price I fould was Advanced auto. After core exchange I was under $200.
jay5.9l is offline
post #160 of 308 Old 01-04-2016, 06:57 PM
keithcj-7
1978 CJ7
pitman arm ?
So I also did the H-1 gear box and would like to run a Borgerson bendable pit man arm as my old one had to go with the return (1978) and if so does anyone have a part number for a 6" center on center. Thanks Keith.
keithcj-7 is offline
post #161 of 308 Old 04-01-2016, 03:46 PM
Colt44
Colt44's Avatar
1983 CJ7
Getting ready to replace my steering gear with the H1 part and thought I'd go ahead and replace the hoses, and probably the pump too.
But nothing is ever easy in the world of CJ.
I go to the NAPA site to order hoses, and I'm presented with the option for hoses (both pressure and return) with and without "Electrical Switch Port" whatever that is.
What's that all about, and which hoses to get?
"Let all the laws be clear, uniform and precise:
To interpret laws is almost always to corrupt them."
~ Voltaire
Colt44 is offline
post #162 of 308 Old 04-01-2016, 07:10 PM
j33pman
j33pman's Avatar
I have no idea what kind of electrical switch port they are talking about, so my thought would be to get the one without.
Bill H. - 1984 CJ-7
Now with Fiberglass!
j33pman is offline
post #163 of 308 Old 04-02-2016, 04:58 AM
keith460
keith460's Avatar
The hose with the electrical switch port was for the 4 cylinder equipped CJ's. The switch would energize a solenoid to bump up the idle speed when the steering wheel was turned full lock. Pressure would increase and stall the engine without it.
If you have a L6 or V8 engine, you don't need it and never had them.
1984 CJ-7 Renegade
keith460 is offline
post #164 of 308 Old 04-02-2016, 11:41 AM
STJP
colt,
to buy or see and compare, check out the pressure hose and return hose for your Jeep (1983) here:
http://www.morris4x4center.com/jeep-...-scrambler.htm
JS
STJP is offline
post #165 of 308 Old 04-02-2016, 11:52 AM
STJP
click on No. 11 "pressure hose" and will take you to a list. The return hose is there also.
Cheers
JS
STJP is offline
