Temp gauge getting 12 volts - JeepForum.com
 2Likes
  • 2 Post By John Strenk
post #1 of 6 Old 03-29-2020, 05:54 PM Thread Starter
Kenscj
Came here and joined to follow John Stenk’s gauge troubleshooting link: am installing new fuel and temp gauges in 84 CJ and temp gauge pegs at hot without engine even running. So, at step 3 of his quick test tutorial, I have constant power, not intermittent at terminal A, (so light on, not flashing). Went to step 3 troubleshooting. Passed ALL the tests. Guessing the resistor is the problem, even though both gauges are brand new. Have been reading lots of posts about similar issues. Don’t know what to try now. Appreciate any suggestions
Kenscj is offline
post #2 of 6 Old 03-29-2020, 05:58 PM
turbogus
1978 CJ5
One thing I noticed about buying these supposedly OE gauges in the last few years is that some of them are either;
a. Damaged in transit, or
b. Chinese knock off design/manufacture that is terrible.
In my case I got lucky in that when I was restoring Black Betty is that Mac of Macs Jeeparts was still alive and had some NOS gauges from AMC that I solved my OE gauge issues. On a sidebar I also added medhanical Auto Meter gauges above the radio to more accurately get engine data.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #3 of 6 Old 03-30-2020, 04:33 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by Kenscj View Post
Came here and joined to follow John Stenkís gauge troubleshooting link: am installing new fuel and temp gauges in 84 CJ and temp gauge pegs at hot without engine even running. So, at step 3 of his quick test tutorial, I have constant power, not intermittent at terminal A, (so light on, not flashing). Went to step 3 troubleshooting. Passed ALL the tests. Guessing the resistor is the problem, even though both gauges are brand new. Have been reading lots of posts about similar issues. Donít know what to try now. Appreciate any suggestions
Do you have 'new' OEM gauge or some aftermarket gauges? As far as I can recall, there are only two types of aftermarket gauges that look similar to the OEM gauges. One is wired like the OEM gauges and one is not wired like the OEM gauges.
A solid 12 volts on the "A" terminal usually indicated a bad ground. That prevents the regulator from operating and only puts out 12 volts.
If you have the dash disconnected or the speedometer hanging loose, you need to ground the case of the speedometer housing.
turbogus and pedal2themetai like this.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #4 of 6 Old 03-30-2020, 03:38 PM
turbogus
1978 CJ5
You know John, I've been knocking those alternative gauges for several years now and although I'm almost sure that I followed the installation instructions, I may have wired 'em wrong after all. Luckily Mac still had some NOS when I was working on those.
turbogus is offline
post #5 of 6 Old 04-09-2020, 05:19 PM Thread Starter
Kenscj
Thanks Mr. Strenck for the quick response. It's taken awhile for me to get back to this project. Also, I have written this response twice already, but apparently am too slow and I time out or something, and when I try to post I am told to reload previous page - and everything disappears. As if I don't have enough frustration with the gauges and dropping the dash over and over...
Fuel gauge brand is Ada Omix. Temp gauge is Crown brand.
I checked, rechecked, and checked again for ground - and it "appeared" fine. Did check of battery cable at battery - aha - high resistance. Replaced cable. Do all checks per directions again, good ground, fuel gauge working but regulator still not regulating, temp gauge pegged.
New idea: ordered some 5V voltage regulators, soldered one in line between fuel gauge and temp gauge, Now, for sure have 5 volts to temp gauge, but still pegged. (Probably cooked it). So, I tried one of the other temp gauges I have and it appears to be working (I have replaced this gauge a few times thinking they were broken and have kept all of them, including the original).
Now have to put dash back together - again - it's a bit cumbersome as I have factory ac. I am going to live with whatever I've got - working temp gauge or not - for the moment. Will come back to it another time if needed. I installed Howell TBI years ago and it has separate temp sensor which will alert check engine light if overheating.
This forum has a wealth of information. I am grateful for all who are sharing their knowledge, experience, expertise.
Kenscj is offline
post #6 of 6 Old 04-09-2020, 08:19 PM
John Strenk
1976 CJ5
Send us pictures...
