Temperature sensor/gauge wiring - JeepForum.com
post #1 of 7 Old 06-13-2010, 03:45 PM Thread Starter
cer
A little background. I have an 85 CJ7. I have owned it for about a year. As long as I have owned it, the temp gauge has never worked. A couple of months ago, I replace the sensor, hoping that it would be a quick fix. No luck.
I am not overly mechanical and I am definitely not an electrician. I have viewed the link form John on the basic troubleshooting for CJ gauges a couple of times, but I had never jumped in. I decided this weekend that would give it a try. I checked power to the speedomter and it checked out fine.
As I was following wires through the firewall, checking connections, etc. I found a purple /white wire with plug that was not plugged in. It was the same wire color as the wire on the back of the gauge. There was a green wire and plug connected to the temp sensor. The green wire was not hot. I tested the purple/white wire, it was getting power so I gave it a shot. Just like that, the temp gauge was working and seems to be working correctly. Also, in my search through the wiring harness, I found an unplugged orange wire.
So my questions are as follows:
1).What in the world is the green wire that was initially plugged into the temp sensor??
2). What does the orange wire go to??
I am attaching a link to a picture of the wiring.
Any help would be appreciated.
cer is offline
post #2 of 7 Old 06-14-2010, 06:43 PM Thread Starter
cer
Anyone have any ideas. I did a quick trace of the green wire and it appears that it terminates at the fuse panel????
I am going to try to dig a little deeper when I get a little time.
cer is offline
post #3 of 7 Old 06-14-2010, 07:31 PM
walkerhoundvm
walkerhoundvm's Avatar
1981 CJ8
I have no idea, but I have the same set of disconnected plugs - albeit in much worse shape than yours.
Checking the Chilton manual, the wiring diagram shows an orange wire, with a light green wire, coming out of the manifold heater/heater relay. The orange wire leads to the heater from the relay, the green wire grounds the relay. It looks like it says "6cyl," but it could be an "8." Either way, I have an aftermarket manifold which explains why mine are disconnected. My light green is paired with a red with a more of a flat-head female connector that I thought went to the hood lamp, but I can't remember. In any case, the manual shows a red leading in to the manifold heater relay.
Now, if you can help remind me what wire goes to the hood lamp, we're even.
-Nick
walkerhoundvm is offline
post #4 of 7 Old 06-14-2010, 08:03 PM Thread Starter
cer
Nick,
Thanks for the help. I dont' have a hood lamp....so maybe that is what the unplugged orange wire goes to???
cer is offline
post #5 of 7 Old 06-14-2010, 09:02 PM
NelsonATC
NelsonATC's Avatar
1980 CJ7
I have the same unplugged orange wire. I too believe it is for the hood lamp.
Mike
1980 CJ7
NelsonATC is offline
post #6 of 7 Old 06-16-2010, 07:41 PM Thread Starter
cer
My confusion continues...
I looked at my buddy's '83 CJ-8 and it appears that on his Jeep, the green wire is connected to a sensor on the side, where mine was originally connected and then the purple / white wire is connected to a sensor on the back of the engine, closer to the dash. I looked at the back of my engine, and did not see a sensor. Like I said before, the temp gauge seems to be working fine, but I am having trouble just letting it go with the green wire disconnected. I do feel fairly confident that the orange wire must be for the hood lamp.
Can any of you wiring experts help me out with the green wire?
cer is offline
post #7 of 7 Old 08-26-2010, 10:30 PM
1982CJ-7
1982 CJ7
This may help as I have been trying to figure out some things tonight myself. I believe the green wire goes to the manifold heater:
Manifold Heater
The purple wire that comes from the temp gauge should go to the coolant temp sensor which according to this is on the back of the head:
http://inlinethumb38.webshots.com/39...600x600Q85.jpg
At least that is what I'm going to try now.
1982CJ-7 is offline
Temperature Gauge gone INSANE!!! CJ8Extreme Jeep CJ Forum 1 10-08-2009 04:11 AM
oil temperature gauge silverbullit Jeep CJ Forum 12 08-17-2009 01:13 AM
temperature sensor mboyd12345 Jeep CJ Forum 4 07-28-2009 08:21 PM
86 CJ7 Temperature Gauge Wiring nokmoutjon Jeep CJ Forum 2 07-06-2008 07:48 PM
temperature gauge thenubsterman Jeep CJ Forum 3 07-17-2005 10:23 PM
